Technical HYDRAULIC BRAKE LIGHT SWITCH LOCATION
Discussion in 'Traditional Hot Rods' started by Steve Lowe, Jan 25, 2020.
  1. Steve Lowe
    Steve Lowe
    Can a hydraulic brake light switch be mounted anywhere in the brake system? Before or after an adjustable proportioning valve? Before or after residual valves? Does it matter? Recommendations would be welcomed.
  2. RmK57
    RmK57
    I converted my early Bronco to a duel reservoir master and used a tee off the master so I could use the original brake light wires. The original threaded right into the master, like most did. I ran mine off the front brakes, running off the rears may not be enough brake pressure to activate the switch, depending on how your adjustable proportioning valve is set.
    On my 57 Ford brake conversion I went with a regular electrical switch off the brake pedal.
  3. BJR
    BJR
    It could matter where you put it, it may come on a nano second sooner closer to the master and before any residual pressure valves, which may keep it on if installed after.
  4. Bandit Billy
    Bandit Billy
    I'd put it some place where it easy to get to when you have to replace it. ;)
  5. oj
    oj
    The front brake circuit sees pressure first, if in the rear circuit it might take a fair amount of pressure to trigger it.
  6. V8 Bob
    V8 Bob
    Much better to install a quality mechanical switch that works off the brake pedal vs messing with a hydraulic. :)
    brando1956, Jokester, Kiwi 4d and 9 others like this.
  7. Blue One
    Blue One
    from Alberta
    I’ve got a hydraulic switch that came mounted in my adjustable proportioning valve.
    As far as the guys saying be sure you can get at it to change it, I have a friend who has been running the same hydraulic brake light switch on his roadster for over 20 years now and never had a failure.
  8. I've seen enough trouble with hydraulic brake light switches that any car I have that uses one also has an indicator light inside the car so I can see if it's working.
    No question, put it somewhere easy to replace because you're likely to have to. I'd put it in the front brake system.
    Jokester, nochop and leon bee like this.
  9. trollst
    trollst
    I'm with V8 Bob, I was just out in my shop adjusting the mechanical switch in my roadster, they are cheap and easy to install, mine is from a 77 international scout, cost a whole twelve bucks from cole-hersey.
    brokenspoke likes this.
  10. squirrel
    If you can buy a brand new 20 year old hydraulic switch, then you won't have any trouble with it. But if you buy a new brand new switch, it'll probably die soon. So yeah, put it where it's easy to install and wire and work on and gets full MC pressure. But still you want a 20 year old NOS mechanical switch, instead, if you can find one that fits.
    2OLD2FAST likes this.
  11. Steve Lowe
    Steve Lowe
    My truck has a hydraulic switch which has worked fine for several years. Not sure if it was an NOS unit? Now that I've installed a two circuit master cylinder, I was mostly wondering if it would perform differently if it were placed behind the adjustable proportioning valve? Less pressure there right? Seems logical to place it in the front circuit or before the prop. valve if placing in the rear circuit? Well, I'm here because my "logic" does not always seem to apply when it comes to brake systems.:)
  12. squirrel
    you can try it and see what happens.
  13. Jokester
    Jokester
    Trash can. Use a mechanical switch.
    .bjb
    caseywheels and Tri-power37 like this.
  14. geezer37
    geezer37
    from 14120
    Had one in my rear brake line for almost 30 yrs. No problem still works fine!
    seb fontana and bobss396 like this.
  15. Blake 27
    Blake 27
    I used a Ron Francis low pressure switch in my rear line (drum-drum), has worked well since 2011. Not pictured is my drive shaft safety hoop.
  16. Mr48chev
    I had a hydraulic switch on my 48 for 15 years and not again. Longevity may depend on how exposed to road debris and water though. I felt that had something to do with mine failing every year or so. To the point I kept a spare in the truck but I was driving the truck every day as my daily driver and it wasn't a garage queen that averaged 50 miles a week over the year.
    When I worked in shops in the 70's I replace far more Ford Pressure brake switches than I replaced mechanical of all kinds.
  17. bobss396
    bobss396
    Mine is on the distribution block. The switch it came with leaked right away. The NAPA replacement took too much pressure for it to trip. Found a low pressure one on Ebay. Also carry a spare. The replacements years back were a lot better.
  18. speedshifter
    speedshifter
    I have heard that the short life of hyd switches can be from using silicone brake fluid. I like the cleaner appearanc & no moving parts with hyd switches. Greg
  19. HarryT
    HarryT
    When I built the truck in my avatar I used a low pressure brake light switch. It lasted 5 years then last summer I noticed it took a lot of pedal pressure to bring on brake lights. Not wanting to break into the system I left the pressure switch in place and wired the brake lights through a mechanical switch activated by the brake pedal. The brake lights now come on with just a touch of the brake pedal and the switch can be easily serviced.
    2OLD2FAST, clem and nochop like this.
