Projects 1957 2 door 150 handyman
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Nov 17, 2019.
  1. Lloyd's paint & glass
    Clean the gl***, and lay your template on it, trace with sharpie, or crayon. 20200130_202041.jpg
  2. Lloyd's paint & glass
    Then the handy dandy gl*** cutter. Not teaching a cl*** here, but not everybody knows how to cut gl***, so this is for them. Anybody can do it, just takes a little finesse, and a $3 gl*** cutter lol. No it doesn't cut gl***, it scores the gl***, then you 20200130_202202.jpg break it on the score line.
  3. Lloyd's paint & glass
    Support the gl***, i usually lay a towel under my gl*** on a piece of 3/4" plywood, but i was too lazy to walk out to the shop truck. Firm pressure, pull the cutter along the line, on the opposite side you marked on. 20200130_202342.jpg
    loudbang and low budget like this.
  4. Lloyd's paint & glass
    Apply some heat to soften the laminate plastic between the layers of gl***. Sometimes i use rubbing alcohol, but the release agent i carry to clean up urethane messes is flammable, so i spray it across the break and set it on fire. Fold the gl*** slightly enough to create a gap that you can run a razor blade in and cut away your work piece 20200130_203314.jpg
    loudbang, low budget and scotty t like this.
  5. Lloyd's paint & glass
  6. Lloyd's paint & glass
    You (or should i say I) can't cut round corners. You can to a degree, but you have to finish up with a belt sander. I cut the bulk away and then sand. I don't own a huge belt sander setup, i buy cheapo belt sanders, always have. I do 95% of my gl*** cutting on site, old cars, box trucks, heavy equipment, so my belt sander is my buddy. 20200130_203930.jpg
  7. Lloyd's paint & glass
    Water water water! I'm using an 80 grit aluminum oxide belt. On the tops of door gl***es where your arm lays, I'll finish with 120. 20200130_204117.jpg
  8. Lloyd's paint & glass
    When you mark your template, be sure you cut on the inside of your line.
  9. Lloyd's paint & glass
  10. Lloyd's paint & glass
    Your choice when it comes to installing the gl***. On something like a model A windshield i use black silicone, because it's encased in the flame, and if you ever need to change the gl*** again you'll be able to get it out. But on a piece like a wing window i use windshield urethane. If you have to change it you just break it and clean the channel out with a screwdriver :D 20200130_210836.jpg
  11. Lloyd's paint & glass
    Run a bead around the channel, and press your gl*** in! Get you a pair of rubber gloves first lol. A handful of single edge razor blades, and clean the squeeze over off of the gl***. I spray the gl*** with window cleaner first to keep it from spreading. Not as bad as it sounds. (Note that i didn't glue this, I've gotta fix the latch first and i gave up for the night) 20200130_211531.jpg
  12. Lloyd's paint & glass
  13. Lloyd's paint & glass
    My tank has some crud in it but it's not rusty, i think i can clean it up. Gotta get that done, it's amazing how fast that gallon jug runs out :rolleyes:
    chryslerfan55, loudbang and scotty t like this.
  14. Stephen Barrett
    Stephen Barrett
  15. Lloyd's paint & glass
    Thank ya brother! It's been a good day :D did you get anything done on the sedan today?
  16. Stephen Barrett
    Stephen Barrett
    No. I had to work to pay for all this. lol. I was able to put my new engine stand together though. At least it's something.
  17. Lloyd's paint & glass
    Seems like that's all I've been doing! Felt good to work on my junk for a change. It's all progress brother ;)
    loudbang and Stephen Barrett like this.
  18. hotrodjack33
    hotrodjack33
    Hey Lloyd, Nice tutorial on the gl*** project. Looks like you may have done that once or twice before (Duh, Lloyd's paint & gl***):D. I probably would have stuffed in a piece of Lexan with J-B weld:eek:
  19. Lloyd's paint & glass
    I've done it that way many times lol, but that damn lexan costs more that gl***!!
  20. hotrodjack33
    hotrodjack33
    Yeah, but it looks like you've graduated from the "dumb guy" methods:D...Me? I'm still there:eek:
  21. low budget
    low budget
    from Central Ky
    Think we use to have tech week around here, This would have been a great one for that!
  22. Lloyd's paint & glass
    Throttle cable and bracket done. Paracord retired :D Screenshot_20200131-141835_Gallery.jpg
  23. BamaMav
    BamaMav
    from Berry, AL
  24. Nude Stude Dude
    Nude Stude Dude
    I had one a few years ago with a 327 and 4 speed. The body was a little rough but it could move pretty well so I didn't worry too much about it. Good luck with yours....
  25. Lloyd's paint & glass
    Thanks man, just got a haircut today and trimmed the mustache, but I'm glad you noticed ;):D
    scotty t and loudbang like this.
  26. Lloyd's paint & glass
    Mine ain't bad, but it isn't perfect lol. I've started with a lot less for sure! Welcome to the HAMB by the way! Traded for a 40 Buick with a guy in Louisville a few years back, about your age.
  27. Lloyd's paint & glass
    Oh i have a lot of "dumb moments" lol, how else do we learn :D
    chryslerfan55, scotty t and loudbang like this.
  28. Lloyd's paint & glass
    Got my gauge cluster today, thanks @tyeager55 ;) once again my genius UPS driver took it to the old lady half mile down the road :rolleyes: she sure gets a lot of hot rod parts :D Screenshot_20200203-200455_Gallery.jpg
  29. woodbutcher
    woodbutcher
    :D UPS="Uncaring Package Service".
    Good luck.Have fun.Be safe.
    Leo
  30. hotrodjack33
    hotrodjack33
    Priority 1...install gauge cluster.
    Priority 2...start car.
    Priority 3...try to get the needle all the way to the other side of speedo:D
