Technical Quick Question
Discussion in 'Traditional Hot Rods' started by Willywash, Jan 30, 2020.
Tags:
  1. Willywash
    Willywash
    I want to use a steel mechanical fan on my 31 A build. I've used a four blade on my 41 GMC, but it doesn't cool quite as well as I would like. Will a six blade move more air? The four blade looks much better to me in a 30's car. I'll be running a SBC in my A, no fenders, just hood.
  2. jetnow1
    jetnow1
    from CT
    How high is the fan on the radiator and are you running a shroud?
  3. Texas Webb
    Texas Webb
    This will make for a better cooling^^^^^.
  4. Warpspeed
    Warpspeed
    Definitely a shroud for best possible cooling, but that may not be the "look" you want.
    Apart from that, how much radiator area the fan sweeps, and how close it is will also have a big effect where there is not a shroud.
  5. Gary Jr
    Gary Jr
    I like a flexfan and a shroud.
  6. alanp561
    alanp561
    I like what actually works best for a specific application
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
    lothiandon1940 likes this.
  7. HotRod33
    HotRod33
    I have put a six blade fan from a 6 cylinder ford AC car on my 33 pickup.... it has more of a hook on the blades and It pulls more air than the 4 blade fan that I had on my 289 ..... I don't have a shroud on it and cooling is not a problem...
  8. solidaxle
    solidaxle
    from Upstate,NY
    I have a four blade on my flat head with only a quarter inch from the rad. Not by choice that's all the room I had. Runs cool. I don't have a magic answer for you. Consider the condition of the rad and thermostats.
  9. dirty old man
    dirty old man
    With an SBC in an "A" your fan is down so low that only a very small OD fan will clear the front crossmember.
    Costs more upfront, but a Zip's water pump riser will allow you to run a much larger OD fan.
    Do a search,lots of posts on it.
