Projects Just Another Hemi Powered Model A Coupe Build
Discussion in 'The Hokey Ass Message Board' started by ClutchDumpinDan, Aug 1, 2019.
  1. Just Gary
    Just Gary
    Beautiful work, @ClutchDumpinDan . And sprayed in your own shop!:cool:
    Nice reflection of you in the headlight bucket too.;):rolleyes:
  2. Tall t 26
    Tall t 26
    Very nice work. Looking like a perfect hot rod. Detail work looks great, chop looks great. Looking forward to the end results!!!
    loudbang and ClutchDumpinDan like this.
  3. pila38
    pila38
    Wow! Beautiful work here. A lot of great ideas here as well.
  4. Dino 64
    Dino 64
    from Virginia
  5. Greg Rogers
    Greg Rogers
    I am envious of your skills- absolutely amazing work!!!
  6. loudbang
    Good recycling of the ammo cases. :)
  7. ClutchDumpinDan
    ClutchDumpinDan
    They work great for sandblasting and painting bolts and screws as well.
  8. ClutchDumpinDan
    ClutchDumpinDan
    Let it dry and took a look. Got some trash in a few parts that needs sanded out. A lot of it came out really good. Well within the acceptable range for being painted in a garage by someone that doesn’t know that they’re doing.
  9. Tim
    Tim
    from KCMO
  10. loudbang
  11. ClutchDumpinDan
    ClutchDumpinDan
    Final coat of primer on the frame...I hope. Paint as soon as it’s sanded and ready, can’t wait to see it done! Changed plans and frame is going to be body color now.
    Stogy, MP&C, kidcampbell71 and 8 others like this.
  12. ClutchDumpinDan
    ClutchDumpinDan
    Squirt squirt. It’s all downhill from here...
    Stogy, MP&C, akoutlaw and 13 others like this.
  13. ClutchDumpinDan
    ClutchDumpinDan
    Sanded and buffed. Need to get it in the sunlight and see what imperfections are too visible. Then a little polish and start to ***emble. Looking forward to seeing it off the rotisserie!
    Stogy, MP&C, kidcampbell71 and 13 others like this.
  14. Dino 64
    Dino 64
    from Virginia
  15. loudbang
    Nice and SHINY paint love it. :)
  16. ClutchDumpinDan
    ClutchDumpinDan
    Had a few spots that needed some more sanding once I got the light on it. P***enger side rail cut and buffed. Gonna look reallllll good after polishing. Hopefully start ch***is ***embly by the end of next week...maybe.
    Stogy, MP&C, kidcampbell71 and 10 others like this.
  17. ClutchDumpinDan
    ClutchDumpinDan
    Polished up, on stands and ready to ***emble. Can’t wait!
  18. ClutchDumpinDan
    ClutchDumpinDan
  19. ClutchDumpinDan
    ClutchDumpinDan
  20. 30tudor
    30tudor
    Good stuff all the way through, is that a Kiwi Konnection frame?
    ClutchDumpinDan and loudbang like this.
  21. ClutchDumpinDan
    ClutchDumpinDan
    Yep, pretty sure it is. That frames been floating around for 10-12 years now :eek:
    Stogy, MP&C, loudbang and 2 others like this.
  22. Dino 64
    Dino 64
    from Virginia
    Looks great, like the contrast of colors too. Those ladder bars have a different mount than I’ve seen before.
    Nice
  23. ClutchDumpinDan
    ClutchDumpinDan
    Tight squeeze but got the alternator in...
    Brake lines going in...
    Stogy, MP&C, Just Gary and 8 others like this.
  24. Dino 64
    Dino 64
    from Virginia
    Are the frame and body the same color ?
    What color is that ?
    Looks really nice
  25. ClutchDumpinDan
    ClutchDumpinDan
    Yes, frame and body are same color. Well they will be if the painter ever gets done. It’s Ford Leadfoot Gray. Newer color on the current Mustangs and F-150s.
  26. lothiandon1940
    lothiandon1940
    I'm loving that color............Don.
    ClutchDumpinDan and Dino 64 like this.
  27. Dino 64
    Dino 64
    from Virginia
    Yes ! I like it
    Oh, those problems with painters :rolleyes:
  28. ClutchDumpinDan
    ClutchDumpinDan
    Front brake lines done...
    Headlights and spreader bar in...
    Just waiting on the body at this point.
    Stogy, MP&C, sidevalve8ba and 7 others like this.
  29. AmishMike
    AmishMike
    Just noticed you are using clevis joint on rear suspension. What connection on front end of your bars? Do you have any experience doing it this way. Gathering parts for parallel 4 bar front suspension with coil overs planning on using clevis on 4 bars at axle connection & also on panhard bar & use heim joint at frame connection for panhard & 4 bars. How does that sound to you? Tks. Love your build
    ClutchDumpinDan likes this.
  30. Dino 64
    Dino 64
    from Virginia
