Projects Southeast Gasser 50 chevy wheel stander project
Discussion in 'The Hokey Ass Message Board' started by Quain Stott, Feb 12, 2020.
  1. DDDenny
    Jungle Pam, just say'n!
    scotty t, raven and David Gersic like this.
  2. Quain Stott
    Quain Stott
    Thanks, for all the support over the years, you have always supported me with this crazy SEGA idea. As you know it started in 2011 and I have always tried to make it better but still stay true to the era as much as possible.
    Hope to see you sometime this year, maybe I can make a trip to Anderson to see you and a few others but will need a body guard anytime I'm in that area LOL. Gene Cromer came down last Friday and spent the day with me, it was sure good to see him.
    enloe, mad mikey, catdad49 and 6 others like this.
  3. Brand Apart
    Brand Apart
    from Roswell GA
    Great idea, looking forward to seeing it in action.
    loudbang and Quain Stott like this.
  4. DDDenny
    Quain
    How is Gene doing?
    Haven't heard much of his Willys for some time.
    enloe, mad mikey and Chucky like this.
  5. Quain Stott
    Quain Stott
    It's parked except for doing shows but he's doing good. I think he's like 86 or 87. My hero for sure.
  6. Quain Stott
    Quain Stott
    Today we worked on finishing up the engine mounts and mounting the v-drive. This pic is of the mid mount that I felt it needed.
    enloe, AHotRod, mad mikey and 3 others like this.
  7. Quain Stott
    Quain Stott
    Anyone that has followed my builds know how picky I am on drive line angle being perfect.
    99% of all drive shaft / u-joint failure is from a misaligned drive line angle, not horse power like most think. This wheel stander will really test ones knowledge on mounting the engine to get the drive line angle right. Plus it has two drive shafts that have to be tuned together. First step is to get the output shaft in perfect line with the input of the v-drive. We made a trick little fixture to do it as seen in the pics. It was bolted to a yoke then welded to a 4" aluminum bar then machined to a perfect fit for the register in the flange of the v-drive. The little notches are machined in the aluminium fixture so vise grips will fit in there to clamp it to the v-drive flange. When this is all finished each u-joint will have 1 degree angle.
    Keep in mind all of this had to be figured in before mounting the engine, transmission and rear end housing. Something that is over looked in most builds until it's to late.
    enloe, AHotRod, mad mikey and 9 others like this.
  8. Quain Stott
    Quain Stott
    Good help is the key to a successful race car shop even if they fuss with each other LOL . Here we see Harold Brady getting *****ed at by Tom White while the 3 of us argue about how the v-drive should be mounted. I got out of the fuss to take the pic LOL. We do have a great team at Stott's Speed shop but we like to have fun while we work. tom and harold.jpg
  9. Quain Stott
    Quain Stott
    Pic's of the mounted v-drive. Once all welding is done final adjustments will be made with the turn buckles. V-drive 5.jpg V-drive 4.jpg View attachment 4582696 V-drive 2.jpg V-drive 1.jpg
  10. seb fontana
    seb fontana
    from ct
    Did you machine 1° on ends of aluminum? Or going to adjust to the 1° with the turnbuckles..
    Quain Stott and loudbang like this.
  11. chevy57dude
    chevy57dude
    Build pics are fun to look at. It's interesting to see how fabrication is thought out and executed. Especially on a vehicle this far out of normal. Love it!
  12. southcross2631
    southcross2631
    Are you going to run stack injection on alky or a blower motor ?
    nice work on the truck .
    mad mikey likes this.
  13. catdad49
    catdad49
    You're spending the extra where it's needed to make it Not the weak link. The front suspension, steering and braking/ steering system will be another time eater. The rest needs to be functional without being overly nitpicky, Almost time to start thinking about a name. Great to hear Mr. Cromer is doing well! Who are you building the T Bird for? Hope to see you this year, Carp.
  14. rd martin
    rd martin
    from indiana
    dam quain ,you always stay busy! what do ya have 2 months before season starts? ah hell lets build a wheel stander! go bud, i wish i had all your energy! will see you at the track!
    mad mikey, loudbang and chryslerfan55 like this.
  15. Quain Stott
    Quain Stott
    The jig is flat we will put the 1 degree in it with the turn buckles. I wouldn't put any angle in it but the u joint has to have angle to grease it's self.
