Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. BJR
    BJR
    The Dewalt 20 volt cordless impact drivers are the greatest tool ever.
    b-body-bob, loudbang and Boneyard51 like this.
  2. Ron Brown
    Ron Brown
    No i wasnt. Damn. These are expensive as they are. Fraid to know how much those would be. Lol
  3. ken bogren
    ken bogren
    Dewalt seems to have a couple 20 volt impact drivers, which one are you guys talking about?
  4. big john d
    big john d
    from ma
    i live in the woods we get a ton of leaves in the fall rake rake rake unless you fire up the pressure washer and blow them into the woods and lets not forget the wonderful upside down oil filters on the slant sixes
  5. Ron Brown
    Ron Brown
    One of my drills is brushless. Great power and physically smaller. Its the one i reach for most the time
  6. Boneyard51
    Boneyard51
    Like most, I started out years and years ago with the Craftsman's and other brands cordless drill, something like 9.6 volts, was nice, but... Then the 12 volts things showed up and as soon as I bought one of those the 14 volts Dewalt showed.... yep, had to gave one of those..... used the **** out of it, had a few batteries, could work most of the day with it! But was pricey and BIG. Then you couldn’t get batteries for them. So it’s on the shelf.
    Then the 19.6 Craftsman showed up, I’ve got tons of tools and batteries and chargers for it, so I’m sticking with it......untill I can’t!
    But my leaf blower and chain saw..... they are 56 volt! !! Ah,ah, agh!
    What ever you buy today....... will be obsolete tomorrow.......so enjoy them while you can! Lol
    Mine still work for me.
    Bones
  7. pitalplace
    pitalplace
    I had a 18v Milwaukee but my wife took it.
  8. BJR
    BJR
    The Dewalt brushless impact drivers are the best, but I have both and they both work great.
  9. donno
    donno
    X2, I wash our cars in the garage and blow water of with a cordless leaf blower.
  10. phat rat
    phat rat
    Here's a 9hr https://www.ebay.com/itm/New-Dewalt...830099?hash=item3d9c275b93:g:ulEAAOSwvRJeLjye
    I just found there's now a 12hr https://www.ebay.com/itm/DEWALT-FLE...903889&hash=item42114d5ae3:g:jswAAOSwJBdeLlPv
    I have a number of different sizes of these 2,5,6 and 9hr. I have a reciprocal saw, impact wrench, drill, impact driver and a weed wacker that are all Dewalt 20v.
  11. Six Ball
    Six Ball
    from Nevada
    Nothing Makita, When I get to it I'll post a list here.
    One of the problems here is that we are off the grid and having chargers always plugged in isn't possible. My whole house and shop run off of batteries. We are a 24v DC power plant. Using batteries to charge batteries is an unnecessary step and you loose power at every conversion. I'm usually better off plugging in the tool and just letting the big batteries do it. I do have enough extra equipment now that I could put together a smaller solar changing station. Or figure out how to charge from DC right to the tool batteries.
  12. ThisOneGoesTo11
    ThisOneGoesTo11
    from Oxford, PA
    Tip: live in the 60's...but not shop-wise. There are now cheap nitrile gloves and safety gl***es out there. Plus LED cordless lights and cheap magnetic bowls and trays to hold loose screws and washers. And camera phones. Make your garage work as easy for yourself as you can!
  13. Six Ball
    Six Ball
    from Nevada
    How about the remote cameras that will fit into a spark plug hole. and drain or filler hole or down a carb throat. See under the dash or inside the trans.
  14. Doublepumper
    Doublepumper
    from OR-WA, USA
    ^ Been thinking I'd like one of those. Bet they would come in very handy.
  15. And don't forget those cheap thermal hand held thermometers with the laser sight. Perfect for working out which cylinder is misbehaving, seeing what your cooling system is doing, etc.
  16. Boneyard51
    Boneyard51
    Which wheel bearing is going out. Tire pressure. Lots of things!
    Bones
    wingspread7 and loudbang like this.
  17. DDDenny
    Found a neat video on alternative approach to fabbing 90 degree angle on square tubing.
    May not be the quickest and not to everyones liking but I was impressed.
  18. mohr hp
    mohr hp
    from Georgia
    When enlarging holes in wire terminals, clamp the terminal between 2 pieces of s**** lexan. Holds the terminal still and allows you to see what you're doing. Use a uni-bit.
    LowKat, Jet96, b-body-bob and 4 others like this.
  19. Kentuckian
    Kentuckian
    A quick and sure way to determine the outside diameter of tubing or anything round is to use open end wrenches as measuring tools. Last week I used a few different open end wrenches to determine whether the rear sway bar on a '65 Corvette was 9/16, 5/8 or 3/4. A 5/16 or 3/8 open end wrench will quickly determine what size steel fuel line a car has.
  20. blowby
    blowby
    from Nicasio Ca
    I always cut and save the cords from dead electric tools etc.. A drill needed a new cord the other day so I grabbed a leftover cord and tried to strip off the thick outer sheath with a razor blade to get to the wires. Kept cutting into the wire insulation. My wire strippers don't go big enough for outer sheathing.
    Then I tried cutting a small slice in the sheathing between the two wires at the end, grabbed both sides with pliers and pulled. Sheath ripped apart without damaging the wires. Maybe there is a better way but that worked.
    loudbang, Algoma56 and Boneyard51 like this.
  21. Ron Brown
    Ron Brown
    dont have a tip...gotta a question...has anyone figured out a way to store a half used tube of silicone without it developing a plug so thick you cant get to the rest of the silicone inside....i bet i've thrown away more silicone in plugged tubes than i've used.
  22. 56don
    56don
    I don't know if it will work everytime, but I used a wine cork in a tube of silicone and 2 or 3 months later I opened it and it was usable.
  23. Lone Star Mopar
    Lone Star Mopar
    They make a little plastic deal that you push down the neck of the the tube to keep the silicone or whatever product from drying out in between uses. I see them at HD right there in the isle w the caulk.
    Sent from my LM-Q720 using The H.A.M.B. mobile app
  24. Lone Star Mopar
    Lone Star Mopar
    brEad, loudbang, 28 Ford PU and 2 others like this.
  25. Six Ball
    Six Ball
    from Nevada
    Depending on how big of a hole you made when you cut the end off a big nail or screw works pretty well. Or wipe the end off well and wrap tape around the outside.
  26. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    The best way to keep silicone from hardening is keep it in the refrigerator. RTV stands for 'Room Temperature Vulcanizing'.
    Besides, this gives you a good reason to have a fridge in shop. As if you needed another one.
    This has been posted here before but I didn't start doing it until about a year ago. Haven't wasted a drop since.
    6-bangertim, loudbang, 56don and 3 others like this.
  27. RidgeRunner
    RidgeRunner
    from Western MA
    Long nail with an OD to closely match the ID of the cut off tip has always worked well for me. There, probably just jinxed myself :rolleyes:
    Ed
    loudbang and Six Ball like this.
  28. carolina chevrolet
    carolina chevrolet
    I use wire nuts on the ends of silicon tubes to keep it from drying out.
    LowKat, 6-bangertim, LAROKE and 2 others like this.
  29. 34Larry
    34Larry
    I also use them sparingly black ones about 3/16 wide. I do my very best to hide them also.
  30. Fortunateson
    Fortunateson
    Apparently suspending the tube upside down is supposed to keep the stuff from hardening so you can use it later but I haven't tried it yet. And thanks for the RTV deciphering!
