I need help with comp cams specs
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jul 1, 2006.
  1. Roothawg
    Roothawg
    I need specs on these valve springs please. I should have called Comp Cams yesterday but I didn't.....it's a holiday weekend now....dang.
    [FONT=Arial, Helvetica, sans-serif] Valve Springs[/FONT] [FONT=Arial, Helvetica, sans-serif]977-16[/FONT]
  2. D.W.
    D.W.
    from Austin Tx.
    Hey Root, Bottom of the Comp cams home page, under technical is "charts, graphs, specs" This leads to a PDF do***ent. #977 is listed by O.D. & by installed height.
  3. Here ya go...straight from the book.
    Compe***ion Cams 977 Spring 1.460 O.D. .700 I.D. Check Height / Pressure - 1.850" / 160 ,
    Open / Pressure - 1.25" / 440 , Coil Bind 1.200 "
  4. Roothawg
    Roothawg
    Thanks guys....
