Projects 1932 Ford Roadster Build- "The Template Roadster"
Discussion in 'Traditional Hot Rods' started by x77matt, Jan 4, 2018.
  1. loudbang likes this.
  2. x77matt
    x77matt
    Great idea- It is a ******* car after all. I will do that. If you have any good examples, send it along!
  3. I don't. But I think a lot of 60s cars had drains in the trunk where the spare tire well is. I'm sure you could find something that would work.
    Alternately, just a little 1/8" hole at the front of the box (***uming you have a forward leaning rake).
    Atwater Mike likes this.
  4. RodStRace
    RodStRace
    First thing that came to mind is the old air-cooled VW caps for the crankcase.
    https://www.ebay.com/itm/VW-Bug-Bus...11115541-Duckbill-Draft-Tube-Cap/172950071107
    You could weld a short tube at the low point in the box and slip this over the tube.
    Check later model cars for the A/C drain. Same thing, let liquid out, but keep air and liquid from getting in. Just needs to be the low spot so it doesn't keep a 1/4" of water in the bottom...
  5. x77matt
    x77matt
    Yup- a duckbill. That what I had pictured also. Thanks for the link.
  6. x77matt
    x77matt
    Got distracted playing with old mini bikes but I did have time recently to pull the body back off to finish the ch***is up. Still wasn’t happy with the torsional stiffness so I added Ionia hotrod shop rear half belled boxing plates. I also added a continuous brace across the top that will fall under the body cross brace. You would be amazed at how easily the top of the rails will move inward without a dedicated cross brace. I will still add some decorative gusseting to blend it with the center trans mount are which will also add some needed shear stiffness through the center.
    20191217_190542.jpg 20191218_124108.jpg 20191218_205219.jpg 20191222_143030.jpg 20191223_234302.jpg 20191223_234206.jpg
  7. x77matt
    x77matt
    Added a shear plate behind the trans mount that really added some good torsional stiffness. Put a bottom plate on using bits from a ch***is engineering x member top plate. Added 3/8" rivet mainly for looks but they are pretty functional...
    20191228_120243.jpg 20191228_120300.jpg 20191228_142447.jpg 20191228_202206.jpg 20191228_202216.jpg
  8. qzjrd5
    qzjrd5
    from Troy, MI
    Looks great Matt. You're making progress on the '32 and the bikes!
    loudbang and x77matt like this.
  9. x77matt
    x77matt
    419602F9-39B1-4860-A951-DE55AD79752A.jpeg BD70B7A3-E445-4C26-A4E4-6645F79C6CF0.jpeg Final bit of fabrication complete today. I am using a Schroeder anti-roll bar in the rear and I had to get the mounts fabbed up to finish the ch***is. I will do some more detailed shaping on the arms but the mount to the frame is complete. Frame is officially done and ready for powder coat.
  10. x77matt and loudbang like this.
  11. DDDenny
    Nice work Matt
    Curious if you plan to add another tab on each axle tube to have double shear on the sway bar, also, am I correct in ***uming that is a mockup sway bar due to its small size.
  12. x77matt
    x77matt
    Thanks- yeah, i still have some detail work to do on the axle tube to strengthen it better. No need for double shear though on a 3/8” bolt for the roll bar forces on this.
    Also, that is the actual bar- it’s a 7/8” x 26” Schroeder bar that is .500 inch in the center. They are available in .025 increments for racing. I’ll post more pics of it when I pull it apart.
  13. x77matt
    x77matt
  14. x77matt
    x77matt
    Still waiting on the frame at the powder coater as he had to special order my color (1969 Ford Royal Maroon) but I did get my axle housings, torque tube and wishbones back. I did them in gloss black. I sent my pinion out Saturday to @HotRodWorks to get the splined end ground for the halibrand rear cover bearing. Once it’s back I’m ready to ***emble the rear axle!!
    3685BE01-162A-43D0-8111-BDB3407ED27F.jpeg D886D3BB-8C21-46F5-8B43-7F7DBB2A5E34.jpeg 220FECC9-E5B2-4923-AFA3-BBA73815B6C7.jpeg 177C814E-BC68-403C-BA70-A1905EB5B17C.jpeg
  15. hotrodlane
    hotrodlane
    Matt, You are doing an Awesome job with this build. I really dig how you made the support legs and trans top.
  16. Limey Kid
    Limey Kid
    Great progress, great work!
    Cheers,
    Stewart.
  17. x77matt
    x77matt
    Thanks Guys! I’m looking forward to the ch***is coming back home after powder coat! I just hope I didn’t miss any major welds or fab!
  18. DDDenny
    Matt
    How about some closeup shots of the ch***is' powdercoat finish.
