Technical Unique air cleaners...
Discussion in 'The Hokey Ass Message Board' started by rustydusty, Jan 15, 2020.
  1. hotrodjack33
    hotrodjack33
  2. Fitnessguy
    Fitnessguy
    Just completed my take on a oil bath type look but a little custom. Went with this colour for now as it ties in to the Rochester carb body colour. Was gonna go black but wasn’t quite sure. Can always squirt another colour on it down the road. Hand fabbed from a sheet of 18 gauge.
    wcben, weps, PoTaToTrUcK and 22 others like this.
  3. fourspd2quad
    fourspd2quad
    0E4EA82F-A76D-4846-A802-E0AC3E9D0EA1.jpeg Top of a ‘56 Chevy oil bath air cleaner and custom made bottom to fit my Edelbrock 4 barrel.
  4. jimmy six
    jimmy six
    Hey guys found another “look” for dual quad applications when shopping at Summit. A few companies, Kluhsman, Keyser, Allstar, etc make carb covers out of metal and not plastic looks like a pair of dominator ones would work and being aluminum could be polished. May be a std 4 barrel top could be used for 2 barrel tops with 3-2’s... Just a thought...
    Deuces and loudbang like this.
  5. 41rodderz
    41rodderz
    from Oregon
    I like the craftsmanship :)
    Deuces, Fitnessguy and Desoto291Hemi like this.
  6. gearsforguts
    gearsforguts
    from temple,pa
    This is the polished scoop I have on my 61 Falcon. received_483965892503791.jpeg received_631689387645082.jpeg
    AHotRod, PoTaToTrUcK, GordonC and 5 others like this.
  7. Hollywood-East
    Hollywood-East
    skooch, wcben, AHotRod and 12 others like this.
  8. 26 T Ford RPU
    26 T Ford RPU
    I always wanted an oil bath style filter. I rolled a 5'' ring to suit the carb and removed enough inside to fit an AP5 Valiant element. JW
    72yenkonova, AHotRod, wraymen and 7 others like this.
  9. Fitnessguy
    Fitnessguy
    Thanks man. Started with a sheet of 18 gauge and a picture in my head. A lot of fab work for sure. All hand done except the bead roller for the few bead lines
  10. Speed~On
    Speed~On
    Here are 2 of my Boettger air cleaners. I have always thought these look great...and unique.
    skooch, wcben, AHotRod and 18 others like this.
  11. jimmy six
    jimmy six
    They look *****in with a lite in them.
    PoTaToTrUcK and loudbang like this.
  12. Elcohaulic
    Elcohaulic
    Your intake would look better and your engine would run much better if you were to block off the intake heat... Some guys use epoxy with gaskets that have steel block off plates in them..
  13. Elcohaulic
    Elcohaulic
    I'm planning on using a 1958 Tri Power intake with the three hole base swapped out for a Quadrajet..
  14. Speed~On
    Speed~On
    What's cooler than having 2 Boettger air cleaners? Adding 6 more to your collection:D
    wcben, chevy57dude, Tman and 10 others like this.
  15. rusty rocket
    rusty rocket
  16. uncleandy 65
    uncleandy 65
  17. Petejoe
    Petejoe
    from Zoar, Ohio
    Oh yea!!!
    AHotRod, Deuces, 41 GMC K-18 and 3 others like this.
  18. wraymen
    wraymen
    Just made this from a fish cooker. Used the fry tray to hold the filters down. Cut the bottom out to shorten it and rolled the lid lip to fit tight.
    4B7786BE-D241-4B4C-B021-C436E9B50B96.jpeg B34A7C87-C6F1-4C35-B940-A92EA11D3B31.jpeg A58192E4-80C5-4422-B7B5-FB1ADF5C0465.jpeg 4F488385-DE41-4B43-B22F-CF414A0A582C.jpeg 20FD114D-1727-44F9-A479-E86E2828659F.jpeg
  19. uh, did I tell you about my Planters Peanuts can with holes drilled everywhere, and a knitted pot holder stuffed inside?
