Projects 1933 Plymouth Sedan: Should I Fix It?
Discussion in 'Traditional Hot Rods' started by OneRustedDodge, Feb 8, 2020.
  1. OneRustedDodge
    OneRustedDodge
    Hello HAMBers,
    I am finally getting around to sorting out HOW i am going to get a hot rod together after all these years and have been saving this 33 Plymouth Sedan. This car is ROUGH and most replacement panels for the early mopars are not available. I've considered morphing the car with Ford replacement panels from the same years, but i am not sure. I have been building and fabricating for 13 years and I want real world perspective on best way to accomplish repairing this one.
    It needs:
    Floors
    Rockers
    Door bottoms
    Cowl Patches
    Front window channel
    Plans are for it to be fenderless. Doesn't need to be anywhere near "show quality".
    Screen Shot 2020-02-08 at 7.36.48 PM.png Screen Shot 2020-02-08 at 7.36.55 PM.png Screen Shot 2020-02-08 at 7.37.06 PM.png Screen Shot 2020-02-08 at 7.37.18 PM.png Screen Shot 2020-02-08 at 7.37.25 PM.png
  2. ROBRAM
    ROBRAM
    I've seen a lot worse. I'd tackle it, if it were mine.
    loudbang and sloppy jalopies like this.
  3. s55mercury66
    s55mercury66
    from SW Wyoming
    I would fab all of the needed panels for that, if it were mine. It will take a lot of work, no doubt, but that is what I would do. There is some good info to be found on here, and elsewhere, on shaping panels and repairing door frames, it can be done. One bite at a time, and you may spit some of those bites out and start over, but it can be done.
  4. stanlow69
    stanlow69
  5. sloppy jalopies
    sloppy jalopies
    do it... the mopar floors will be relatively flat, compared with '33-'34 fords...
    a competent metal brake guy should make the rockers and sills...
    a little shrinking should put the desired L -R bow in them...
    find a clever guy with a bead roller and an English wheel to make the patch panels... compound curved with flat beads across the bottom...
    maybe bent conduit arch to form an edge from the skin to the wheelwell … not correct radius but doable at home... don't be afraid... most of us have cut out what we have done and started over... a few times...
  6. lippy
    lippy
    from Ks
    Would make a cool hotrod. Just depends on how much YOU like it. If you have the vision, you can do it. It has nice lines. Lippy
  7. chev34ute
    chev34ute
    It looks pretty straight foreword. It all comes down to the patterns you make. Get some magnets and craft sheet sized cardboard, place the cardboard over the damaged areas fasten with magnets and cut out to the desired shape. Place the patterns over the sheet metal and cut out oversize.
    This is what I made up recently. 0236675E-81EB-484C-9F38-81B8E39E11CD.jpeg A5FA262E-C1D1-4EBF-B2AD-1B10BC0F6631.jpeg
  8. scotts52
    scotts52
    Save it? Heck ya!!! 33/34 Dodges and Plymouths are awesome.
  9. v8flat44
    v8flat44
    You bet. How many do ya see? Dare to be different.....i picture a 273 or 340 Cuda mill.......just say'n.
  10. Gasser 57
    Gasser 57
    from New Jersey
    Great looking body style. Sure would be cool if you could save it!
  11. RMR&C
    RMR&C
    from NW Montana
    Worth saving for sure.....they are really cool cars. But then I'm biased.
    It's easy for us to say"fix/build it", it would be a huge amount of work/$$ for sure.
    Since it has no floors, it's a great time to channel it a bit!:D I made patch panels for both sides on mine, but it wasn't quite as far gone as yours.
    dwollam and chryslerfan55 like this.
  12. gene-koning
    gene-koning
    Is this where we say "its junk, it will never be worth anything, so send it to me and I will get rid of it for you?":D
    I suppose your vision of the finished product will have a huge bearing on how you build the car. If it needs to be perfect, or close to it, you need to find someone that can create the new panels the body needs, anything less then a perfect replacement part won't do, and you certainly wouldn't want to use Ford parts on your Mopar. If you are looking for an imperfect fun to drive hot rod you built yourself, most of the panels you need can be made at home if your willing to learn how. Personally, I make my own panels, but I'm OK with imperfections. Gene
    Illustrious Hector likes this.
  13. touring20
    touring20
    I would use ford patches , the bottom of these Body's look like they were ground off .
    When built as a high boy or channeled
    Had a 34 dodge PU , and ultimately that is why I sold it .
  14. Toqwik
    Toqwik
    I would decide is this a car you are going to keep a long time or one you are ready to sell once finished. If you plan to sell it, cut your losses now and p*** it on. If this is something you can see as a member of the family, heck yea build it. Doesn’t look that bad and you will be surprised the power of the HAMB to help. It’s a lot of work, just make sure it is what YOU want before diving head first.
    RMR&C likes this.
  15. never2L8
    never2L8
    l
    Do you still have the parts car or do you know where one is
    what did you end up doing with your Plymouth sedan project
  16. Crookshanks
    Crookshanks
    We have a handful of extra parts saved from our 33 Chrysler projects. Shoot me a list of what you are looking for. Some stuff may interchange.
    scotts52 likes this.
  17. Anything with suicide doors is worth saving. Just saying.
  18. never2L8
    never2L8
    I was looking for a body of four a 33 Plymouth sedan
