Projects The Wagon Ford shoulda' built, so we did!
Discussion in 'The Hokey Ass Message Board' started by Rocket's Hot Rod Garage, Jan 29, 2020.
  1. K13
    K13
    Jimmy's a freak. That is a HIGH bar to set.
    drdave and loudbang like this.
  2. troybert
    troybert
    from muncie in.
    Watching threads like this is shared knowledge, it amazing of the skills out there and the ones that are willing to share I truly appreciate, thanks Troy
  3. theman440
    theman440
    from Las Vegas
    Dig those exhaust cut outs!
  4. nor6304
    nor6304
    from Indiana
    really enjoy the build Thank you
  5. David Gersic
    David Gersic
    from DeKalb, IL
    “...lack of skills.”
    Right. Pull the other one, it’s got bells on it.
    chryslerfan55, loudbang and 31Apickup like this.
  6. I tell students the difference between good and great is knowing how to fix or work yourself out of a mistake or difficult situation.
    A poor technician doesn’t care about mistakes unless it affects a pay check.
    Knowing your limitations doesn’t imply “lack of skill” It means you understand how to get the desired result with what you have.
    Lots of 6 and 7 figure high end cars were built by guys wrestling sheets of aluminum over various stumps using multiple pieces to form a panel.
    We do appreciate the humility or politeness extended to us guys on the sidelines watching this amazing build. .
  7. Peanut 1959
    Peanut 1959
    Just stumbled on this build summary today, and I can't wait to see how it turns out! I haven't seen the final product yet, and I'm thoroughly enjoying the tease. [emoji12]
  8. Early on we knew we needed to re-make the tops of the quarters to work with the Crown Vic style trim & accept the new quarter windows. IMG_3568.JPG IMG_3545.JPG
    brEad, drdave, chryslerfan55 and 18 others like this.
  9. We didn't like the stock tail lights. @Jeem suggested using modified Galaxie lenses & backup housings. IMG_3299.JPG
    Outback, 40two, BigO and 17 others like this.
  10. The absolute hardest thing that needed done for this build is the custom trim that extends from the B-pillar all the way back to the tail fins that needed fabricated. Mike spent allot of time building the dies & welding all the pieces together to make it happen.
    12378122_522780374570313_110715177987074757_o.jpg 1421265_522780834570267_1343608164628229867_o.jpg 10557548_522781037903580_4870299184675422745_o.jpg 921401_522780911236926_1932301442240432823_o.jpg
    Test run to make the final product.
    63fdsnr, BigO, brEad and 21 others like this.
  11. We found out early on working with the stainless the best way to tackle welding it & blending 2 different part together is to use original Ford trim & cut strips to use as fill rod.
    We went to the wrecking yard again & found some nice flat rocker trim pieces from a Lincoln to re-purpose.
    After working out any small flaws on the Lincoln trim we formed it on the brake before running it through the Pullmax to give it the final profile.
    BigO, 54delray, drdave and 22 others like this.
  12. Johnboy34
    Johnboy34
    from Seattle,Wa
  13. Welding the trim together is a delicate deal.
    We re-used the stock Vic trim to finish out the ends above the tail lights. It involved adding along the bottom to match the new trim.
    IMG_4204.jpg IMG_4206.jpg 28514837_895307137317633_5542372096732245171_o.jpg
    Then comes the extremely tedious task of metal finishing the welds.
    lewk, Jim the Sweep, 63fdsnr and 27 others like this.
  14. Tim
    Tim
    from KCMO
    Holy cow
    Boryca, Baumi, loudbang and 3 others like this.
  15. K13
    K13
    Wow that trim must have taken forever to fabricate.
  16. Mart
    Mart
    Excellent stuff. Custom made stainless trim is just taking it to a new level. You left me behind with the regular custom fabrication, but working with stainless.. well, wow.
    Landmule, Okie Pete, loudbang and 2 others like this.
  17. guthriesmith
    guthriesmith
  18. A few years ago I took a TIG refresher cl*** and had a chance to do some stainless welding. It was a pleasure to work with. Unfortunately I never had further occasion to do any stainless and have since sold the machine...but I’m thinking about buying a smaller unit. I don’t think I’m up to what your guys did though.
  19. Mr48chev
    Whoo Hoo, I was hoping you would do a build thread. Thanks for sharing.
  20. wvenfield
    wvenfield
    I love wagons and this one is killer. Congrats.
  21. chevy57dude
    chevy57dude
    What an amazing build!
  22. TFoch
    TFoch
    Excellent craftsmanship!
  23. 69supercj
    69supercj
    Geeze Loueeze, absolutely amazing talent and craftsmanship!!
  24. jimmy six
    jimmy six
    Appears to be 1956 Fairlane rear bumper ends. Not used on wagons in 1956. Hoping he will tell us if he modified the rear bumper like he did the front. Removing the flat license plate flat section was awesome.
  25. fordflambe
    fordflambe
    Very nice work. Thanks for sharing.
  26. X-cpe
    X-cpe
    Also being able to anticipate and prevent them.
  27. Crayons
    Crayons
    Kudos to your welder. ..nice small welds (low bead height ), makes finishing so much easier. Good work.
  28. The 39 guy
    The 39 guy
    I was impressed with your teams talents in metal fab and then you did the stainless....... I have refurbished enough stainless trim to realize how much skill and patience it must take to weld it then metal finish and get the results you did. I tip my dust old hat to you guys.
  29. Yes, Mike is the man!
    drdave, Squablow and loudbang like this.
  30. vilanar
    vilanar
    from Finland
    Wow,just wow! Thank you again for sharing this build thread. Doing/modifying the trim is amazing.
    Mike is one hell of a welder/finisher. You have a great team !
    Keep the pics coming , there is never too many build pics.
    Thanks
