Inside the Thermador Swamp Cooler REVEALED !
Discussion in 'The Hokey Ass Message Board' started by Chopperman, Feb 24, 2012.
  1. manyolcars
    manyolcars
    I used one across Texas and into Ok City. It didnt help at all and chipped the edge of my window glass
  2. NEWFISHER
    NEWFISHER
    from Oregon
    I couldn't wait until the weekend, reading the thread got me motivated on my lunch hour.
    no leaks
    kidcampbell71 and Okie Pete like this.
  3. rjason
    rjason
    Just about spewed my coffee on the keyboard when I watched the youtube vid of the hamster!!
  4. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    there is nothing to them... anyone can restore them with a little time.. did one a yr ago and guy is still using it to today... yeah in humid climates they are pointless pretty much... only way I got some use out of it was putting ice cold water and ice inside and pulling the rope quite frequently... haha.....
  5. Mr48chev
    I think it's the same thing they use in swamp coolers for houses and I think you can buy pieces of that at hardware stores or Lowes or Home depot.
    It looks like they have synthetic replacement padding for those now too that might be easier to deal with.
  6. Piston Farmer
    Piston Farmer
    I know an old topic, but how are you guys Re-sealing these after you open them up? I had to disassemble mine to pop out some dents.
  7. 29AVEE8
    29AVEE8
    I am old enough to remember riding in my dads '53 mainline Tudor down the San Juaquin valley in mid summer with one of those. In low humidity they work great. I have a large evaporative cooler in the window of my garage. It was 106 on my patio today and my garage was 79. The concept is sound, but high humidity makes them worthless. Pretty much an arid southwest device.
  8. 60galaxieJJ
    60galaxieJJ
    awesome thanks for the info
  9. The internal end rear cap was originally sealed with tar . If you do need to take the internal end cap off.... you will need to cut through the tar to get it off. You can use simple plastic roofing tar to seal it back up.
  10. mike in tucson
    mike in tucson
    from Tucson
    The stuff inside is excelsior like the other poster said....essentially wood shavings. The excelsior holds the water in the air path. Spinning the tube every so often keeps the excelsior wet....it doesnt have to spin all the time. You can buy the excelsior mats where ever swamp coolers are sold....Home Depots in Arizona even carry the excelsior. If the water is not distilled, evaporating tap water will leave the white mineral deposit.....on a home swamp cooler, the excelsior pads are changed yearly for best performance. Some newer design roof top coolers use a honeycomb paper instead of excelsior to hold the water. Auto coolers OR home coolers work the same (1) keep pad wet (2) move air over pad. In the old days, people in Arizona slept in their front yards and draped a wet sheet over their cot using a clothes line to hold the sheet in a tent shape. This was the forerunner of the swamp cooler. Now you know too much about them. We have a mist system on our back porch using a 3000 psi pump that pumps 1 gal/min thru fog nozzles. When the outside temp is 105, the porch is maybe 90 deg. Low humidity is the key for this stuff to work.....try the auto cooler in Florida and you only get wetter.
  11. Sure does............until it melts, 20 miles from home, and you are left with nothing but water. I suppose you could pack a cooler full of ice and re ice it, but trust me, no one did.
    belair likes this.
  12. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Friends of ours got to packing theirs with ice, then they decided dry ice was the route... a few miles down the road they pulled over to empty the dry ice out, as it was TOO cold!
  13. They were too "cold" because they were being suffocated LOL.
    The smoke you see coming off of dry ice is just water condensation. The dry ice itself, though, is solid carbon dioxide. If you're in a closed room with it for long enough, you can start to suffer from carbon dioxide poisoning.
    05snopro440 and belair like this.
  14. As usual- listen to Mother boys and girls, that is correct. I have a salesperson that tried to deliver product packed in a quantity of dry ice. He nearly didn't make the trip.
    Otherwise, swamp coolers or "evaporative coolers" work quite well here in the high desert and other low humidity areas. There is a limit though and seems to me it only is able to cool about 20 or 25 degrees max. When its a hundred, you're lucky to bring it down to 80, but 80 is better than a 100 right?
    Posted from my office while pretending to work!
  15. Ron42Dodge
    Ron42Dodge
    from Omaha
    Great pictures and information. I read on one site the mat material was balsa wood fibers. Is that what you found?
