Technical change over to juice brakes
Discussion in 'The Hokey Ass Message Board' started by MERCURYGUY, Nov 6, 2019.
  1. MERCURYGUY
    MERCURYGUY
    Hi guys ! need some tech info on change over to juice brakes on my 36 ford. The wheels are no problem but can someone tell me how I can mount the master cylinder ? Is there a kit to do this ? Can I use say a 40 petal ***y to accomplish this ? Many thaks Mercuryguy
  2. Try contacting Richard Lacy at earlyv8@aol.com (mail), (626) 338-2282. Relative to your comment on the '40 pedal ***embly, I believe most guys use the '39 due to the location of the clutch lever (I still recommend contacting Richard Lacy).
    Charlie Stephens
  3. alchemy
    alchemy
    I'd say find a complete 39 Ford brake and clutch pedal ***embly. Other than opening the hole in the crossmember a little, it's basically a bolt-in.
    A 40 ***embly is different and would need you to change the clutch throwout shaft. Lots more work.
    guthriesmith likes this.
  4. Truck64
    Truck64
    from Ioway
    Are you sure you want to take a step down in reliability like that? Brakes are important, after all.
  5. MERCURYGUY
    MERCURYGUY
    Thanks Guys for the imput Mercuryguy
  6. bct and panhead_pete like this.
  7. panhead_pete
    panhead_pete
    Lloyd's paint & glass likes this.
  8. 51504bat
    51504bat
    Like Charlie says
  9. Pensive Scribe
    Pensive Scribe
    If you manage to find the 39 pedal ***embly you will also need the clutch actuating arm (shiny black in the picture) if your using the stock 36 transmission. Reproductions are available, but if you have a chance to get it too, grab it. I wish I would have been told this before I converted, so I'm p***ing the info on now.
    Here is another picture of my installation in case someone needs more for reference.
    bct likes this.
  10. alchemy
    alchemy
    Scribe, why do you need a 39 transmission arm? Is the 36 too short?
  11. Lloyd's paint & glass
    Yeah i would modify your existing pedal. I've done a few that way. And used a master cylinder from a slightly off topic 68 Ford F100 with drum brakes. 7:1 ratio on your brake pedal.