  20. sloppy jalopies
    sloppy jalopies
    I was under the impression that the OEM proportioning valves on a ford let the rears take first to stop the auto ****** from continueing to spin the wheels, pushing the rearend and maybe causing a spin...
    it does this for just a few seconds then about 70% ? goes to the fronts where most of the stopping power is...
    for the northeners…. have you had bad rear brakes in an automatic and tried to slow to a stop on glare ice, had the rear wheels go on spinning and have the **** end try to p*** you... ?
  21. Steve Lowe
    Steve Lowe
    Here's some pictures of how I would like to plumb. Not much room on this old Mopar and being a retro rod, I try to minimize altering things too much. Anyhow, it's the easiest way I could come up with and not have to mess with any wiring changes. My initial query was concerning pressure switch placement. I'm hoping it's OK to put the hydraulic pressure switch behind the prop. valve? I'm now thinking it should not matter where the hydraulic pressure switch goes due to it must have some minimum amount of pressure to activate? I'm just mocking it up now and will fabricate a mounting bracket for the prop. valve. The front port on this master cylinder will feed to the 10psi residual in the photo. Rear port will go to new front discs via a 2psi residual. See any mistakes? DSCN2459.JPG DSCN2460.JPG DSCN2462.JPG DSCN2463.JPG
  22. seb fontana
    seb fontana
    from ct
    That will work fine, mine is just like that. I installed the proportioning valve vertical and have it come up through floor at front edge of seat..
  23. jimmy six
    jimmy six
    My Wilwood MC came with one. I didn't use because of the electrical connections. Put the original on.
  24. clem
    clem
    Easiest ? Should safety not be the priority here ?
    Have you not read the other posts above.
    With all due respect, you ask advice and seem to continue to ignore it.
    Posts 2, 3,4,5. answer your questions.
    Post 6 is from one of the most experienced brake guys on here !
    Many other posts have exceptionally good advice.
    Post 14 doesn’t explain his system, so may be completely different to your setup.
    There are plenty of other threads on this topic.
    Some people have had success with hydraulic switches that on other threads are referred to as HD, I ***ume over there, maybe refers to Harley Davidson, I am not sure.
    And there seems to be a right way up to mount them.
    That’s enough of my one finger typing wasted........
    Please Carry on.........
  25. Steve Lowe
    Steve Lowe
  26. Steve Lowe
    Steve Lowe
    Yes Clem, I have read all the posts and am not ignoring anyone. I don't do this stuff all the time and I have much respect for the knowledge and experience of many of those that love these old vehicles. In fact, V8 Bob especially and several others have given me great advice pertaining to my current front disc brake and split master cylinder project. I consider my truck a resto-rod. Had it for over 40 years. I've made many changes to it including T5 speed transmission, later model posi differential with taller gearing, 12volt conversion, alternator, halogen headlights,and other things. I also have always done everything possible to keep it so I or someone else could easily restore it back to stock. Still have all the original parts. In reference to the pressure switch, I agree that a mechanical switch is overall a more reliable choice. It's a bit difficult to install a mechanical switch and make it look right on this truck due the pedal geometry and how crowded it is in there. I would have to mess with the wiring harness as well. So, perhaps I'm lazy, but it was an easy choice to put back the hydraulic switch which has worked perfect for me for many years and plugged right in looking like it came from the factory. I have NOS ones on the shelf as well. So, It's just a choice I made. I just finished bending up the hydraulic lines. I would appreciate any constructive criticism if anyone sees something I've missed. Photos below: DSCN2467.JPG DSCN2469.JPG DSCN2471.JPG
  27. clem
    clem
    Appreciate your reply.
    When I pulled my hydraulic switch and went mechanical, I just extended the wires a little, but your wiring loom may be different.
    I am curious though as to the loops in your lines, is that to make bleeding easier or for vibration reasons or something entirely different ?
  28. Steve Lowe
    Steve Lowe
    Yes, for vibration and flexing. The original line from the master cylinder had a loop to the tee on the frame. I figure the Mopar engineers knew what they were doing. The master cylinder is mounted to the bell housing which moves with the engine torque. Even though the motor mounts on my truck are "almost" rigid, there is a a little flex when the engine is revved. Over time I imagine the lines might fatigue and crack?
    clem likes this.
  29. bschwoeble
    bschwoeble
    You might have a problem bleeding air out of the system if you point the switch up at 12:00.
  30. lostn51
    lostn51
    from Tennessee
    Okay I’m bringing this one back up because I’m plumbing the brakes on my 51 and it has a proportioning valve mounted to the master cylinder with several options for the front lines and has a low pressure switch for an idiot light. I’m using a manual pressure switch but where to put it? Do I put it into the block that the idiot light switch is or mount it close to the master on the front line? Can it be midway up to the tee to the front brakes? Here’s a picture of what I’m working with so you can tell me what’s the best way for me to do it. IMG_1792.jpeg
