Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. Matchless
    Matchless
    Interesting. I lined up both cars one day and took a look at the body moldings, openings, etc. Seems to me if you guys have seen variants then I guess I need to look harder. A Comet with a Falcon nose might look kinda cool......or really effed up, not certain which yet, lol.
  2. roundhouse
    roundhouse
    from GA
    Time to update the thread
    My 21 yr old son just bought this one
    So we will be on here asking questions
    It’s a little rough around the edges
    Missing a lot of interior trim
    And maybe some exterior trim too
    I’m not sure how much was removed
    Originally a V8 according to the VIN
    Currently has a 302 with a lumpy cam
    And a c4 I think
    Has AC that doesn’t quite blow cold enough
    Drivers window fell off the track driving it home
    Paint looks good in pics but terrible in person
    Lot of dings and stuff that didn’t get fixed before it got sprayed
  3. 62rebel
    62rebel
    Look at the Australian Falcon for what a Falcon looks like with Comet front dress. Very close.
  4. Matchless
    Matchless
    Roundhouse, nice car. If it's gonna be a daily driver I wouldn't worry too much about dings and dents - it's going to acquire more. Our Falcon was parked in it's usual spot in the barn when my Dad was rummaging in the joist's above.....dropped a little piece of 2X4 end first on the right front fender giving it a bruise. My Dad has since p***ed away and even if I re-did the entire car - I'd leave that little dent. Reminds me of him ( in a great way) everytime I see it.
    62Rebel ........you're right, it does sorta look that way, the Argetinian Falcons do too.. I'd really be interested in seeing what our Comet ragtop would look like with a Falcon front end. Anybody here any good with altering pics?
    coneman likes this.
  5. I did not look at each page but did scroll through most of it, I did not see much 6 cyl engine mod stuff. Has anyone done anything with the 200ci cylinder head? I'm looking for a way to mount two carbs. I have seen the mid '60's hotrod mag story on what they did but I don't think I would be able to braze a steel flange to the head to build an intake off of. Also I would like to come up with something better than the store bought "clamp on" adapters. I have a milling machine and lathe so I can make up some stuff, just need a workable plan. has anyone done this?
  6. Bigcheese327
    Bigcheese327
    The Schjeldahl book discusses direct-mounting a two-barrel carburetor to the log intake. I'm sure you could block off the original carburetor hole and use the same method to mount a pair of carbs instead. I prefer multiple carburetors on an inline as I think it balances the fuel-air charge, so it sounds like a solid plan to me.
    The big problem with the log intake is that the inside is pretty rough, which messes up fuel atomization, so if you're going to be opening it up, it might pay to try to smooth it out some.
    Some folks have band-sawed the intake off entirely and built something new from the intake ports out. That's well above my pay grade, but YMMV.
    46international and loudbang like this.
  7. Outback
    Outback
    from NE Vic, Oz
    Do a search for a '2V' 6cyl head that was available in Australia, these had a bolt on inlet manifold, they are also currently being reproduced & available.
    There is a local 63 falcon with a 2v 6cyl which does low 14 sec 1/4 mile times. (ed not low 13's but 14.2's)
    loudbang and 46international like this.
  8. rusty1
    rusty1
  9. DDDenny
    Rusty, you'll like this.
    That "not for sale" sign looks just like the one that appeared in front of a 55 two-ten two door after the third time I inquired if it might be for sale.:mad:
  10. 62rebel
    62rebel
    Tried to work out a deal for a 62 Tudor but the owner isn't selling.... yet.
    Thor1 likes this.
  11. Outback
    Outback
    from NE Vic, Oz
  12. RetroSpeed
    RetroSpeed
    Although I have owned three 1963 Rancheros, my '60 2-door wagon is my favorite Falcon.
  13. alanp561
    alanp561
    Did you try the Ford 6 forum? Lots of good information there.
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
    Thor1 and 46international like this.
  14. did not know there was one, thanks.
    I found the Ford Flathead 6 forum, not one for overhead valve 6's.
    Thor1 likes this.
  15. alanp561
    alanp561
    Sorry. It's not on the HAMB. Try fordsix.com. There's plenty of stuff for what you are looking for.
  16. mgtstumpy
    mgtstumpy
  17. scrap metal 48
    scrap metal 48
    Really cool^^^.....
    Deuces, Gammz and lothiandon1940 like this.
  18. Boulderdash
    Boulderdash
    New years thread bump, and a question.
    I have a 63 Falcon with a '66 Mustang 8" axle, albeit currently out of the car and in pieces (flange to flange is 50 13/16"). The existing steel wheels have 4" backspacing and 195/75 R14 tyres. I am tempted by some Cragar SS 14 x 6 rims, but they have a backspacing of 3 3/8" and 175/65 R14 tyres, and I fear they will scrub on the outer wheelarch lip. Any ideas if they'll fit?
    Obviously the shallower backspacing will put them further out, but then the narrower tyres (approx 3/8" either side) should help redress the balance somewhat. Would rather not cut the inner arch lip off, if I can help it.
  19. 62rebel
    62rebel
    Was the axle in the car when you got it, or was it something you found separately? Roundbody Falcons are notorious for being difficult to install a v8 capable rear axle into. You are probably going to have to modify (narrow and move spring pads) the Mustang axle to get it to fit at all. Nothing that is horribly involved, but labor and time nonetheless.
  20. Boulderdash
    Boulderdash
    It came with the '66 axle already fitted, so I already know it will fit with the 14" 4" backspace steelies.
    62rebel likes this.
  21. 62rebel
    62rebel
    That's a stroke of good luck right there.
  22. mcnally351
    mcnally351
    from boston
    Does any falcon guys know if the door hinges on a round body is the same through the years? They look similar on the 64. Even mustang hinges look the same and are available through macs. I’m looking for a drivers side 61 upper. Thanks!!
  23. 62rebel
    62rebel
    You need someone who has a hollander interchange manual to really answer your question. I imagine that they are very similar but I couldn't guarantee it.
    mcnally351 likes this.
  24. Nailhead A-V8
    Nailhead A-V8
    can't just replace the pins and bushings?
  25. Nailhead A-V8
    Nailhead A-V8
    8" - '72-'77 Maverick/Comet bolt in with '66 Mustang spring plates, Mav/Com 4dr. driveshaft also bolt in
    9" - 1957 Ford
  26. 62rebel
    62rebel
    Not picking but those donors are more rare than the Falcon now
    Nailhead A-V8 and Gammz like this.
  27. loveoftiki
    loveoftiki
    from Livonia,Mi
    What kind of HP are you throwing at an 8” rear end.
  28. loveoftiki
    loveoftiki
    from Livonia,Mi
    Don’t think I ever put mine on here...wanted a hot little street car...289, 11:1, TW Heads1, Eddy Performer RPM intake, custom ground comp cam.. built C4, 2500 Stall converter.....and a Maverick 8”
    Front ends all Opentracker from the master out.. DC49B1A2-34DF-401B-981C-F8274A54AF8C.jpeg E3A54466-9C42-447E-96B2-752B752FF044.jpeg 8AA65B8E-5BDE-43C1-8710-79F02BB1981E.jpeg 516CB324-8674-4181-84F7-1E49474E368A.jpeg
  29. mcnally351
    mcnally351
    from boston
    That’s a good idea thanks
  30. mcnally351
    mcnally351
    from boston
    I was backing up the car with the door open and wrecked the door on my wood pile and broke the hinge. I have since welded the hinge back together and found a door but hoping to find another hinge
