Projects This Roadster followed me home...
Discussion in 'Traditional Hot Rods' started by JunkCarJesus, Jan 27, 2020.
  1. Colonial Coupe
    Colonial Coupe
    Put a few gallons of gas in the tank. Hook up a hose to the fuel line and watch how the gas flows out, if it's not peeing a good stream the fuel shutoff valve has **** in it. I had this problem once same results that you're having. Pull the valve and get the crud out of it and the tank. Snyders and others sell a mesh filter that goes into the valve before you put it back into the tank. They also sell a replacement gl*** bowl that they sell a filter for. All good investments that will save you headaches down the road.
    loudbang and JunkCarJesus like this.
  2. JunkCarJesus
    JunkCarJesus
    It definitely has a GAV I just don't have the choke rod. It was missing when I bought the car.
    kidcampbell71 likes this.
  3. Mechman_22
    Mechman_22
    from Nc
    nice find, great looking car. what part of NC are you in im over in Jacksonville NC.
    JunkCarJesus likes this.
  4. JunkCarJesus
    JunkCarJesus
    Level Cross
  5. JunkCarJesus
    JunkCarJesus
    Got the ***le in!!! Being in North Carolina it had me a little worried. Believe it or not this was the deciding factor on me buying this car. Haven't really made any progress, we went from having a monsoon to fairly cold weather. Hopefully I'll be able to get something accomplished tomorrow.
  6. Pete Poling
    Pete Poling
  7. JunkCarJesus
    JunkCarJesus
  8. Pete Poling
    Pete Poling
  9. JunkCarJesus
    JunkCarJesus
    Picked up a couple more pieces to the puzzle. I scored this 32 shell last night thanks to jonnybright and my friend came through on a choke rod today. To all of you saying check the gas flow from the tank, you were correct. I ran it out of gas last week and I guess some crud got ****ed into the shut-off valve. I blew some air backwards through the line and now she's running like a champ! I finally got to take it on a successful test drive. I'll post the video in just a few.
  10. JunkCarJesus
    JunkCarJesus
    First successful test drive! I think I've finally got it sorted out. Time to get this thing road ready...
  11. dwollam
    dwollam
    Great! Now, get one of those press in screens for the stock pet**** from Snyder's or wherever and make that problem go away and stay away. Ya pull the pet**** off, push it in the top of the pet****, screw back in and you're good to go.
    Dave
    chryslerfan55 and JunkCarJesus like this.
  12. JunkCarJesus
    JunkCarJesus
    Took the Roadster for a little cruise around the compound. This is part 1. Had to turn the camera off when I got stuck...
    chriseakin, dwollam, hfh and 2 others like this.
  13. JunkCarJesus
    JunkCarJesus
    Here's pt. 2. Pretty stoked on how this thing is running. Time to get it on the road...
  14. JunkCarJesus
    JunkCarJesus
    Here's a few pictures from yesterday's shenanigans. I'm going to try to get lights on this thing and hopefully go get the tags Friday. I'd really like to find a windshield too. 20200223_180745.jpg
  15. Jeff Pandora
    Jeff Pandora
    from Mojave
    Nice cant wait for the sequel
  16. JunkCarJesus
    JunkCarJesus
    I should probably fix this. Does anyone know if waterproof grease will slow it down until I can replace the water pump?
  17. Have you tried to tighten the nut? I believe there is a lead gasket/bearing that you deform and tighten around the axle to stop the leak?
    Rune from Norway
  18. Itchy-Pit
    Itchy-Pit
    Enjoy the journey and memories! Thanks for taking us along!
    JunkCarJesus and chryslerfan55 like this.
  19. JunkCarJesus
    JunkCarJesus
    I couldn't get the nut to move. I'm going to try soaking it in pb blaster.
  20. missysdad1
    missysdad1
    Glad to see that Down East Street Rods plaque on your car. That club was formed in my living room many, many moons ago. I know it's still very active and that warms my heart. Good luck, and keep up your very interesting posts.
    brEad, chryslerfan55 and Stogy like this.
  21. sloppy jalopies
    sloppy jalopies
    didn't know where but the club started in the early seventies...
    I joined in '83 with a low-buck '30 roadster pick up...
    bought some A stuff from charter member jimmy harris this week...
    I recently retired after 36 years of service...
    not a lone wolf... more of a lone b***et hound...
    glad to see you still have a horse in the race !
  22. JunkCarJesus
    JunkCarJesus
    Finally got the hardware so I could mount the windshield. A combo of reproduction parts and original parts made it much more complicated than I had anticipated.
    dwollam, Stogy and chryslerfan55 like this.
  23. JunkCarJesus
    JunkCarJesus
    20200310_192842.jpg 20200310_192941.jpg 20200310_193007.jpg 20200310_193034.jpg
    dwollam, brEad, kidcampbell71 and 2 others like this.
  24. JunkCarJesus
    JunkCarJesus
    There's a few pics of the gl*** installed. Now I've got to figure out a way to clean it!
  25. Might I suggest using Windex?
    JunkCarJesus and kidcampbell71 like this.
  26. JunkCarJesus
    JunkCarJesus
    Got the tags today! Registered as a 1930 Ford Roadster. If you've ever tried to register an old car in North Carolina you know exactly how big of a deal this is.
    dwollam, Jeff34 and 31fords like this.
  27. JunkCarJesus
    JunkCarJesus
    Time to get some lights on this thing. I started out by cutting the ends off of the stock headlight bar. A little convincing with the torch and they worked perfectly. I'll change out the hardware as soon as I have a chance. The taillights are just some cat eyes that I had laying around. They too are temporary. Now it's time to take her up the road... 20200311_181733.jpg 20200311_181744.jpg 20200311_190543.jpg 20200312_094044.jpg 20200312_100313.jpg 20200312_104734.jpg 20200312_104728.jpg 20200312_180240.jpg
  28. sloppy jalopies
    sloppy jalopies
    when you cut that bar off maybe leave half of it with each cup... it is handy as leverage when twisting the light mounts …. I always tilt the cups down [tilting forward] or the lights won't adjust low enough to work...
    Jet96 and dwollam like this.
  29. JunkCarJesus
    JunkCarJesus
    Yea I learned that the hard way. I ended up using a big adjustable wrench. Made it difficult to make each side match.
    dwollam likes this.
