Hot Rods Kohler Kustom shop projects photo dump
Discussion in 'The Hokey Ass Message Board' started by thunderbirdesq, Jan 12, 2020.
  1. thunderbirdesq
    thunderbirdesq
    The weather has been so mild I’ve been running this heap around for parts and supplies, still needs a bunch of everything but it’s still fun to drive even with no heat! it s****es the chin pulling in and out of the parts store lot so it must sit just right. 9F653390-9C1A-4447-950C-2607037A03B4.jpeg
    brEad, 383deuce, 41 coupe and 16 others like this.
  2. Bandit Billy
    Bandit Billy
    ^^^^moon roof?
    loudbang and Stogy like this.
  3. thunderbirdesq
    thunderbirdesq
    Say what now?
    1947knuck, loudbang and Stogy like this.
  4. hillbilly4008
    hillbilly4008
    from Rome NY
    Dang, someone's been busy! Good stuff man. I thoroughly enjoyed going through those pics.
    Keep it up kid
  5. Stogy
    Stogy
    Rat Fink Hatch...:D
    1947knuck and loudbang like this.
  6. thunderbirdesq
    thunderbirdesq
    On the 40? That’s just the factory roof insert seam. The sd body has a full length welded steel roof insert, probably too large of a body to stamp out of one piece of steel.
    1947knuck, Stogy and loudbang like this.
  7. 40ragtopdown
    40ragtopdown
    My sister in laws delivery could be yours long lost cousin. L.o.l. 20150913_130746.jpg
  8. 40LUV
    40LUV
    from Mid Jersey
  9. thunderbirdesq
    thunderbirdesq
    Haha no kidding it could!
    Spent a few nights and weekends and we put together a different ch***is with extra parts and leftovers hanging around the shop, things happen faster when you’re not doing them under the car.
    1947knuck, JUNK ROD, Stogy and 2 others like this.
  10. Tall t 26
    Tall t 26
    Awesome builds. Very nice work.great pics. Keep em coming!!
  11. louisb
    louisb
    Hey! My hood is not random junk!
    Glad to see you back on the HAMB.
    --louis
  12. redoxide
    redoxide
    100% ******** hot rod building , no mess no fuss just getting the job done and making it look easy. ( we all know it isnt ) This has been a great read and an inspiring post. Thank you. :)
    loudbang, Stogy and thunderbirdesq like this.
  13. thunderbirdesq
    thunderbirdesq
    775E8E6E-ACDC-48C0-B0DB-8A55EAD009F8.jpeg 377772A7-40A7-4C0F-962F-0E91D1631359.jpeg A little more work on daves special, getting the silicon firewall seal fit, just washers as we’re fitting it up but the perimeter on the firewall
    Side will get an aluminum ring with a rolled outer edge to improve the clamping area and for a more finished appearance.
    1947knuck, JUNK ROD, loudbang and 5 others like this.
  14. thunderbirdesq
    thunderbirdesq
    You made the hood (and did a killer job!), I just poked a bunch of holes in it!
    Stogy, 1947knuck, loudbang and 2 others like this.
  15. thunderbirdesq
    thunderbirdesq
    Torque tube was dang near resting on the curtain pan on Romeos roadster, the pan and body crossmembers had some minor rot anyhow so we pulled it and installed new crossmembers, a flat panel, ditched the bustle, and moved the riser back a couple inches. We were able to save an old toe board that fits the cars personality, made a floor board from oak ply and gave it a paint job to match, with some real road dirt and a few hundred footprints on it, it should fit right in.
    brEad, TomT, 1947knuck and 5 others like this.
  16. redoxide
    redoxide
    I love how you do things.. 100% solid work with no messing about. Its all neat, its all functional and its all in keeping with the style of old survivor hot rods, maintaining and improving things without going to far. Love it ..
  17. TomT
    TomT
    You are still killing it, Andy, doing some waaay cool work. Thanks for posting !!
  18. thunderbirdesq
    thunderbirdesq
    Whew! Jeffs truck is torn down, blasted, straightened up and ready to head off to tuki for paint! Got a big pile of parts headed to the polisher and chromer as well. This is gonna be one fine hauler!
    brEad, TomT, 1947knuck and 8 others like this.
  19. thunderbirdesq
    thunderbirdesq
    A few things happening here
    64DF558F-D9A1-4946-B5E2-A48623B890F7.jpeg 4DB1032F-D161-4864-8D29-22CEE2BE2EAB.jpeg 5D9ED939-A016-4105-BBF0-E7222707D2C7.jpeg 0E8972A9-4A3B-43AF-8635-8B64361E5AC5.jpeg 45E36A91-AD34-4226-B50E-80ED3FFCFCD4.jpeg
  20. thunderbirdesq
    thunderbirdesq
    @dudley32 ‘s axle getting knocked down a few stones
  21. rod1
    rod1
  22. redoxide
    redoxide
    On the axle drop , what happening at the other end ? Is the axle end secured some way perhaps in a similar fixture to the end being dropped ..?
  23. loudbang
    Does the axle remain the same width between kingpins?
  24. T. Turtle
    T. Turtle
    I used to restore old cars for living and I can tell you this is work at the highest level. Please post more.
  25. thunderbirdesq
    thunderbirdesq
    Yes there’s a carriage that bolts through the perch boss to limit narrowing and a bottom stop to set the kpi angle.
  26. thunderbirdesq
    thunderbirdesq
    We do have some control over the narrowing but Even with our stop set all the way out we still lose some width, just the nature of the beast. In this case the jig was set up to allow the axle to narrow as much as possible because it’s going under a full fendered car.
  27. thunderbirdesq
    thunderbirdesq
    Front shocks and a headlight bar in progress on Romeos roadster
    DEB21BD1-AAD6-4702-A4C9-C3C03F6DAAFD.jpeg CB36C5A5-45A5-44C2-AC46-CBEDECC17807.jpeg
    Pats 33 coupe starting to come together
    @louisb jimmy he picked up from @chaddilac just showed up, gathering up some parts and we’re gonna make it into a reliable daily he can really use as a truck
    And a random shot of Jeff’s 32 that turned up on Facebook
    brEad, Stogy, JUNK ROD and 11 others like this.
  28. Pete
    Pete
    Andy
    iv always been a fan of you and your work. Your the real deal ,,,, no gimmicks, no crazy expensive gigantic machines,,,,all hand made hand formed parts and pieces. Every car is authentic and unique! Kudos my man.
  29. thunderbirdesq
    thunderbirdesq
    The feeling is mutual brother, your cars have always inspired me, glad to call you a friend!
  30. Old-Soul
    Old-Soul
    Thanks for the crash course update
    Years back you'd posted a cadillac powered T roadster you and a pal built...I've always wondered what became of that cool T?
    Stogy, chryslerfan55 and loudbang like this.
