Customs The Mild Custom Transformation, mama's 55
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Aug 23, 2018.
  1. Roothawg
    Roothawg
    That's what I was thinking....of course I had no idea what they used.
    loudbang and Moriarity like this.
  2. Chaz
    Chaz
    To my knowledge the stock skirts fit INSIDE the wheel well. not on top.
    loudbang, Moriarity and Chili Phil like this.
  3. Roothawg
    Roothawg
    Anyone know what the biggest tire I can get under the front with the Aerostar springs? I have to swap some tires around on my nephews truck. Trying to help him out. I have a 215-75-15 on there now. These are 225-75-15's. Not sure of they would rub or not. I would think .600" won't make that much difference.
  4. 48fordnut
    48fordnut
    the Merc taillight are the Best 55.6 ford modification that can be made. Just saying.
    winduptoy and loudbang like this.
  5. Roothawg
    Roothawg
    They are, but have you priced them lately? Crazy.
  6. Copper Top
    Copper Top
    I did a 55 Ford Crown Vic mild custom about 20 years ago and used 60 Dodge taillights, and a lot of years ago, I put 60 Buick tallights on a 56.
    loudbang and Roothawg like this.
  7. A friend of mine did 61 Ford full size in his. I think it took a bit of edge t*******. Here is what they look like stock and you can get them with or without the back up clear lens.
    Here is his version installed after a little work.
  8. Taboo56Chevy
    Taboo56Chevy
    yeah its insane how much they want for a set. The 60 Darts work and look good as well and a lot cheaper, I found a set at a swap meet recently for $20 but then needed probably a couple hundred dollars in plating.
  9. Taboo56Chevy
    Taboo56Chevy
    Ah Russ Meeks car, I think there is alot more metal work in the tail light area to get those 61 units to fit, that just some t*******. Looks like there is a lot more bulge on the inner fin area next to the trunk lid compared to a stock 55/56 ford.
    loudbang, chryslerfan55 and Sancho like this.
  10. You may be right. There's Custom then there's Kustom then there's the Russ Meeks way. No changes are a direct bolt up. Some just easier than others.
  11. Maybe I should have said Less involved.
  12. loveoftiki
    loveoftiki
    from Livonia,Mi
    I agree...way more than t*******...yes 60 Dodge taillights look good on those for sure
  13. manyolcars
    manyolcars
    wrong wheels but a beautiful car
    loudbang and razoo lew like this.
  14. Roothawg
    Roothawg
    I like the 60 Dodge lights as well. I just get confused on what all will interchange. Are all Dodge tail lights the same for the Polara etc? I saw one NOS the other day but it was kinda pricey and I wasn't 100% it would fit, so I p***ed.
  15. Gman0046
    Gman0046
    The Ford convertible has too much side trim, bad wheels and ugly tail lights. Just because fugly tail lights just happen to fit doesn't mean you should use them
  16. Gotgas
    Gotgas
    from DFW USA
    The tails in the photo I posted are from the smaller "Dart" bodied '60 Dodges, but there were larger Matador/Polara bodies which used a completely different tail light design.
    Believe me, it's confusing.
  17. loveoftiki
    loveoftiki
    from Livonia,Mi
  18. Gotgas
    Gotgas
    from DFW USA
    Those are '61 Dodge Dart. And they are the "dealer add on" tail lights that came about mid year as owners complained about how dim the stock lights were. Here is an example with, and without them.
    Not to be confused with the '61 Dodge Polara/Matador, which uses a completely different tail light. These old Mopars are a mess.
    1low52, loudbang, Copper Top and 2 others like this.
  19. Roothawg
    Roothawg
    I think that is relative to your likes/dislikes. I'm not a big Torque Thrust Wheel fan but I won't bash guys because they like them.
    My dad always told me that if you want to make a friend for life, brag on their car whether you like it or not. You want an enemy for life, tell him the opposite.
  20. My dad's saying was "don't measure other peoples likes or dislikes by your personal Yard Stick". Took me a while to sort that out.
  21. K13
    K13
    Just ignore him. He self admittedly doesn't like customs but has to go on every custom thread and bash. Must have a pretty sad life.
  22. Roothawg and loudbang like this.
  23. We used Galaxie lenses modified to fit into stock housings.
  24. Roothawg
    Roothawg
  25. 6sally6
    6sally6
    Nice look'in old 55!! Beyond clean (especially by east COAST standards!) I like the Crown Vic trim on all 55/56 Fords. Can you make that work on a post car?...Don't know.
    Ready to see a before and after on the ride height!!!
    6sally6
  26. Roothawg
    Roothawg
    The wife bought 55 Pontiac Star Chief trim for it. I still haven't done the rear end swap yet. I'm in the middle of a shop overhaul. Trying to get organized before I get back on it.
  27. oliver westlund
    oliver westlund
    i remember this thread! cool car!
  28. Roothawg
    Roothawg
    Just a quick update. The Okie Apache has gone home and freed up a bay in the shop, so mama’s 55 is back up on the front burner.
    I pulled the dash last night, getting it ready to strip and paint.
    C22C2FFE-E524-44BA-B74E-A3FBD49A2138.jpeg B5EF3570-9442-47CE-B120-004AE115EDF4.jpeg
  29. DIYGUY
    DIYGUY
    from West, TX
  30. sliceddeuce
    sliceddeuce
