Technical Heater hose
Discussion in 'Traditional Hot Rods' started by kennj, Jan 27, 2020.
  1. kennj
    kennj
    does anyone make heater hose that can be bent to a 45 degree angle without kinking, I know there are molded pieces with a 45 but only short pieces
  2. kennj
    kennj
    Out of the heater then a close 45, then about 4" to another 45 in the opposet direction and then straight to the engine
  3. Bob Lowry
    Bob Lowry
    I have a older Corvette and needed a unique 90 degree bend. My solution was to use a copper plumbing elbow with two clamps...worked perfect. You can find 45 degree copper unions as well. They fit snugly inside the heater hose, allowing you to clamp the tightly. Just a idea for you. Bob
    Just Gary, 56don and Tim like this.
  4. Smokeybear
    Smokeybear
    Go to an old school parts place, most will let you go in the back to see the hoses they have in stock. You can ask a box store like autozone or o'reillys but they may not let you go behind the counter.
  5. kennj
    kennj
    Did go thru the parts store but they just had short stuff , trying to do one piece and not have a bunch of connectors
  6. OLDSMAN
    OLDSMAN
    I bought one from O’reily had about 4 inches on one end then a 90 then about 2 feet
    lothiandon1940 likes this.
  7. moparboy440
    moparboy440
    from Finland
    My local parts store sells a hose called Gates shape N Fit heater hose that is reinfored with a wire.
    You can bend it 180* without it kinking.
    Great product, only drawback is that it is quite ugly if you are intending to build a show car.
    lothiandon1940 and jimmy six like this.
  8. 5window
    5window
    Don't know how street-roddie you want to be,but you could do it with Cool-flex pretty easily
    Sent from my moto g(6) using The H.A.M.B. mobile app
  9. KoolKat-57
    KoolKat-57
    from Dublin, OH
  10. Mr48chev
    I'm not finding it online right now but the printed Gates and probably Napa hose catalog (s) have a section that shows pictures of every molded heater hose that they list. you may have to buy a hose with several other bends on the other end to cut the section out of but you may find what you need there.
    I can't see anyone using that damned copper house plumbing on a hot rod and anyone suggesting that **** needs to be slapped alongside the head. Leave that stuff to the rat rod brigade.
    On the other hand an HVAC shop might be able to bend up the correct size stainless or aluminum tube with the right bends and the roll at the end to retain the hose for a reasonable cost to where you just use short pieces on each end to connect it.
    Tim likes this.
  11. The heater core ******s are copper and the radiator ******s are copper on an original.
    71077B38-E5A7-4542-8CD2-5AF3C46BD226.jpeg E06E2778-3840-49C6-85C4-74C0F3014647.jpeg B98E07DF-A7F5-47C9-AE48-299153A95476.jpeg 8C5AB8E9-CE6A-445A-85DB-CF4926EDE974.jpeg D328843A-61FE-49BA-ADB6-C1221F76AADF.jpeg F0E3E0E2-D155-4D80-91EB-B4966BD49C56.jpeg 70B20C0F-CA36-4C61-9091-4E9E6032CBBE.jpeg 660ED674-B87D-4951-AB6C-E1AD2859C69C.jpeg
    5window likes this.
  12. inthweedz
    inthweedz
    Not sure if the USA market had the 1994-2000 Nissan Skyline's..
    If you did, it could be worth doing a "Google image" search..
    Their heater hoses are long, with many bends in them.
    Might be something there you could use..
  13. bschwoeble
    bschwoeble
    Please take the time to find the hose that works. The chrome corrugated stuff and the flexible wire covers all belong to the billet crowd.
  14. bodymanmp
    bodymanmp
  15. sloppy jalopies
    sloppy jalopies
    IMO... make the heater hoses a little long so you can switch which hose flows in and which flows out...
    switch the ends every year... may flush some sludge out of the core... helps stop back ups.
  16. 5/8 and 3/4
  17. sloppy jalopies
    sloppy jalopies
