Technical Heat- or the lack of it - UPDATE
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jan 25, 2020.
  1. nochop
    nochop
    from norcal
  2. Cliff Ramsdell
    Cliff Ramsdell
    ^^^ Cool. My old Corvair had a Gas heater in it, worked better than the forced hot air.
    Cliff Ramsdell
  3. HOTRODPRIMER
    HOTRODPRIMER
    Today was the first opportunity I had the time to work on the sedan, I spent a few hours this afternoon trying different suggestions that was offered by you guys.
    I checked the thermostat and it seemed good but since I had it out I replaced it with a new one.
    I picked up a laser thermometer and found out the hoses from the water pump and the intake were between 164 & 188 when the engine was running and showing 165 on the gauge, on the inside after the water p***es through the electric cut off valve it was around 88 to 103.
    I still am not getting heat, I'm thinking I have a faulty valve, HRP
    Johnny Gee and dana barlow like this.
  4. Slopok
    Slopok
    Just by p*** the valve with a piece of pipe for now and see if that helps.
    dana barlow likes this.
  5. Lloyd's paint & glass
    Find you a ***y little ball valve to put in the line so you can close it during the summer :D The take the offending valve out, grasp it firmly, and throw it as far as you can!
  6. Texas57
    Texas57
    I'm confused again..........electric cut off valve? Do you have 2 or did you determine the one you had was electric? It may have been addressed, I don't particularly want to reread 5 pages again.
  7. gene-koning
    gene-koning
    I agree with Lloyd, I have a ball valve to shut off or turn on the heat on all my hot rods. The biggest issue with a ball valve is when you go for a cruise and the temp is around 45. You have to decide if you want heat or not, otherwise you have to stop, open the hood, and change the valve position. Gene
    norms30a likes this.
  8. patterg2003
    patterg2003
  9. OLDSMAN
    OLDSMAN
    HRP have you talked with the tech support people at vintage air. I would definitely give them a call.
  10. fergusonic
    fergusonic
    from Kokomo, In
    Just stick a chunk of cardboard in front of the radiator..... period correct.
  11. HOTRODPRIMER
    HOTRODPRIMER
    I will try to explain what is there and why I did it that way, Vintage Air supplied a electric heater control valve with the unit and it was installed correctly according to the instructions this is all done back during the dog days of summer, when we charged the air we got nothing but heat and I was leaving on the All Deuce Run the next weekend.
    I tried everything I could think of and the only solution I could come up with is go to the parts store and buy a inline valve to stop the water from entering the unit, All I knew was I didn't want heat when the temperatures were hovering in the 80's & 90's.
    That is the reason for the extra valve that yu see in the photo.
    The arrows on the Vintage Air valve are in the proper direction for water flow as is the extra valve.
    No sir, I wanted to try and see if the laser temperature gun would help in deciding my next course of action but calling the support line is my next step.
  12. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Good ole vintage air **** valve failure then... These things are a known issue for sure, not sealing up completely as you found before and now wont release.. Pull the electric one out byp*** it with a piece of pipe, just put a ball valve under the hood... Call it good... YOU WILL HAVE HEAT SIR... ANd be able to control it when you want to.
  13. prpmmp
    prpmmp
    Actually this is a Streetrod item,Go to a Streetrod forum and they will tell you how to fix it:eek:! Pete
    seb fontana likes this.
  14. HOTRODPRIMER
    HOTRODPRIMER
    Thank you so much for that insightful & invaluable bit of wisdom, you don't know how much I appreciate it.
    I might also suggest that in the future you restrict your post of **** girls to a **** site instead of on the hamb, just offering you some unsolicited advice since you felt the need to offer me some. HRP
    Moriarity
    SUPER MODERATOR
    from Mound, Mn USA
    If everyone must know. a **** was posted by @prpmmp
  15. Lloyd's paint & glass
  16. prpmmp
    prpmmp
    Hey Danny!! It was a joke!! Plus I never posted what you claim!! I was banned for being ignorant to Mark Moriaty!! I deserved it and we talked it out and I got a second chance! Sorry for my bad joke( I'll keep them to my self since I,m not part of your click) Have a good day! Pete I see you have edited you staement by Mark, I did not post a **** picture! I hope he can clear this up, Mark closed a thread for that reason and I went off on him!!