    I was about 14 or 15, and bought a well used Harley dirt track bike with no filter.
    It needed something to keep the leaves and sticks out...
    good old fun days :)
    Sent from my SM-G981V using The H.A.M.B. mobile app
  20. hd1084
    hd1084
  21. Blue One
    Blue One
    from Alberta
    I was having airflow issues with my Y block, choking it up and making it run rich using the little 4x2 filters so I contacted Dennis at O’Brien Truckers and ordered a set of these 4 1/2” Edmunds air cleaners.
    They should flow lots of air and they have washable elements.
    A7E9E9FC-30B3-4245-B7AF-E4B3628171D6.jpeg F4A103DD-E2D7-4343-93D5-D444A40F39FF.jpeg 9E61952F-42B0-41E9-A133-17CD66EF101C.jpeg 7558734A-0377-4B78-9B90-01A1C45A92E9.jpeg CF492422-3C0E-4973-B15D-1CC5B452310A.jpeg
    40FORDPU, ekimneirbo, hd1084 and 9 others like this.
  22. Blue One
    Blue One
    from Alberta
    I’m not surprised at all that you went in a different direction.
    You couldn’t see the direction you wanted to go anyway :D:D
    VANDENPLAS and clem like this.
  23. Country Joe
    Country Joe
    Well, technically, it did come off a shelf. A a shelf in the bakeware store. :D
    210superair likes this.
  24. 210superair
    210superair
    from Michigan
    I'd like to do something different, but at the moment I'm rolling around the idea of tri carbs. I can't bring myself to do it because the car runs awesome and I don't wanna go messing around right this moment for a few reasons. Right now I just wanna drive it....
    AHotRod, dana barlow, Deuces and 4 others like this.
  25. wraymen
    wraymen
    I change air cleaners routinely on my Austin just for the hell of it. Keeps it interesting. I see something and start thinking, man how could I use that. It’s not traditional I guess but it keeps me happy.:)
    I found 4 of these and hope to get some br***/copper velocity stacks formed up to attach them too. Yeah I’m eccentric.
    CEBFF563-59C3-41EF-A9F5-3126F573EB40.jpeg ACA7102B-C576-4E0C-A7FE-14548B0C377C.jpeg
    AHotRod, Deuces, GordonC and 3 others like this.
  26. 210superair
    210superair
    from Michigan
    Vintage marine vents? Now you got me thinking. There's a bad *** bow vent on my Chris Craft That'd make a cool cover... s-l300.jpg
    Deuces, GordonC and wraymen like this.
  27. Jokester
    Jokester
  28. Elcohaulic
    Elcohaulic
    Once you get it running so good that you don't want to touch it, don't!! I've made that mistake and regretted it.. When you think of it, there are so many different combinations of settings that you might never find it again.. I would get the timing lite out and write everything down.. I've been do***enting settings along with octane and temperature.. That way I have proof of what works and doesn't work..
  29. Chappy444
    Chappy444
    Saw this laying around @Clark shop.
    It caught my eye for a topper for my current project.
    Its a 1930s motor cover from an electric floor polisher...lol.
    Bonus points, the peak on it matches the peak on the 34 pontiac grill shell I am going to use...
    Chappy
  30. Stueeee
    Stueeee
    from Kent, UK
    Couldn't find anything I liked as an air filter lid for my 1950 truck. Here's the wooden casting pattern I made.
    needs to be smooth to "draw" from the sand mold.
    Buffing the raw casting to a bit of a shine.
    Fitted to my truck:
    BTW, on a previous occasion when I posted a pic of my truck's motor, some members said that it "wasn't traditional" being "80s billet" So, for the record, on this early SBC motor, most of the stuff like the stainless brackets and pulleys are actually 2005 billet, I know this, because the majority of these parts were machined in my workshop after I imported the truck; parts from or via the US cost a fortune by the time they arrive here in the UK.
    e.g. here's the start of the alternator pulley that's in the photo above.
    AHotRod, clem, VANDENPLAS and 9 others like this.
