Hot Rods Driveway Stains
Discussion in 'The Hokey Ass Message Board' started by Charlie Stephens, Feb 12, 2020.
  1. partssaloon
    partssaloon
    Lowe's has a oil stain remover made by Valspar that seems to work really well on pavers
  2. Beanscoot
    Beanscoot
    "How about asphalt?"
    I find that oil, diesel, gasoline etc. will soften or even dissolve the asphalt, so it's pretty hopeless. I guess the kitty litter ground in would be the safest.
    Of course the real answer for me is to replace the rear main seal in all three of our daily drivers(!) but I'm waiting until the clutches wear out.
  3. Deuces
    Deuces
    Yep! Buck a bottle....
    lothiandon1940 likes this.
  4. moparboy440
    moparboy440
    from Finland
  5. Special Ed
    Special Ed
    Depends on what the composition of the pavers is. Usually, kitty litter (gypsum) works well, and so does gasoline and these are the two least expensive things you can possibly find ...
  6. Flathead Dave
    Flathead Dave
    from So. Cal.
    61Cruiser and chryslerfan55 like this.
  7. plym_46
    plym_46
    from central NY
    Large baking pan and puppy training pads. They hold a lot of oil or coolant. But why not find and fix the leak?
    Deuces likes this.
  8. 56don
    56don
    Another vote for Tide powder. Scrub it good and wash it off.
  9. spook498
    spook498
    Heh, kitty litter stomp or the Fallon Shuffle in Navy parlance....
    Ive used Dawn on fresh oil stains that arent too big. Tri Sodium Phosphate also works but isnt overly environmentally friendly.
  10. ekimneirbo
    ekimneirbo
    Didn't read all the previous suggestions so maybe this one has been suggested. I keep a spray bottle of kerosene or diesel fuel in my garage. Whenever some one leaks oil on the driveway, I spray it and it miracously disappears in a couple days. It really works well even several days later. Best to do it before any rain gets to it. Don't know how it works on long term stains cause I never have any. Had a guy leave 2 ft diameter trans fluid puddle and it was gone shortly thereafter. If they leave a real puddle, soak it up with a rag then spray it. Might have to spray a second time a few days later if its rear end grease. I've been using it for 20+ years. The secret is to have the bottle before you need it.
  11. HotRod33
    HotRod33
    How did you get oil stains???? Hotrods don't leak oil.... Hahaha
    chryslerfan55 and Special Ed like this.
  12. It's a Hotrod. If it isn't leaking oil then it's out of oil!
    Hahahahaha....sorry, had to add for the 100th time.
    Sent from my Pixel 3a XL using The H.A.M.B. mobile app
    03GMCSonoma likes this.
  13. Although gasoline will work as a pretty good cleaning product I'd advice not doing this.
  14. woodiewagon46
    woodiewagon46
    from New York
    I've used Brake Clean followed up with Gunk. Let it sit and wash it down.
  15. Dawn dish soap works well on pavers.
    Did my driveways this summer as my van had a ****** leak for a while left a dirty spot.
    soaked it used almost a full bottle on the entire driveways
    Scrubbed it with a stiff bristle broom
    Let it soak about 10 minutes
    Then hit it with my pressure washer
    And it was gone.
  16. ct1932ford
    ct1932ford
    For ash-fault driveways Speedy-Dry brush it in , let it sit , wash it away. I guess it is like kitty litter.
  17. flatford39
    flatford39
    I use simple green and a stiff broom and a power washer. Do this before I reseal.
  18. lucky ink
    lucky ink
    Always used kitty litter and grind in with a brick :D
  19. aerocolor
    aerocolor
    from dayton
    This works great for me.
  20. jnaki
    jnaki
    Hello,
    If your pavers are color stained in the format when laid down, check any left over ones for color disappearing from any liquid or dry remover product. It certainly would not be nice to see discoloration in one spot of the whole driveway. We have stayed away from color infused concrete/manufactured driveways. We know that it is always the problem from friends’ cars and frequent visits from relatives leaving their deposits after they leave.
    Even the U.S. Mail person parks his/her van on the driveway to deliver special packages and leaves a drop or two. If those stay too long, it is harder to get out. The original Amazon delivery guy used to park in the driveway, but I guess the new rule is to stay on the streets. He, too was a culprit in those little drops. A wire brush and the potent liquid Acetone or Lacquer Thinner works every time.
    Those are the two strongest stuff we use and those pesky oil spots disappear in a flash. The smooth concrete areas of warehouses and buildings are less inclined to stain as the surface is smooth and sometimes sealed. Most spills are easily wiped up using less potent solutions.
    But, since I do not want to hang out on the driveway cleaning, the little time it takes is minimal. Porous concrete does cause problems.
    Jnaki
    Be careful on where that acetone or lacquer thinner get put on the shelf, counter or concrete. It does take off colors.
  21. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    I don't have a good answer to the question, but when people say my cars leak and leave stains, I say it's not leaking, it's marking its territory.
    lothiandon1940 and VANDENPLAS like this.
  22. blowby
    blowby
    from Nicasio Ca
    Well coincidentally I finally moved one of my tired leaking heaps to pull the engine yesterday. 10 minutes, no more, with kitty litter. Ain't perfect but should keep the HAZMAT crew away. The rain and sun will finish it.
    BTW on pavers, the ones and my place aren't flippable, one side is textured and chamfered, the other rough with square edges.
  23. nochop
    nochop
    from norcal
    When did we all turn into our fathers?
    el Scotto, J_J2, chop job and 2 others like this.
  24. HealeyRick
    HealeyRick
    from Mass.
    In the gas station where I worked it was speedi-dry (kitty litter) spread out over the floor. Scrub it with the wood side of the shop broom, flip over the broom and sweep it up.
  25. bchctybob
    bchctybob
    I use carb cleaner and a rag on the polished concrete in the shop, the kitty litter stomp on the rougher outside concrete. But what about rust stains on the concrete? I've got a few rust stains on the driveway from moving old engines around that I haven't been able to get out.
  26. Mike Rouse
    Mike Rouse
    Sodium hydroxide is the strongest base there is. Oven cleaner and drain cleaner are made of it. Try spraying oven cleaner on your spots wait a little while as it soaks in then scrub with a broom. Do the same thing with drain cleaner mixed with a little water. After a through scrubbing rinse with hot water. While using these products wear protective gloves and goggles. These products will dissolve your cell walls if you get it on you.
  27. nochop
    nochop
    from norcal
    That’s funny, that’s probably how I learned it..... many years ago @ $2 an hr.
  28. nochop
    nochop
    from norcal
    Rust stains... did you expect something that would dissolve a car to be easy
    bchctybob likes this.
  29. southcross2631
    southcross2631
    Muriatic acid works real good at removing stains just remember to have good air flow so the fumes don't get you. It also cleans up your grinding burs if you get them clogged with aluminum.
    Eats **** out of aluminum. Can used to acid port heads and intakes .but you have to know what your doing or you won't have any parts left.
    chryslerfan55 and bchctybob like this.
  30. Bandit Billy
    Bandit Billy
    I have a combination of stamped concrete and exposed aggregate, 11 years of old cars, no stains. The trick is applying solvent based sealer either roll on or spray every other year after gentle pressure washing. Drips and spills wipe up easily and when it rains you can skate from one end to the other.