  16. Quain Stott
    Quain Stott
    One month from Saturday is the First SEGA race At Emerald Coast Drag way in Holt Florida. But the wheel stander won't make it. If I didn't have so much other stuff to get ready I could finish it easy but only get to work on it a few hours per week.
  17. Quain Stott
    Quain Stott
    T Bird is for Mike Blackwell to run SEGA B/Gas. I need to do a build thread on it.
  18. southcross2631
    southcross2631
    Quain, if I wasn't trashing on my Comet trying to get it done I would come over and volunteer my time to help in any way to get the wheelstander done . Including being a test dummy.;)
  19. Quain Stott
    Quain Stott
    I'm bouncing around kinda working on little things I can finish quick because I'm only getting to work about 2 hours per day on this play project. Tonight I made these rear Body mounts, I found the inner panel to be solid and it has a reinforcing rib behind it so it's a good place for a body mount. It would be a lot easier to just weld the body on like most do but I want the body to bolt on. Most all of my projects are built for the body to be removable, I guess that habit is left over from the old days building pro mod cars.
    enloe, AHotRod, kidcampbell71 and 5 others like this.
  20. Quain Stott
    Quain Stott
    Had enough time left tonight to do a quick set of seat mounts also. Started with 1/8th aluminum plate that I cut and bent to make a 7" tall seat mount.
    No pains taken just getting it done.
    AHotRod, Thor1, mad mikey and 3 others like this.
  21. Quain Stott
    Quain Stott
    I put the steering column and pedal ***embly back in just to help locate the seat. Notice we are using the stock pedal ***embly and steering set up from 1950. We did make a small modification to the pedal ***embly so the new floor board will lay flat on the ch***is. You will notice where the pedal mount is cut and welded back. The top of the mounting bracket is now under the ch***is where it was on top of the ch***is from the factory. IMG_0701.jpg IMG_0702.jpg IMG_0715.jpg
    enloe, AHotRod, Thor1 and 4 others like this.
  22. Quain Stott
    Quain Stott
    It's strange building something where no drive train is in the middle of the car. I usually incorporate drive shaft loops, cross members and stuff like that into the seat and seat belt mounts but in this thing I just have to worry about seat mounts so no thinking or planning required. Just run a piece of tubing across from one side to the other anywhere I want. Pretty easy to see I'm wire welding most of this deal together, remember I'm in a hurry. IMG_0712.jpg
    enloe, AHotRod, Thor1 and 5 others like this.
  23. Quain Stott
    Quain Stott
    I take that back, I did do a little planning. I went ahead and welded an insert in the tubing for the seat bolt and one for the crotch strap. Never mind the bad tig welding I rushed through it because it has to be sanded back down to be flat so the bolt will set right. IMG_0707.jpg IMG_0708.jpg
    AHotRod, mad mikey, loudbang and 2 others like this.
  24. Quain Stott
    Quain Stott
    If you noticed the notch cut on the ends of the tubing when it was laying on the bench in the previous post it's so it will lay flat with the old ch***is so the floor will run over it with out a step down. IMG_0709.jpg IMG_0711.jpg
  25. Quain Stott
    Quain Stott
    To stay with the 1967 era theme we had to use a low back seat. I found a cover for it also so once the cover is on it will hide the fact that it's a modern day plastic seat. Of course I'm buying everything from Summit, New sponsor for the SEGA points fund for the 2020 season.
    It's in but only with one bolt. I'll finish up the other 3 mounts next time I get a few minutes to fool around with it.
  26. catdad49
    catdad49
    You're thinking/planning about this build, you just don't realize it. I believe it's called Experience! I'm wheelie (insert groan) enjoying this, can't wait to see the finished product (Oh, and the T Bird).
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Reminds me of my responds to O’Reilly Auto Parts. "O'Really!, you don't have what I'm looking for".
    catdad49, mad mikey and loudbang like this.
  28. BamaMav
    BamaMav
    from Berry, AL
    Woo hoo!!! I see y'all are going to L***iter Mt! Gonna do my best to be there!
  29. Quain Stott
    Quain Stott
    Yes we are and the wheelie truck should be there. Spread the word, let everybody in the neighborhood know so we can pack the place.
    loudbang, catdad49 and mad mikey like this.
  30. mad mikey
    mad mikey
    This is a great build you are doing Quain,and will delight fans everywhere you go. :) Still waiting for you to bring the show to here in Pa.;) Anyway, thanks for sharing your talent and all you do. Mike.
