Here is a '30 Ford Sedan built by Mississippi NSRA Builder of the Year Les Rude. Has Clear ***le. All steel body Chopped 7 inches Doors stretched 4", door post moved back 4", body not lengthened Custom frame Channeled 3" 350 crate motor, stock Custom made ceramic coated headers 700 R4 trans 9" Ford rear end w/ 3:50 gears A/C, condenser under car with electric fan Tilt column Front and rear power windows Torque Thrust D rims Bias ply tires, 15x6 front, Firestone 5.60 15/ 15x8 rear, Firestone 8.20 15 Disk brakes front, drums rear Coil over shocks rear Mono leaf front Gun metal gray paint with semi-gloss clear Aluminum radiator Black tuck-n-roll interior Electric dashboard folds down for easy access to the wiring and fuses CD player No Trades More info, redingermichael@yahoo.com or sawfish54@live.com
I have a video of the electric dashboard that folds down for easy access to the wiring and fuses. Email me if you want to see it.