  17. HOTRODPRIMER
    HOTRODPRIMER
    I'm not mad, I just grabbed a pointy stick and jabbed at the bear. :D I got thick skin.
    BTW, what's a click? o_O HRP
    hotrodjack33 and prpmmp like this.
  18. Atwater Mike
    Atwater Mike
    Pete...That's clique, not 'click'. Glad you got a second chance.
    prpmmp likes this.
  19. OLDSMAN
    OLDSMAN
    Good job Danny, a lot of period correct cars have A/C on them. There’s nothing wrong with wanting creature comfort in our cars
    '49 Ford Coupe, nochop and Gman0046 like this.
  20. prpmmp
    prpmmp
    What Mike said!! Pete
  21. prpmmp
    prpmmp
    Thanks!!! Pete
  22. Gman0046
    Gman0046
    Danny, glad to be a member of your clique. Don't let an insignificant post get you down. As a fellow Southerner, I also see no need to be uncomfortable driving my cars. Mine always have Vintage Air and I've never had a heat issue.
  23. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Those who live in the south, know the definition of "Swamp ***"...
    Caution......
    Driving hours in swamp *** conditions leads to uncomfortable chaffing, sticky nuts, soaked drawers, no loving tonight syndrome, and has been known to cause stinky *** syndrome and slippery toilet seat injuries.
    Say all that real fast like those cure all pills on TV commercials and You should get a laugh if you know about this widespread heat effect.
  24. So you got a valve, it’s electric, and it gives you heat when you want AC . There’s now another foreign valve to stop the electric valve and now the car gives you no heat when you want it. Also the AC is too cold.
    Man you’re all messed up,,
    Sounds like your electric valve is working exactly backwards and the foreign valve is just confusing the issue.
  25. Lloyd's paint & glass
    I've had swamp ***, it's not pretty.
  26. Texas57
    Texas57
    Danny, the electric valve supplied by VA has a wiring "harness-connector" that has a ground wire.........white wire with a ring terminal. Is that connected/grounded?
    Vintage Air instructions **** big time. I had less trouble figuring out my 97 wire engine harness than I did the VA stuff.
    If you call VA, I'm thinking the first thing they'll tell you is to remove the added valve so they know what they're working with trying to troubleshoot.
  27. A 2 B
    A 2 B
    from SW Ontario
    The difference in temperature of the heater hoses can be detected easy enough with your bare hand. If one is warmer than the other, one of two things can cause this. Check for proper valve operation, electrically actuated or mechanical. There should only be one installed in the system. If neither gets hot you need to back track to the water pump. I have seen hoses that have deteriorated and cause an obstruction inside the hose without any outside appearing indication.
    Second thing could be an airlock but I'm doubtful of that if several thermal cycles have occurred. To find out, disconnect the return hose at the highest point possible to allow air to escape.
    As previously suggested, byp*** the valve/s with a piece of pipe. Its just a simple process of elimination. Good luck.
  28. typo41
    typo41
    And so it goes,,,
    Is this going to be 58 page 5 year build????
  29. hotrodjack33
    hotrodjack33
    Damn it all to hell...I'm a day late to this thread
    First I missed the Nudie post (love me some good ****):p
    Then I miss a great "swamp ***" conversation...which I'm sure I could have interjected some delightfully disgusting input:eek:
    Finally, I hear about this HRP clique, that as far as I know, I'm probably not a member of...:(
    norms30a and ekimneirbo like this.
  30. HOTRODPRIMER
    HOTRODPRIMER
    I didn't even know I had a click? but you can go here to join.:D
    BTW, make sure the sound is on. HRP
    hotrodjack33 likes this.
