Technical Let's see pics of well detailed frames
Discussion in 'Traditional Hot Rods' started by Roothawg, Jan 26, 2020.
  1. Roothawg
    Roothawg
    I spend a lot of time studying other people's cars. More so than most. I even have my wife doing it now.
    I appreciate the time and effort spent to make something look purposeful. Post up pics of nice, well thought out ch***is. I appreciate bandit Billy's cars. He has a similar affliction for polishing, like I do, so I can relate.
    Hopefully, he will post more pics of his stuff.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    Jowett Jupiter frame for the Car Craft dream rod
    A37DF0C7-81C7-4691-AEF7-5A2005D947AD.jpeg 533A86A3-BDFC-45ED-BFE9-282ADD560DEA.jpeg B9FCDD4F-ABA9-431E-9254-8D161B566958.jpeg
  4. Baron
    Baron
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Some really ****py pics of the futurian’s frame, one with me hamming it up
    055897C5-C4E7-474B-8ABC-D1968FF755B3.jpeg 2531AF0A-B47D-473C-93CD-3E718187F5D0.jpeg 7BB016AA-0193-48B7-A4AA-C82CD0279CBE.jpeg 5D12B193-A580-47C7-B996-15A000C86F84.jpeg E20C98AE-4D91-4434-A28B-BB9C7110DEEF.jpeg
  6. Beautiful work,,,,, !
    The only reason I checked on this thread was because Moriarity was on it .
    Roothawg,,,is that pic Billy’s frame ?
    Looks like his color of choice .
    Bandit does awesome work as well !
    Tommy
    Roothawg, Bandit Billy and Moriarity like this.
  7. Bandit Billy
    Bandit Billy
    The last pic of the frame before I put the body on.
  8. Roothawg
    Roothawg
    Yes, it is.
    loudbang, OLSKOOL57 and Desoto291Hemi like this.
  9. Billy I have never met you but you also do fabulous work.
    The color contrast with the exterior body,,and the firewall under body color.
    Man,,,it just goes together.
    It looks like pure cl***,,,,combined with hot rodding .
    All the chrome and polished stainless,,,combined with the colors.
    Man,,,I would be a nervous about even getting around yours and Marks rides.
    I might accidentally breath on it or something.
    Now,,,I like the regular stuff as well,,,,,that’s all I can ever do anyway .
    However,,,we should always try to be the best we can.
    I especially have respect for the ones that do it themselves.
    Tommy
    Bandit Billy likes this.
  10. Roothawg
    Roothawg
    Show pics of your custom motor mounts, brackets, hangers etc.
  11. -Brent-
    -Brent-
    Still quite a ways to go on the ch***is but here are my front motor mounts and bellhousing mounts.
  12. Roothawg
    Roothawg
  13. Flathead Dave
    Flathead Dave
    from So. Cal.
    Very nice work...
    Damn, I wish I had the room for a lift.
  14. Bandit Billy
    Bandit Billy
    @-Brent- that is nice s***ch work.
    Mine? I built them out of SS, they bolt in to threaded bungs that run all the way through the frame rails and boxing plates. The flathead and ****** drop out the bottom of the car for service thus the motor mount engineering. I had to test that feat when I found out the hyd TOB was leaking. Radiator, hood, sheet metal all remained on the car while I R&R'd the drive train.
    Exhaust hangers are 8BA rods that I cut down. The tubing was to help isolate the hangers from the frame. I guess it works :cool:
    I welded more threaded bungs into the tubing to hold the 6 rod/hangers. Here is one.
    It is not without its fault and errors, but like was said above It is the best I can do.
    atch, 1Nimrod, Rolleiflex and 15 others like this.
  15. Allmotor
    Allmotor
  16. Montana1
    Montana1
    Here's one of the Montana '32 in 12-16-2006. That was 100,000 miles ago!
    1Nimrod, 1947knuck, LOU WELLS and 6 others like this.
  17. 34Larry
    34Larry
    331, with Torque-flight, "C'd 4", with 4-1/4' kicked rear cross member.
    1Nimrod, 1947knuck, 32SEDAN and 8 others like this.
  18. Baron
    Baron
    I like painting the floor a different color than the body/ch***is, other-wise the ch***is details disappear . 20200119_135352.jpg
    atch, John Heckman, 1Nimrod and 15 others like this.
  19. DDDenny
    That's a no s#itter!
    A lot of dimes too!
    1947knuck likes this.
  20. mgtstumpy
    mgtstumpy
    Nothing flash, I just moved the side mounts back due to Fentons, insufficient room in OEM position. No room for [Hurst] saddle mounts due to other OT accessories with Alan Grove brackets (AC & PS). Engine tube had to be widened slightly (Sleeved). Rear of brackets is reinforced for strength.
    1Nimrod, 1947knuck, LOU WELLS and 4 others like this.
  21. Marty Strode
    Marty Strode
  22. bymanr
    bymanr
    IMG_1159.PNG Frame for my avatar.
  23. -Brent-
    -Brent-
    I think it looks slick!
    They all have their idiosyncrasies. Most times nobody would ever know unless it's posted online.
    loudbang and Baron like this.
  24. LM14
    LM14
    from Iowa
    My '32 build. Happy with the quality of the build so far.
    SPark
    assembly1d.jpg assembly1e.jpg assembly1f.jpg assembly1g.jpg assembly1h.jpg assembly1i.jpg assembly1j.jpg assembly1k.jpg assembly1l.jpg assembly1m.jpg assembly1n.jpg assembly1o.jpg assembly1p.jpg assembly1q.jpg assembly1r.jpg assembly1s.jpg assembly1t.jpg assembly1u.jpg assembly5b.jpg assembly5c.jpg assembly5d.jpg assembly5e.jpg
  25. Chainsaw chipper
    Chainsaw chipper
    from Illinois
    I'll join in with a few shots of a 32 roadster frame we completed awhile back.Hope this is what you are looking for,Thanks Ken
  26. jetnow1
    jetnow1
    from CT
  27. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    @bymanr
    Can you post some detail shots of your front suspension? Is that a Panhard bar attached to the right wishbone?
  28. Blown35
    Blown35
    QUOTE=I appreciate the time and effort spent to make something look purposeful. Post up pics of nice, well thought out ch***is.
    - Not a custom but lightly modified stock for my period correct S.C.o.T. blown Flathead Three Window
    PICT0025.JPG PICT0022.JPG PICT0034.JPG [
  29. Marty Strode
    Marty Strode
  30. Bandit Billy
    Bandit Billy