  19. x77matt
    x77matt
    Sure thing- I expect it may take another week or two due to Covid delta on shipping powder from the supplier.
    This is what I’m using- 1969 ford royal Maroon. It is very close to 48 Ford Monsoon maroon
    Atwater Mike, pivir123, brEad and 2 others like this.
  20. x77matt
    x77matt
    More progress over the last week. Last weekend I flipped the body over and finished the detail welding on the bottom and then shot it with some 1969 Ford Royal Maroon so it will be ready to set on the ch***is when it gets back.
    2D329A92-8BCD-4C44-817A-AAED6705887D.jpeg 3741CC68-60CB-44DE-9CB9-3524A804B35A.jpeg
  21. x77matt
    x77matt
    This weekend I got my pinion back from @HotRodWorks and it looks great. I had them grind the ford pinion to accept the rear cover bearing. I spent a day and a half setting it up but it all went straight forward. I had spent the previous couple weeks preparing the parts for it though. The pinion bore in my case was set up with a smaller bore for a ball bearing pinion, but I wanted to use a stock Ford Double tapered roller. I carefully ground the pinion bearing race on my belt grinder to achieve a 3 thousandths press fit into the case. Also I had to use my trusty brake hone to ream the front and rear bearings for the lower shaft.
    I used the VanPelts website to follow the procedure for setting the carrier bearing preload and lash. I ended up with .004” backlash and 15 inch pounds of preload on the pinion. I put the bells on and off about 20 times but had a great result (I hope).
    CBA277E1-2780-44DB-96D9-DE1D2ED521FA.jpeg A190997C-AF3C-4605-8AB8-486714008F83.jpeg 0C452D0B-71FC-42D5-9496-C112DB1CCE5F.jpeg 71909F42-BB95-41BB-A969-A1D9AD034849.jpeg 44661B8A-3A28-43AF-8268-15422B5139FC.jpeg 57FEEA00-54C4-49AE-B142-98059025EA1E.jpeg 28A4DD40-7E5F-4692-AD30-7D1019A22162.jpeg 4DF7DDC0-5779-4A2A-A616-D2E634722F90.jpeg 61B5ED16-7A2B-418A-982E-61A233700A17.jpeg 1A17E472-1B14-4803-9334-13347831F6ED.jpeg
    cactus1, Runnin shine, Pat and 7 others like this.
  22. Great perseverance setting up that rear end! Everything is coming along.
  23. x77matt
    x77matt
    Ch***is is back from powder coat today! While it was out I have been messing with my engine and also getting the front and rear suspensions ****oned up. Today I picked up the Frame and mocked the suspension in place with my roller tire and wheel set. I’ll actually scuff and paint the frame rail outer section to match the body, but the rest of the powder coat will be pretty close in color.
    82B0622F-998A-4A1A-8FD0-A85272993946.jpeg 8FC465A4-1156-4BEC-B1E2-F78B8A95F4E5.jpeg B0BA4D9C-04E4-4030-9591-44EA8C5296FC.jpeg 4170B542-5E1A-4FCF-B161-FDECB1496063.jpeg 88C87152-6F2C-4D3E-80A7-2C9A945E46EF.jpeg 19BE3A34-B010-405D-BD7B-DBC90DB22FF1.jpeg
  24. Nice work, Matt. Has the former Template owner seen it?
  25. x77matt
    x77matt
    Yup- I’ve been keeping him entertained with photos. He approves so far ;)
    loudbang and Algoma56 like this.
  26. x77matt
    x77matt
    Brake lines and ch***is bits roughed in. Exhaust is just hanging there waiting for the motor, but it’s in enough to put the body back on to finish the body work. Old chrome parts cleaned up pretty well too!
    6BB4215E-12EF-44DF-B2EC-EE6B56E5E53C.jpeg 5E99FD05-8A7F-48DD-95F1-4F1A024EE995.jpeg 82F8A758-50AF-4D79-9831-C8309BEB9CCE.jpeg 25CC5C33-C6C4-4B25-8628-C174D28B88C3.jpeg 5372D883-07F0-4F98-8B60-D28158D90AB1.jpeg 543468C9-7400-43B8-9BAC-0AA4813FAC68.jpeg
  27. Limey Kid
    Limey Kid
    Looks great! Putting the running gear together for the last time is always a great feeling.
    Cheers,
    Stewart.
    x77matt, sloppy jalopies and loudbang like this.
  28. cactus1, x77matt and loudbang like this.
  29. qzjrd5
    qzjrd5
    from Troy, MI
    You're doing a fine job Matthew!
  30. fegsta
    fegsta
    Just on the rear floors did you use originals, as I read earlier in the post about them. With the body turned over with paint on thay look stock?
    Sent from my KOB-L09 using The H.A.M.B. mobile app
