Technical What guages are you guys using
Discussion in 'The Hokey Ass Message Board' started by sdluck, Feb 4, 2020.
  1. sdluck
    sdluck
    I am going to up date the gauges and need a speedo that will work with my quick change.What are you guys using
    dana barlow likes this.
  2. DDDenny
    Stewart Warner
  3. sdluck
    sdluck
    Thanks buddy
  4. partsdawg
    partsdawg
    from Minnesota
    Old Stewart Warner green lines.
  5. Happydaze
    Happydaze
    I suppose it depends on what you mean by 'work'. If work is taken to mean will be (kinda) accurate and remain that way following the QC gears being changed without the need for changing speedometer drives in the gearbox, or having some kind of adjustable mechanical conversion device (which may or may not exist), the answer must surely be an electronic speedometer with a gps sensor.
    That's what I have and why I have it in my as yet untested project. I couldn't fathom another way!
    Now, whether the gears will ever be changed is another matter, or indeed thread!
    Chris
  6. chevy57dude
    chevy57dude
    Though not traditional, X2 on the GPS speedo. Put one in 4x4 truck with oversized tires. Summit sourced, around $330 total: electronic gauge, chrome cup, and sensor. Dead nuts accurate.
  7. bobss396
    bobss396
    I have a 3-set of Summit 2 5/8" gauges in my Ford, they work well and look great at night.
  8. Chappy444
    Chappy444
    In the coup I have a flatty with a t5... and I am running a vintage SW 160mph mechanical speedo... I bought a set of driven gears for the T5 gear ratio and my current tire height. Did the calculation and picked the right gear and put it in... very simple.
    Another, very inexpensive option would be to download the Ulysee Speedometer app (I think its $0.99)
    I have a USB charger and a magnetic mount in my car as I use my phone for GPS and other things when I am traveling.
    This app works great has a bunch of features and did I mention its 99 cents
    Chappy
    Screenshot_20200205-074956_Ulysse Speedometer Pro.jpg Screenshot_20200205-075504_Ulysse Speedometer Pro.jpg
    catdad49 and jim snow like this.
  9. Elcohaulic
    Elcohaulic
    I like the Sun Green Line gauges the best. At night they are beautiful..
  10. ramblin dan
    ramblin dan
    I'm trying to collect old steward warner gauges when I go to swap meets and on line. I've had pretty good luck finding them in various places and good prices. I lucked out about a year ago when I went to a garage sale and came across an engine turned panel with a full set of these gauges from the sixties. I began talking to the guy selling them and found out his dad was a locally famous drag racer and car painter in the early days who had a 34 coupe and turned out I knew his dad from local car shows. Because I knew his dad and because of the car I was putting them in he sold me the whole panel full of gauges for five bucks. It was then I heard his dad had p***ed that winter. His dad was known for painting cars with lacquer paint while smoking cigars and had died of lung cancer.
  11. sdluck
    sdluck
  12. sdluck
    sdluck
    Anybody else?
  13. fastcar1953
    fastcar1953
  14. 32Dan
    32Dan
    from Chino, CA
  15. nochop
    nochop
    from norcal
    Black and white SW, bought at Napa about 15 years ago
    ekimneirbo likes this.
  16. fleetside66
    fleetside66
    aussie57wag, kadillackid and weemark like this.
  17. Tim
    Tim
    from KCMO
    With a quick change? I’d get an electric speedo that you like and use a gps sending unit. Then it’s always correct regaurdles of gear change
  18. Rocky
    Rocky
    Classified Editor
    I have a set of So Cal gauges in my coupe now but the curved lenses, red and white football and 200 MPH speedo kinda puts me off. I bought a brand new [discontinued] set of Cl***ic Mooneyes gauges...not the cheezy ones made by Mooneyes but real live American made Cl***ic units.... 34oilpressurecruise.jpg
  19. TimCT
    TimCT
    Another vote for the vintage green lines.
    uncleandy 65, -Brent- and Elcohaulic like this.
  20. 34Larry
    34Larry
    Ford Racing Black Face.[​IMG]
    By Auto Meter. Notice the "Ford" oval script in the Bezel. Tach also.
    Have no idea why pic didn't post.
  21. dana barlow
    dana barlow
    from Miami Fla.
    QC,? do you change the gear set from time too time or stay with same{ Ya I know QC is designed for using def gears}
    There is some 12 volt speed-o's that run off a magnet on drive shaft,so that type has to be set for a gear n tire set/same for standard rears. Model A speed-o ran off front hub from cable drive.>>>but stock "A" speed-o can be run of a newer ******( 1960s standard shift or auto with tailshaft cable drive to speed-o=that's how I have my own working in my 1928 "A"/I spliced a 57 Ford speedo cable to "A" speed-o an it came out only off by 2 mph. with my 3.0 rear and hot rod tires on my rod.
    Or you can just use the GPS in your phone now days for speed-o too.
    The guages I have used in the p***ed were what I could find free back then,best was out of 50s Studys{ SW} but have replace with new as broke. Even the 2 black rims,have once again been replaced by chrome rims now. This rod has been repaired more then just a few times,I first built it,in 1959. Kept the same look n color always.
    ekimneirbo, WalkerMD and hrm2k like this.
  22. fleetside66
    fleetside66
    Here are the original Moon gauges, made by U.S. Gauge for Dean Moon.
    kadillackid, Xman, verno30 and 4 others like this.
  23. Kiwi 4d
    Kiwi 4d
    @DDenny , good luck with your new stupid warner gauges, they look nice for sure . I have had two speedos go bad , they replaced the first one . I sent the second to an instrument spe******t and he said after 1500 miles it was just plain worn out junk . Well the speedo still reads but odo is not. I think several other HAMBers reported the same.
    Atwater Mike and ekimneirbo like this.
  24. Blue One
    Blue One
    from Alberta
    Cl***ic Instruments Hotrod series.
    The only way to go.
  25. 4speed411
    4speed411
  26. atomickustom
    atomickustom
    Is that a ribbed aluminum oil filter housing repurposed as an insulated cup holder? Genius!
  27. Black_Sheep
    Black_Sheep
    image.jpg SW Greenlines for fuel, volts, oil pressure and water temp. Speedhut built a custom GPS speedo and tach to match...
    kadillackid, brEad, hrm2k and 4 others like this.
  28. 392
    392
    Cl***ic. Good stuff.
  29. triumph 1
    triumph 1
    Early Stewart Warner
