I'M no longer LOCKED OUT
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Feb 22, 2020.
  1. nochop
    nochop
    from norcal
    I don’t think you can unlock a deuce door with a key if the handle is in the locked position, at least on my avatar...hence knowing I can reach the door handle through the cowl vent. But it will lock by throwing the p***enger door into lock then the drivers door, then exit through drivers door.
    upspirate and HOTRODPRIMER like this.
  2. HOTRODPRIMER
    HOTRODPRIMER
    That's what I'm afraid of. HRP
    loner2 and chryslerfan55 like this.
  3. Doublepumper
    Doublepumper
    from WA-OR, USA
    This does ****..... Any way to pop a grommet or unbolt something on the front of the firewall, then use something like stiff wire to get to the door handle? Gotta be a way :mad:
  4. Mel
    Mel
    I was just about to say access through the battery box in the floor- presuming your battery is still in that position. Well, a small slice in the carpet that is under the seat would be better to me than smashing some gl***.
  5. abe lugo
    abe lugo
    Place an order. Week and 40.00. Still cheaper than new non-matching gl***.
  6. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Just call a locksmith.
    They have tools - you don’t.
    They have these inflatable balloons that flex the door just enough to slip and hook or wedge plate to open doors.
    Call the lock smith and get it done
  7. HOTRODPRIMER
    HOTRODPRIMER
    We broke one of those trying to remove the pins on Dave's 40 coupe. HRP
  8. HOTRODPRIMER
    HOTRODPRIMER
    That's exactly what I plan on doing Monday morning. HRP
  9. ffr1222k
    ffr1222k
    I had to call one on my OT car once. He charged me $50 and that included a key.
  10. Jalopy Joker
    Jalopy Joker
    bet that you have a BF hammer that fix most anything
  11. HOTRODPRIMER
    HOTRODPRIMER
    Believe me I thought about it until common sense kicked in. HRP
  12. BamaMav
    BamaMav
    from Berry, AL
    I'd still try the wedges in the door jamb trick. All you need to do is get it far enough away from the jamb that you can work a stiff wire in there. The heavy plastic strapping works great, too. My kit has both. I just want to get one of those cool pump up bags.
  13. HOTRODPRIMER
    HOTRODPRIMER
    The '32 Ford does not have a overlapping door like the Model A, it is flush mounted with about a 3/16" gap, I just don't see any way to accomplish that.
    Again, I'm going to call a locksmith tomorrow, I don't have to gain entry today and I see where their service is higher on the weekend & holidays. HRP
  14. 19Eddy30
    19Eddy30
    from VA
    Hot rod Primer , I did not read all the posts , If still locked Out , jack car up & I would try going from under Car threw the Brake peddle opening with a rod to door handle,
    HOTRODPRIMER likes this.
  15. ct1932ford
    ct1932ford
    Such Suspense! :confused: Wish I were there. I would have 4" out of top by now!:eek:;) Good Luck my friend.
  16. HOTRODPRIMER
    HOTRODPRIMER
    Mark, did you forget I buy my cloths in the men's Big & Tall department, not the children's department like yourself :D
    Seriously, I have owned a couple of chopped cars and as much as I like them I am too tall for a chopped car. HRP
    loner2, ffr1222k, pprather and 3 others like this.
  17. captain scarlet
    captain scarlet
    from Detroit
    Do you have stock door locks?
    If you do can you pull the hinge pins and pull the front of the door out or forward far enough to unhook the back?
    I saw you mentioned you had new check straps, don’t know if those are too short to try....
    ct1932ford and chryslerfan55 like this.
  18. Johnboy34
    Johnboy34
    from Seattle,Wa
    With what probably broke in the latch mechanism your most likely going to have remove hinge pins anyway just to open the door and fix the latch.
    Sent from my SM-G973U using The H.A.M.B. mobile app
  19. Junior Stock
    Junior Stock
    I guess Ford figured this problem out by 33 as mine locks from the inside by pulling the handle up. That said I tried using the key, even though I already knew better, to unlock it and it does not work.
    Call a locksmith if you like but if you are using the factory lock pretty sure you will just be getting an extra key out of it. An expensive one at that.
    Good luck
  20. bobj49f2
    bobj49f2
    I don't think that's a hard rule on this board :rolleyes:
    warbird1 and chryslerfan55 like this.
  21. glrbird
    glrbird
    HRP, while you have your thinking hat on, is there a way to prevent this in the future?
  22. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Agreed, If you're going to have to pop the driver side pins to get the door open to do the latch repairs, have at it. At least the 32 is at home.
  23. This will take some practice, but it works.
    Bob
    chriseakin, dan31 and chryslerfan55 like this.
  24. Here is another method that might be successful using a regular drill. I have not tried this one, but I have seen many videos like this.
    Bob
  25. 49ratfink
    49ratfink
    a guy I worked with had a chain with what must nave been 50 of the old Chevrolet keys on it. he loaned it to me so I could find one that worked and get a key made for my car... so what you need to do is find the guy with 50 old Ford keys, or call your buddies and have them come over with whatever keys they have.
  26. HOTRODPRIMER
    HOTRODPRIMER
    Something like this ain't 100% preventable, if what I think happened the latch spring might have broken and I suspect age has a lot to do with that, in the future I will try to remember not to lock the p***enger door from the inside.
    The way Ford designed the latch if the p***enger door is locked from the inside the door lock key is useless, it will lock & unlock the door from the outside as long as it remains unlocked from the inside of the car. HRP
  27. dirt t
    dirt t
    As a retired lock smith I cain't tell you how many cars I opened by the p***anger door. Also I always used the p***anger door . As Customers and amateurs do the drivers door. And they usually caused damage in that door.
    Rich S. likes this.
  28. ct1932ford
    ct1932ford
    That is what I said. I think the door straps will not be an issue. If the doors have never been off, it may need heat and that is a problem.
  29. ct1932ford
    ct1932ford
    You are not that much taller than me!:rolleyes: Well at least we both feel the same way about Ford door locks.:p SC 030.JPG
  30. HOTRODPRIMER
    HOTRODPRIMER
    ^^^^^^^^^ Brothers of Different Mothers ^^^^^^^^^. :) HRP
    loner2, Blue One, ct1932ford and 2 others like this.
