Technical Wide Whites
Discussion in 'The Hokey Ass Message Board' started by Jamoke, Feb 1, 2020.
  1. Jamoke
    Jamoke
    Where did you purchase your wide white wall tires from looking for something other than Coker.
  2. Mopar Tony
    Mopar Tony
    The only other one I know of is diamondback. It crazy how expensive these things are.
    BigO likes this.
  3. Jamoke
    Jamoke
    Couldn't agree with you more. They're in the demand You're going to pay for it. Crazy
  4. Mopar Tony
    Mopar Tony
  5. 40LUV
    40LUV
    from Mid Jersey
    Go with Diamondbacks.
    olscrounger and BigO like this.
  6. Jamoke
    Jamoke
  7. LuckyFordGuy
    LuckyFordGuy
    Go with Diamonbacks had them for years ride good an balance good just order another set price is a little spendy
  8. Jamoke
    Jamoke
    Yeah, I guess you get what you pay for in the long run.
  9. LuckyFordGuy
    LuckyFordGuy
    That is very true
  10. ochamsrasor
    ochamsrasor
  11. squirrel
    never heard of them. Interesting...permanent portawalls.
    "Calli Tire & Wheel LLC is proud to introduce our line of custom made and affordable whitewall tires! Our process takes a radial blackwall tire and turns it into a whitewall tire using real whitewall rubber. This is not paint, but real raw whitewall rubber. The raw rubber is vulcanized (cured using heat and pressure) to permanently bond the whitewall rubber to the tire. Calli Whitewall tires are made with an added stain blocker. This is a black rubber layer that goes under the white rubber, and its purpose is to keep the whitewall white"
  12. Jamoke
    Jamoke
    What brand of tires are you using? And what's the mileage? Barrier
  13. squirrel
    Are you asking me what tires I use? I just copied and pasted that info from the Calli web page that you linked to. I think wide whites look ****y, and don't put them on anything
  14. Jamoke
    Jamoke
    I'm sorry. I thought you were from the company. Nevermind.
  15. squirrel
  16. BigO
    BigO
    Heard a lot of good things about Dia****backs.
  17. jimgoetz
    jimgoetz
    Try "Universal Vintage Tire". I'm running US Royal's but they have many other makes.
  18. Special Ed
    Special Ed
    I've had both good and bad results with Diamondbacks. I'll be ordering a set of Calli's soon, because of the cost.
  19. atomickustom
    atomickustom
    Universal has been around forever, since the 1970s at least. I remember their catalog from back then.
    jimgoetz likes this.
  20. K13
    K13
    I would say the opposite is true they really aren't in demand so the cost to produce limited numbers means each tire has to cover way more of the production costs. We get to add about 40% to those prices by the time we pay exchange and brokerage up here.
    Sent from my SM-G950W using The H.A.M.B. mobile app
  21. bskustoms
    bskustoms
    from Aloha, Or.
    Diamondbacks, spendy but looks and safety for my ride and FAMILY the cost is never too much.
    Be Kool!
  22. scoop
    scoop
    Diamondbacks,have them on my 31 and will be buying another set for my 30.
  23. Jamoke
    Jamoke
    Got a great Price from Performance Plus Tires on
    Aurburn Bias Ply Radials Wide Whites
    Just under $1000 shipped to my door
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    I moved this to the main board. the traditional custom forum is no place for a discussion on radial tires.....
    jimgoetz and K13 like this.
  25. jimmy six
    jimmy six
    My Diamondbacks were on Cooper tires..
  26. rockable
    rockable
    I have 3 cars running the Cokers and will put them on my Buick when finished. Never had a problem and the quality of the appearance is really good.
  27. Lost in the Fifties
    Lost in the Fifties
    Their site says Calli tires are Nankang or Hankook radial tires with whitewalls vulcanized on. They don't look wide white or bias. They look like 15'', 14" & 13" low-rider tires.
  28. fordflambe
    fordflambe
    These are diamondback and were on the car when i bought it a couple of years ago. Whitewalls are vulcanized onto TOYO carcus. I have read one guy gripes about whitewall coming off of his Diamondbacks but i have to say mine are solid and no signs of failing. I drive cross country on freeways at 80 and back roads up, down, and around hills and have had zero problems in about 20,000 + miles. Tread wear is great and car handling is great. I think the brand of tire Diamondback uses is based on the size of tire you desire (not every size is available in every brand).
    Spooky, Deuces, slug and 1 other person like this.
  29. jimgoetz
    jimgoetz
    I didn't realize OP was asking about radials. My US Royals are bias ply.
    Moriarity likes this.
  30. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    First off... I couldnt agree more, anything other than Cooker is a good choice... Sorry if I offend anyone with this comment but the quality of the last 4 sets gotten through them were trash.... run out- vertical high spot and side to side also...
    CHEAP- get a set of BFG radial TA take them to a tire shop that will buff the lets off and go down to white underneath the black... Costs about 25 a tire to have the whitewall buffed in, not a perfect whitewall like a made one, but functional and safe, ran quite a few of these. ANy tire with a Raised white leter will work also just fyi...
    Not as cheap- DIAMONDBACK. But good quality, diamondback actually uses major manufactured tires and vulcanizes a whitewall into the tire. Works great and last long time for sure with no problems.
    CHEAPEST....... Port-O-walls... BUT **** quality and look like ****.....
    ebfabman likes this.
