Projects Flathead going in a 34
Discussion in 'Traditional Hot Rods' started by 19cafmwb34, Jan 11, 2020.
  1. 33Doll
    33Doll
    That’s What I say!
    It’s always fun to tease though!
    Its all fun and games!
    Hell I love my Toyota 4.7 V8 so much, I thought why no one has tried that yet, Its Kind of a Hemi! Stick it in a F-1 or F-100! Oh- No I’m gonna get black balled now! Ha!Ha!
  2. 33Doll,
    Which heads you going with ,,,,,Offy,,,,or 8BA ?
    Tommy
  3. 33Doll
    33Doll
    The iron heads. The engine was rebuilt already when we got it, ran great In IMG_5654.JPG Adjustments.JPG IMG_5538.JPG Adjustments.JPG the 40 chassis he bought, but my Pops tore the bottom end to inspect it anyway.
    Painted all, souped it up, and didn’t want to deal with braking in new heads.
    dwollam and Desoto291Hemi like this.
  4. Outstanding,,,,,I plan on using my iron heads as well,,,8CM,,,I assume they are identical to the 8BA .
    Your engine is a beauty !
    I was gonna use aluminum,,,but since the ones I have are perfect,,,,I figured,,,why not,,,save about 800 dollars as well.
    I’m planning on using a 4 barrel intake as well ,like yours.
    Tommy
    33Doll likes this.
  5. 19cafmwb34
    19cafmwb34
    Last time I checked that’s what is about this is about Fun &Games since they kept pulling me over when it was about boobs & beers
    dwollam and 33Doll like this.
  6. 19cafmwb34
    19cafmwb34
    Still looking for a firewall to sit real nice behind the flatty. This is a shot form a couple of weeks ago
    waxhead, dwollam, Fairlane500 and 3 others like this.
  7. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Think I just saw a new in the box firewall in the classified section....
  8. El Gato
    El Gato
    Putting a Flathead in anything with your Dad is the best reward. Good job and keep the project moving.
    Our 59A, bored 1/8 with Merc 4" crank, Potvin cam, ported, relieved, Sharp head and 3 X 2 Sharp intake.
    Cheers
  9. 19cafmwb34
    19cafmwb34
    Got some work done so here is an update.I decided not to replace the original firewall $$$. Covering it again with a three piece set with some help from good friend ,he owns a shop with 25+ working, they fabricat a lot of crap for “artists” in NYC. The two seems will be covered with stainless hood trim from a 56 Pontiac. I am going to get them lined up with the heads so it will look like the lines on the head will continue up the fire wall-if it all works out.Also going to get some new master cylinders.Best I can think of is to get the brake and clutch lines inside the car and have the come out up near the master cylinders.Trying to stay in some kind of budget .Going to do the final measurements today put them on to the cardboard and plywood profile and head down to pick out what type metal and finish to use. 4805C93E-6704-40D8-981E-6B674D8D6374.jpeg 2F67368F-FD7D-4969-B2F9-9533934341F0.png 15C86984-9451-4A52-BE02-8BE533F43EF3.jpeg 97278045-76DC-454E-A240-B416E386B319.jpeg 204DB3EA-6E23-453E-8947-9A4884CB81BB.jpeg 0964041C-6242-4646-BE41-D0BB93C13877.jpeg
    dwollam, Jeff34 and Fairlane500 like this.
  10. 19cafmwb34
    19cafmwb34
    Thanks but decided to go without it
  11. 19cafmwb34
    19cafmwb34
    16F78D53-6D35-49CB-89A0-7EA48DABAD18.jpeg E0BDD4F7-1951-4F26-9929-6830623D556F.jpeg
    Sounds like a nice build on your mill!Trying to keep costs down I having it built with the stock crank and put some money into a new 3/4 cam.I chose this shop in Westhampton Lawrence Race Engine for two reasons he built a flathead last year with a Tom Roberts blower kit last year and he will break properly it in and it will have a Dyno sheet.
