Technical Disc Brake Kit 1937-48 Ford, 5 on 5-1/2
Discussion in 'Traditional Hot Rods' started by Thomas Marmont, May 8, 2017.
  1. Thomas Marmont
    Thomas Marmont
    Disc Brake Kit 1937-48 Ford, 5 on 5-1/2 BC
    Okay I'm looking at purchasing Speedway Motors front disc brakes for my 1948 Mercury. I have a really hard time on find any one who's know what backspace to run. I have a set of stock ford 15x6 so I am told. Tires are ther are 15inch I like keep it looking stock. I want to know were to get a steal wheel that will work with my center cap. 48 merc caps and beauty rings. The wheel needs to 15x6 Bolt Pattern:
    5 on 5.5" with wheel 3-7/16" center hole. Thanks Thomas
  2. tfeverfred
    tfeverfred
    Try Wheel Vintiques.
  3. 42merc
    42merc
    If in fact you have the original Mercury 15" wheels, they will work with the Speedway kit IF you use a 1/4" spacer behind the wheel.
    The spacer can be sourced from Advance Auto Parts for not much money.
    Works for me.
  4. 19Fordy
    19Fordy
    Please measure ( and let us know) the wheel mounting surface to wheel
    mounting surface measurement both BEFORE and AFTER installing your kit.
    It would be nice to know if their is a difference.
    Good luck.
    Thanks.
  5. rusty rocket
    rusty rocket
    So Mercs had 15"s and not 16'"?
  6. 31Apickup
    31Apickup
  7. 42merc
    42merc
    '42 thru '48 Mercury's were 15" x 5" with a 5 1/2" bolt circle.
  8. jimmy six
    jimmy six
    Personally I like the spacers that are drilled for what you want, flat, and not cast with over sized slotted holes. That maybe OK for aluminum/mag style wheel but not steels. Good luck.
  9. MIKE STEWART
    MIKE STEWART
    I put this same basic kit on my 1939 Ford Coupe about 12 years ago. F-150 rotors and big GM calibers - This car has a Columbia 2 speed that I want to keep. Easy to install - I just used a Granada disk/drum split master cly. For now - have the stock 40 Ford gear with a 4.44 ring - and a Chevy 327 - 300 hp and Muncie 4 speed. This was my Dad's high school hot rod. With that gear - the overdrive is really needed. When this car is road worthy - might regear to 3.78.
    For now - I have 1974 F-150 15x6 Ford truck steel wheels. They clear great front and rear. Future wish list is 15x6 steels and 1956 Ford Tk caps. These big disk really stop the coupe.
  10. 19Fordy
    19Fordy
    Mike, Did your track width change as a result of installing this kit?
  11. MIKE STEWART
    MIKE STEWART
    I installed it about 12-15 years ago - it did not change the offset. Really - the 15x6 ford rims sit closer to the fenders on the rear - than front.
  12. MIKE STEWART
    MIKE STEWART
    my rear end is a Columbia 2 speed - I almost think 15x7 rims might be too wide for the rear - it will be tight, vs the 1957 Ford 9 inch on my other 2 1939 Fords.
  13. 19Fordy
    19Fordy
    Thank you , Mike.
  14. Graybeard4545
    Graybeard4545
    from Maryland
    I am putting a Muncie in my 40 standard. did you use a hydro throw out or did you figure out a linkage? pics?
    Mine is a sbc, chevy bell, Muncie and a 9in rear.
    thanks,
  15. MIKE STEWART
    MIKE STEWART
    My Dad used a 1965 Chev Z bar with a 1940 Ford Petal set for the clutch. I reworked the connection from Z bar to clutch fork with heim joints and legnthened the postion further out on the clutch fork. Works Ok - if from scratch - I would try a cable like a T-5 in a Mustang.
  16. MIKE STEWART
    MIKE STEWART
    pic of the z- bar - with 1940 petals. If starting from scratch - 1939 petals and reclocking the arm to the 6:00 position should connect with clutch fork without a z bar. Mine is OK now - but plan B was the Drake repop 1939 petals. Z BAR 39.jpg