    I found what I believe might be a 1st series Thermador Cooler. The unit rests on top of the window and has tabs that insert into the upper track. There appears to have been pads between the unit and the face of the glass. I cannot make out what the decal used to have for a name of this unit. Does anyone know?
    The problem with this design is the unit blocks most of the view out of the window. There are no provisions for braces or brackets.
    I've seen a similar unit that is almost identical except the fill cap was relocated so the unit could be flipped and not block you view as much. I believe those also came with a brace.
    I think they went away from these models as flat glass went away and sloped windshields came in. My unit barely fits in my 4 door front window.
    If anyone knows more on these units I would appreciate the info.
    I found one post that had a picture of one from a November 1940 article.
    51 mercules and kidcampbell71 like this.
  16. Ron42Dodge
    Ron42Dodge
    from Omaha
    I found a past auction where one just like mine was sold. That seller was nice enough to send a picture of the front and back labels from his first series KOOLAIR.
    What is interesting is the patent number on the first series, 2,142,895, is dated Jan. 3, 1939 but the actual patent is for a pasteboard (cardboard) corrugated stock box. It had an "L" shape slot on the front for air to enter. It hung off the top of the window. Dry ice was the intended coolant. This would have been the predecessor to the first series KOOLAIR.
    The second series KOOLAIR was essentially flipped upside down so it did not block the view out the window as much. The patent number for that one is 2,230,020 which has a diagram of the first series unit. This Patent is dated Jan. 28, 1941. These used water and the mystery material that was in between the mesh was described as "a loose filler such as Excelsior or the like."
    51 mercules likes this.
  17. The 39 guy
    The 39 guy
    Thanks for the info Ron42Dodge! To bad I didn't buy one of theses things back when no one was interested in them.I live in a dry climate area so I think I could actually see some benifit from useing one them.
  18. ccarnut
    ccarnut
    from hays, ks
    is there a company out there that makes replicas or sales parts for them. just wondering
  19. Okie Pete
    Okie Pete
    Thanks for the pics and info. I just pulled one out of a ditch on a pasture we rented .
  20. D.Lee
    D.Lee
    from Czexas
    Can anyone clue me in on how to preload the spring for the wheel?
  21. wraymen
    wraymen
    Try looking up lawn mower pull starts. Might give you some ideas.
    Frank02L likes this.
  22. 1960vwguy
    1960vwguy
    Great Article! I used it to crack open my thermador and start cleaning it out. I'm hoping someone here has an extra air screen piece I circled in this image (not my photo). Mine is missing. I'm happy to pay for it.
  23. Terrible80
    Terrible80
    You have to have some flow for these to work, opposite rear window barely cracked open lets hot air out as cool air fills passenger compartment.
    firstinsteele and 1960vwguy like this.
  24. 5But do ya go one of theses. Sear Car cooler, same age. 12 hi/lo blower. uber rare. (wish I could find a manual) still new in box (cept shortened cord.) swamp1.jpg swamp2.jpg swamp6.jpg swamp6.jpg swamp12.jpg swamp13.jpg
    martin53 and kadillackid like this.
  25. Jonneeb
    Jonneeb
  26. Nacifan
    Nacifan
    There is a fellow hambr that builds exact steel repo- "Themadoer Car Coolers". Die stamped ends, lower supports, front screens and more. Mot cheap but cheaper than buying a rusted out one for $200 buks and paying someone to restore it... The green coolers were at the Long beach swap meet in Nov.19 for over $500. There i 2019 California 319.JPG Swamp Coolr End Screens 1 .JPG Swamp Coolr Our Parts 1 .JPG 2019 California 319.JPG Swamp Coolr End Screens 1 .JPG Swamp Coolr Our Parts 1 .JPG Swamp Coolr OG our end and Duct 2 .JPG s an ad on Craigslist Northern Virginia
    cajunfirehawk and kidcampbell71 like this.
  27. Aldo Hernandez
    Aldo Hernandez
    Hi I see you make awesome repops!!! How much for a report back cover? I lost mine.
  28. Aldo Hernandez
    Aldo Hernandez
    I see you make awesome repops!! How much for a repo back cover? I lost mine.
  29. pprather
    pprather
  30. 23crate
    23crate
    from nz
    try this guy ..
    https://www.ecophagefabrication.com/