  12. thirtytwo
    thirtytwo
    Why don’t you just fill in the little piece that’s been cut out?
  13. Bandit Billy
    Bandit Billy
    I have a trigger word alert set in my profile for key words pertaining to "boobs and alcohol", Let me say I was disappointed with your post and lack of photos. :cool:
    On topic, nice work on the 34, please keep posting.
  14. speedshifter
    speedshifter
    Do you think old Henry would approve of the flatheads with Delco altternators? Greg
  15. alchemy
    alchemy
    Why cover up the nice original firewall? Just patch the small cut out area. The money's in the Henry Ford stuff.
    dwollam and oliver westlund like this.
  16. So-cal Tex
    So-cal Tex
    X2 Looks like an easy job to just repair the area around the middle with a donor from a '35 truck or have a good sheet metal guy make the patch, the original beads and shape is just beautiful on '33-'34 Fords.
    oliver westlund likes this.
  17. 19cafmwb34
    19cafmwb34
    Trying to be nice, the last one looked like it was put in in a hurry.It was put in in one piece so all the way around the top and down the sides on the “shelf”it was between 3/8” to 1/2+” shy I could go on but i think you get the idea.
  18. 19cafmwb34
    19cafmwb34
    I thought about that, got a few replies on the want adds for one here but 500 for a complete wall with as many small holes as mine has was a little more than I wanted to spend on a patch. I thinking now to use some aluminum I have give it a brush look it and put it in in three pieces.I will try and get the seems on center with the heads and use some 56 Pontiac Chieftian hood strips, they are ribed paint them to match the head color and rub off them off leaving the ribs to match the fins on the aluminum heads. Going to try that if it really looks like crap I might go the $500 patch route.
  19. Stephen Barrett
    Stephen Barrett
    Best thing you ever could've done is loosing the Chevy. "Flatheads Forever" :cool:
  20. thirtytwo
    thirtytwo
    sorry but I don’t, the rest of the firewall looks fine except the center looks like an easy fix to me , I don’t understand doing the whole firewall because of that little section
    Stephen Barrett likes this.
  21. I'd work on the firewall you have; it goes well with your plans of flathead replacement. Back to traditional hot rod.
  22. Jacksmith
    Jacksmith
    from Aridzona
    Ha! The fire-wall looks better already! That flat head will do just fine in that car! Out with the street rod, in with the Hot Rod! Excellent decision!
  23. clo
    clo
    612468BC-EB25-47AD-9F6B-AD7AB9675123.jpeg 612468BC-EB25-47AD-9F6B-AD7AB9675123.jpeg I have a nice original firewall for that car.
  24. Jacksmith
    Jacksmith
    from Aridzona
    Wow... game changer!
  25. 19cafmwb34
    19cafmwb34
    After reading some the posts here I gave it some thought and called up a old friend who is good with sheet metal and we kept coming back to what alchemy, algoma56 and a few other suggestions here and work with what Henry gave us.Clo I will send you a message about your firewall in the post above, I would like to use it. For now it’s back to my favorite electric wiring for this swap!
    34 5W Paul, slv63 and alchemy like this.
  26. low down A
    low down A
    i think what them chevy guys are trying to tell you is How can this be done when there are no pete and jake instructions in the box. you would be so far ahead by using that firewall clo is offering.
  27. Jacksmith
    Jacksmith
    from Aridzona
    Ouch... burrrn!
  28. 19cafmwb34
    19cafmwb34
    Thanks I am listening I sent him a message.
  29. thirtytwo
    thirtytwo
    why would a guy waste a whole nother firewall when the only little spot to repair is mostly flat ?, honestly if a person can’t repair what’s there, putting in a whole new one is going to be above their head and marginal results would probably be had
  30. 421-6Speed
    421-6Speed
    I agree fix the firewall you have and use original pedals. I have a super nice set of pedals and a master cylinder bracket that goes with the original pedals if interested.
