Technical Is this correct 38 ford
Discussion in 'The Hokey Ass Message Board' started by 38nailhead, Feb 11, 2020.
  1. 38nailhead
    38nailhead
    from England
    Hi anyone who reads this . I’m in the process of taking apart my panel truck to fully see how much work is needed on the body and tonight came across this ...
    On one side of the body the metal work runs on top of the wooden cross member at the back and on the other side it runs below. Is this meant to be like this please ? The body sits well on the ch***is and the wooden bed that was inside the panel truck also sat well .
    Thanks Ben E2E6C68C-F116-4E71-AC59-DA893173BF6B.jpeg 7AB9BFCB-804D-48DC-B248-D730CEC8341C.jpeg 54A6CA39-618F-4081-9D56-ABC369A475C9.jpeg
  2. BigO
    BigO
    Never seen that, wish I could help.... someone knows and hopefully reads this.. good luck. BigO
  3. dudley32
    dudley32
    The right side looks correct...the left looks bent. Maybe it was replaced at some time?
  4. 38nailhead
    38nailhead
    from England
    So you think it should be sitting underneath the timber ?
  5. 38nailhead
    38nailhead
    from England
    A2455F4C-D85D-438B-9ED7-0824ECE0DFAD.jpeg 29016185-D4A5-4193-84DF-1184E07C33E8.jpeg 41B12596-0365-4095-86F5-D6A90217C54D.jpeg
    This is the bed before I took it out , was very rotten and weak , but was the original bed as it had the bed strips , 2 access plates in the center and also by the wheel arches
  6. kidcampbell71
    kidcampbell71
    @Pete Eastwood
    ... if anyone else doesn't chime in, this man ^^^ has likely laid an eyeball on your answer at some point .. in his world.
  7. 38nailhead
    38nailhead
    from England
    thanks , I will use message him if nothing else comes up
  8. theHIGHLANDER
    theHIGHLANDER
    I'm thinking this through with the eyes of 40+ years in restoration. 1st thing I'd look for is a commercial ch***is of some kind like a pickup or flat bed. How does that frame look? If they too have that extra kick to the left for something (like fuel tank, or other production needs) there's no other way possible to build a level bed back there except with that over/under wood approach. My search would be for Ford Commercial frame pics. This tickled my curious single nerve enough to look for myself. Clever those dadgum Ford guys...;)
    I looked at your pics a lot closer and that is indeed the body subrails, yes? I'm ***uming that's so and the next question is where does the petrol tank normally go?
    38nailhead likes this.
  9. 38nailhead
    38nailhead
    from England
    The ch***is for these are the same as the 35- 40 car ch***is . But slowly taking this apart I’m absolutely amazed with the way the wood is used on the bed , it’s such a shame I couldn’t save it F94B031D-231B-4D5C-A099-41F6054C5D89.jpeg D8BB0EDF-6049-41B1-BD66-DE1F5E643291.jpeg D35DD065-1DFF-4D10-AB05-953FEF1C0429.jpeg
    Stogy and kidcampbell71 like this.
  10. theHIGHLANDER
    theHIGHLANDER
    I did a google image search for 1938 Ford panel truck. It seems the gas tank fills through the fender much like the cars (I have a 39 std sedan). That being the case I'm gonna be in the line that says it's correct. They would need room for the petrol filler pipe and hose, right? Yes, looks like my frame in many ways too and my tank rides back there as well. As to the use of wood you should welcome that. Easier to cut wood than fab steel. You gonna make me search your stuff or post a pic of the whole truck?;)
    Stogy, 38nailhead and BigO like this.
  11. 38nailhead
    38nailhead
    from England
    Thanks for the info . BBEEC52F-DF92-437A-B260-1F4ED0A68FFC.jpeg 08AE3B2E-AD7D-404C-B0FE-A2BBAF8A92CE.jpeg
    hfh, bathcollector, Stogy and 5 others like this.
  12. flatford39
    flatford39
    You have a really nice looking truck there. Good luck with it.
  13. theHIGHLANDER
    theHIGHLANDER
    The car sheet metal on the front is a natural. I've seen it on pickups too and really, REALLY like that look. Way kool...
  14. 38nailhead
    38nailhead
    from England
    well for anyone that wants to know the rails on my truck body are correct and thehighlander was correct it’s shaped this way for the fuel filler neck to go under . BFBC52BF-0E6E-4D5E-812B-1F24A81B8EF7.jpeg
    Stogy likes this.
  15. For what it's worth, the gas tank is the same for all '38-'40 Ford car and '38-'41 1/2 ton pickups and panels (112" wheelbase) except sedan delivery. You have a panel truck, not a sedan delivery, so no problem. The filler pipe is different from cars but is the same for all 1/2 ton (112" wheelbase )'38-'41 pickup and panel.
    Stogy likes this.
  16. Deuce Lover
    Deuce Lover
    I suggest you go to www.fordbarn.com which is a sister site to this.There are members there that have restored these panel trucks.You might get more info there.
  17. BLACKNRED
    BLACKNRED
    Did the Panel truck have parallel elliptical springs ? if it did, I just learnt something new.
  18. 38nailhead
    38nailhead
    from England
    the ch***is has been modified many years ago before i purchased it with a Chevy 10bolt rear , so after market I have to say.
  19. BLACKNRED
    BLACKNRED
    I would suggest that the strap follows the floor on both sides, the timber supports for the floor would have been bolted to the ch***is through the strap and timber and ch***is, more than likely with blind bolts with a square locator similar to a gutter bolt, I had a 39 Coupe Utility years ago and the wooden floor had a similar arrangement, although worlds apart Ford did use similar manufacturing processes world wide.
