Technical Y block Ford build info
Discussion in 'The Hokey Ass Message Board' started by 46international, Jan 29, 2020.
  1. 12 pins between the marks. not rocket science. Its the blow by that I don't like. Every Y block I was ever around had excessive blow by. I would hook up a PCV. and rin a vacuum cleaner hose from the oil fill to the top of the air filter. so the carb could eat those oily crankcase fumes. And most of the Y blocks I was around had low oil pressure. possibly due to excessive internal leakage around the cam bearing.
  2. KenC
    KenC
    Haven't been a Y block in years, but still remember setting the marks horizontal and counting pins. I think a lot of guys counted links. Doesn't work.
    46international likes this.
  3. Truck64
    Truck64
    from Ioway
    Can count links, or count pins, what doesn't work, though is lining up the dots, the way so many other engines are done. Oops!
  4. sunbeam
    sunbeam
    Remember those pictures showing the timing gears the engine is right side up. Ive seen more than one put together with the engine on a stand with the pan up to keep the lifters in and the 12 links end up on the wrong side.
  5. 54vicky
    54vicky
    why the pan ? the cam holds the lifters not the pan it may be better stated that the picture showed engine on stand with pan up.nothing to do with the lifters.person viewing picture should realize the fact if not they should not be allowed near an engine ***embly.should add the gear on cam and gear on crank being a different size would have been another clue.(where the hell did common sense go)
  6. Oldmics
    Oldmics
    Another great source for Y Block parts is Vern Schumann
    Schumann's Sales & Service, Inc.
    P.O. Box 128
    Blue Gr***, Iowa 52726
    phone 563-381-2416
    He makes those cam bearings that are groved on the outside of the bearings so that alignment of the bearing exactly to the blocks oil hole is not an issue.
    Oldmics
  7. The engine don't need to have the pan up to keep Y block lifters in. When your installing a timing chain the cam had to be installed. No way are you gonna remove a lifter from a Y block when the cam is installed.
  8. Blue One
    Blue One
    from Alberta
    I used the valley pan from Mummert which is a baffled aluminum version of that factory steel pan.
    And then I ran my PCV like this factory diagram.
    jimmy six, egads and 46international like this.
  9. jaracer
    jaracer
    Rebuilt my Y block about 14 years ago and put everything back stock except for a mild cam I got from John Mummert. One of the things I did find that I hadn't seen before, is the cam journals had a lot of wear. It was running well, but the oil light would flash on at idle in hot weather. I found that the good running engine was slap worn out. I ended up replacing the block (sever cracks in the main webs), crank, pistons, cam and lifters, rockers and rocker shaft, valves, a couple of rods and most every wear item. I only thought it ran good before the rebuild.
    I think all the upper oiling problems came from sludged up engines with a lot of wear. I have had no problems with my engine which has maybe 20K miles since the rebuild.
    On the distributor, the one you have is the preferred one. The side pivot plate actually changes the dwell when it pivots.
  10. sunbeam
    sunbeam
    All I was saying the short block was upside down to put the cam in and they didn't turn the engine over to install the timing gears and chain had the br*** links. There instructions said line up the br*** links with the dots on the gears on the left side but the engine was right side up they were on the wrong side. Kind of like Y blocks heads gaskets say front not up.
    46international and Truck64 like this.
  11. Like the early SBC's you have to check the harmonic "balancer" for rotational shift. The rubber insulator breaks down and allows the outer ring to move.
  12. jimmy six
    jimmy six
    The Damper Doctor does a good job fixing that problem....two day turn around
  13. mgtstumpy
    mgtstumpy
    Some additional reading
    46international and egads like this.
  14. Is there a problem driving those bearings in with the grove cut in them? I guess it is not too deep but I guess it could collapse at the grove when driving it in. but thanks for the info.
  15. RB35 got me a valley pan with the baffle so I'm set on that item. Thanks for all the photos and help in that area.
    And thanks to RB35!
  16. Was that a 312 or a 292 motor? I have heard 292 blocks cracking like that are rare. But not rare enough, mine was a 292.
  17. Thanks for that, I printed it out can't wait to read it.
  18. How about valves? I have a set of good posted "G" heads but the guides are worn, I have seen some oversize valves but most likely will need a full set. Anyone know where I can buy them?
  19. ZAPPER68
    ZAPPER68
    from BC
    I actually laughed out loud when I read this...51 years ago (when I was 16) I 'freshened up' the Y block in my 56 F100. However, when installing the cam I had the engine upside down on a workbench. Not good as I discovered later! I did manage to get the engine to run but 1400 rpm is all she would do...much to my amazement, when I took it apart none of the valves were bent. I re-***embled it (right way up this time) and it started up and worked perfectly. :)
  20. sunbeam
    sunbeam
    Back in the day guys used chevy 348 valves they had bigger stems and let you ream the worn guides. But today 348 stuff might be harder to find than Yblock
  21. jaracer
    jaracer
    312 evidently they were more prone to cracking, but it's the same block, just the main journals are larger.
  22. Alaska Jim
    Alaska Jim
    Ernie, are you still racing your bird? I sold some of my land in Mineola, and am putting the house up for sale this spring. I will stop in to see you when I am down.----Jim
  23. thanks for the tip
  24. 73600ba5-c450-41bd-9fdd-9f06.jpg I was looking at the Y block forever site yesterday and found this. What is that silver sheet metal thing held on with that Phillips head screw/bolt? I have one block with a threaded hole where that bolt is but no bolt and one block with a short bolt in that hole but none with that sheet metal shield, is that to guide oil to the chain?
  25. Oldmics
    Oldmics
    As I recall , I believe that was some sort of guide/holding mechanism to ***ist in drilling the oil hole in the block.
    Ask Ted thru your private messages. I showed that mod to Bill Coleman that he preformed when he did one of my engines. Its from a Mercury Tech Bulletin
    Oldmics
  26. Slowshop&custom
    Slowshop&custom
    Aloha!
    I'm soaking up information like crazy here for a stock 272 that is going in the 1929 Tudor.
    Thanks guys!
    Truck64 likes this.
  27. 55blacktie
    55blacktie
    In the photo of the valley pan/cover posted by 46 International, I would say that the tube either attached to the air cleaner or to a valve-cover vent. Sometime during the life of my 55 Tbird, someone attached a pcv valve to the dress-up air cleaner. The hole was later covered, and a conversion kit was installed, running a hose from the pcv valve (attached to valley pan/cover) to the carburetor spacer. I ended up discarding the dress-up oil-bath air cleaner, fearing that the punctured air cleaner would result in the steel-wool-type element's disintegrating, resulting in particles being ****ed into the engine. Whoever ruined the air cleaner (hopefully not my dad), wasn't thinking. My Holley 4150 Street Avenger carburetor has a port to which the pcv hose can be attached.
  28. egads
    egads
  29. 6sally6
    6sally6
    Would love to see some pictures of the timing chain ***embly (with the dots that ain't suppose to be aligned up!)
    Count pins not links??? I'm corn-fused!
    6sally6
  30. Wanderlust
    Wanderlust
    I know eh, what’s the point of putting dots on if you’re not going to use them? Counting links, what kind a horse**** is that. Sounds like Henry got cheap and reused gears off of something else. As a former all Chevy guy, you do what you gotta do to make a Ford work.
