Projects The Wagon Ford shoulda' built, so we did!
Discussion in 'The Hokey Ass Message Board' started by Rocket's Hot Rod Garage, Jan 29, 2020.
  1. You purchased the air cleaner from me. I am so impressed with your car.
    Glad the air cleaner went to such an impressive project.
    Maybe I should sent your money back---- maybe not.
    Ernie[/QUOTE]
    I thought I got a good deal on the air cleaner. I was looking for one for over a year so you came to the rescue by offering up yours. Thanks again!
  2. Beginning to figure out the back window. Again we where really lucky to have the wrecking yard close by so we could go out there, study original cars, how they functioned & then try to back yard engineer things.
    We had looked into possibly using some sort of donor qtr. windows early on in the build but nothing was quite right. We talked with a company about making new "acrylic" windows for the car. The nice thing about going this route is we where free on the design & could make things look the way we wanted. We had to make aluminum "plugs" for the quarter windows & back window. They use these to make the new "gl***".
    After shaping the new window plugs Mike constructed window frames to house the windows.
    We wanted the windows to have a divider to look stock rather than a modern street roddish one piece window. You can also see the new structure stuff primered red.
    brEad, drdave, ratrodrodder and 19 others like this.
  3. Filled the gas tank door. The filler is now behind the driver side tail light.
    Shop etc. Oct 14 281.JPG Shop etc. Oct 14 283.JPG wagon quarter frame bare.jpg
    lewk, brEad, drdave and 22 others like this.
  4. Now's a good time to show the rendering by @Jeem
    Note the custom tail lights, side trim & '56 rear bumper.
    BigO, brEad, 54delray and 33 others like this.
  5. K13
    K13
    Great stuff!
  6. Like we figured out earlier the roof started to curve about halfway through the door jam. After we straightened everything out it required modifying the B-pillar trim & "Terra"
    BigO, brEad, 54delray and 23 others like this.
  7. Johnboy34
    Johnboy34
    from Seattle,Wa
    Things that would take a long time to figure out by just looking at it.......
    Sent from my SM-G973U using The H.A.M.B. mobile app
  8. belair
    belair
    It's the little things...
    loudbang, Thor1, HunterYJ and 3 others like this.
  9. Squablow
    Squablow
    This is looking great! I have not seen the finished pictures yet but I look forward to following along in this thread and seeing them in the end. Some really masterful metalwork and also good use of junkyard/donor parts to keep it looking like a factory build.
    The guy who did the bumper looks like Cary Elwes from the Princess Bride.
  10. TFoch
    TFoch
    Nice work! Thanks for posting your progress.
  11. King ford
    King ford
    from 08302
    DAAAAMN nice work! Thanks for posting!
  12. By far the most challenging part of this build is all the customized & hand built stainless trim. Mike became a master at welding & finishing out the original stainless.
    As the renderings depict above we wanted to modify the side trim on the car. We used 4 "V" shaped door moldings cut in half & flipped to the other side to make one. The front fender trim is modified stock Ranch Wagon trim to flow into the new door molding.
    lucky, BigO, brEad and 25 others like this.
  13. Pretty much everything from the B-pillars back was either modified or custom made. We made our own dies for our Pullmax machine to form the trim above the drip rails from the B-pillar back. Also for the interior trim coming off the inside tiara molding, the molding above the back window & finally the molding on top of the quarters that extends from the B-pillars.
    Outback, BigO, brEad and 23 others like this.
  14. K13
    K13
    It's nice to have a cool build thread to look forward to seeing updates every day!
    loudbang, Squablow and guthriesmith like this.
  15. guthriesmith
    guthriesmith
    I knew there were a TON of modifications that went into this car, but I wouldn’t have figured out half of it without all that you are posting. And, I agree that I like following along in anticipation of what is next daily!
    Chief 64 and loudbang like this.
  16. Ace Spades
    Ace Spades
    Waiting to see more of this build. Y'alls craftsmanship and ingenuity is awesome. I'll wait to see the finished product once this build journey is finished.
  17. winduptoy
    winduptoy
    I saw this car in a fleeting moment on a different post...I am glad I found this thread before going back to look in depth.
    Thank you for taking the time to post all of this....'55, '56 Ranch Wagon has always been a favorite in my book. You cemented that as the case for sure.
    I am glad that you took to this project and I am sure the outcome is going to be stellar... Kudos to the team of craftsmen along with your vision. Carry on!
  18. lewk, BigO, brEad and 22 others like this.
  19. We made up a buck for the new tail gate skin. The crown need to change allot at the top by being flatter but stay the same at the bottom to match the tail pan.
    Next up was shaping a new gate skin on the hammer. I'm no expert metal shaper so I need to make it in 3 pieces due to my lack of skills.
    40two, BigO, brEad and 21 others like this.
  20. You can see how much flatter the new skin is compared to the original skin. The original car was really round & "bubbly"
    Next was t******* the skin & tipping the flange to fit to the structure.
    First test fit.
    Donor gate that'll sacrifice some of it's mechanical parts & the bump deal for the power window switch.
    Hamtown Al, BigO, brEad and 31 others like this.
  21. gatz
    gatz
    that sure is some nice work goin' on !!
  22. the term "lack of skills" does not belong anywhere near this thread
    you skillfully used the tools you have to create an impressive part
    eddie1, 54delray, Landmule and 13 others like this.
  23. okiedokie
    okiedokie
    from Ok
    Look forward to each new post, thanks.
  24. guthriesmith
    guthriesmith
    Yea...what Anthony said...no where in this thread should be the phrase "lack of skills". You likely make the rest of us (or maybe it is just me) feel like a hack...
  25. gonzo
    gonzo
    Wow, impressive work. Thanks for sharing.
  26. DDDenny
    That power tailgate window is neat as are all the other mods on the wagon.
    If I was closer to you I would have had you do the power rear window for my 66 Suburban that was planned, was more work than anticipated and the skills were not there either so that plan was s****ped.
  27. Baumi
    Baumi
    You´re ********ting us, right? Hahahahaaa
  28. I see crazy talented guys like Jimmy Hervatin & Josh Bulloch who make very large panels to perfection and am envious.
  29. ken bogren
    ken bogren
    What he said!
    loudbang, anthony myrick and Baumi like this.
  30. Baumi
    Baumi
    My experience is that the really skilled and knowledgeable guys like you are pretty humble folks. In my opinion the reason for this is, the higher your level knowledge and skills are, the more you know about your limits and what would be possible and within reach with a few more years of training and experience. Where a less skilled and experienced person can not see what would be possible , having less views and opportunities. Last time I met Gene Winfield 1 1/2 years ago he told me that " everyday´s a school day!" That´s the fun in it, right?
    Outback, 40two, brEad and 12 others like this.
