Technical Roof Insert
Discussion in 'Traditional Hot Rods' started by Mike Colemire, Jan 4, 2020.
  1. trvguy
    trvguy
    I ussed a Dodge Minivan roof on my 32Ford, nice compound curves. Nice fit
  2. Blues4U
    Blues4U
    from So Cal
    Nobody has mentioned it so I will. Be forewarned, it will get a lot LOUDER inside. Right now, a lot of noises are exiting the open top and going away, you put the top on ad all those noises are going to bounce right back down at you. Especially is you have loud exhaust (lakes headers!), but every little noise that is generated is going to be reflected back down at you.
    I built the insert for my A pickup to be removable. The original roof bows were in the car, providing the basic shape, I used a s**** piece of 1/4" plywood and cut it to size using a pattern I made out of poster board. Then, to minimize the reflected sound waves I filled the ply with holes. Then covered it with batting and vinyl. I can remove the insert in about 3 minutes if I want to go with the top open, but to be honest, that is very rare (never?). When I eventually redo it I'll make it permanent instead of removable.
  3. unfinished
    unfinished
    Man I wish ya had not brought up Vista Cruiser.....yet another car I lost in a broken relationship!!! Lotta fun and I miss that ole wagon!!! Can't say as much about the lost love....
  4. In addition to what these guys said, I also like the '57-'59 Ford roofs, they have inverted ribs that look good. '64 Darts have a cool pattern of ribs, grouped to the outsides.
    Another cool idea, is a dzus fastened insert full of louvers!
  5. AmishMike
    AmishMike
    Not trying to sell the idea but a suggestion for your consideration. No pics but saw a coupe with plexigl*** roof insert ( tinted yellow). Thought kind of neat idea. Sun would roast the inside but could also make removable for open air cruise or wedge open at rear. Not sure how would make rain/drip proof & suspect some steal cross pieces to support sides & insert. As a roadster guy will not be trying but you might think about it. With treated wood frame attached to plexi & slight tint to match paint on car might be pretty nice
  6. blazedogs
    blazedogs
    I welded in a steel roof insert not too long ago and it was a nightmare.A lot of work , easy to make a mistake , warp age when welding, getting the right contour and fit, body filler work blending in etc . Never again Would now chose a different route than a steel roof insert My 2 cents.. Gene
  7. 51farmtruck
    51farmtruck
    I used a piece of 1/8" lauan plywood for the top in my 32. A thin piece of padding and then the original type grained vinyl. I painted the lauan a nice semi gloss black and it looks really nice from the inside.
    -Brent-, Tman, RICH B and 7 others like this.
  8. blazedogs
    blazedogs
    A much better way to go and a fabric top matches the era of the car & looks great...
    kb9jlo, loudbang and TagMan like this.
  9. McFly
    McFly
    Do you have any detail shots of the track/trim holding down the vinyl?
    RICH B and loudbang like this.
  10. 31choppedtopcoupe
    31choppedtopcoupe
    from Ohio
    Any interior pics of that insert?
  11. Lexan and it will have a "moon roof". Believe it or not when I was little I saw a few show cars at a place called "The Cow Palace" with roofs filled that way (would have been plexi gl*** back then).
  12. Just Gary
    Just Gary
    I did the same as @sloppy jalopies and found an '86 Toyota minivan :confused: matched my A Tudor perfectly. I'm gonna cover it with vinyl later.
    More details here:
    https://www.jalopyjournal.com/forum...e-6-steel-roof-covered-by-stock-vinyl.636247/
  13. Blues4U
    Blues4U
    from So Cal
    Yes. Note the oak blocks are to hold the insert in place. That was part of the removable aspect of the top. I originally wanted it to be removable. Turns out I don't remove it, it's just too nice having a roof overhead. So, if/when I redo it I'll get rid of those and use something far less noticeable. Otherwise it look like the original style insert at first glance, chicken wire and batting. IMG_7688.JPG
  14. Scrapbmxrider16
    Scrapbmxrider16
    I like how it looks man
    Sent from my SM-G965U using The H.A.M.B. mobile app
    Blues4U likes this.
  15. 32 hudson
    32 hudson
    A lot of good information , suggestions and photos in this thread. Where do I get the trim welting or rubber strip to finish off the edge ? I would like it to fit close and not stick up much. I am not a fan of the Juliano's aluminum strip.
  16. cfmvw
    cfmvw
    If you check out the European Deuce Thread, there are a number of cars that were set up with a ragtop sunroof instead of an insert. Maybe you could graft in a VW Bus ragtop sunroof?
  17. Jason Mitchell
    Jason Mitchell
    from Memphis TN
    I like the idea of using wood bows similar to original, then making a vinyl top that snaps on and off...but thats just me.
  18. 31choppedtopcoupe
    31choppedtopcoupe
    from Ohio
    Looks good buddy. I think I’m gonna copy it for my ‘31.
