frost plugs
Discussion in 'The Hokey Ass Message Board' started by 30Abone, Jul 2, 2006.
  1. 30Abone
    30Abone
    I am having trouble with a stubern frost plug that does not want to come out any ideas?
  2. squirrel
    How are you trying to remove it? Generally they come out pretty easy if you drive one side into the block with a hammer and punch, then pry it out by the edge with water pump pliers (channellocks).
  3. 30Abone
    30Abone
    never mind just got it out
  4. 47bob
    47bob
    It always helps to have lots of sharp tools and be really pissed off.
  5. pimpin paint
    pimpin paint
    from so cal
    Dent Puller/slide hammer.
    S****ey Devils C.C.
  6. squirrel
    I've used the slide hammer technique on flat plugs, and real small ones, but the other way is easier on "normal" freeze plugs
