Projects Got a little something to put the rocket in.
Discussion in 'The Hokey Ass Message Board' started by J_J2, Feb 24, 2020.
  1. Rusty Heaps
    Rusty Heaps
    Unless you're doing a full restoration, those gauges are pretty common. You can easily find a better set that probably won't need much more than a good cleaning, lubrication for the speedo, and installation. Don't forget the voltage reducer for the fuel gauge, that's ***uming you will do a 12V conversion. Good and solid looking car. Best of luck to you. I certainly will be following your progress.
  2. 56don
    56don
    Did you retrieve this from that salvage yard you posted photos of earlier? Looks like out west, you should fill out your profile so we know where you are from.
    Looks pretty rust free, will make a great project.
    chryslerfan55 and J_J2 like this.
  3. J_J2
    J_J2
    I’ll be doing the 12v conversion for sure, I’ve been having a little trouble locating the orig. gauges but I’ll keep looking. Thanks I’ll be needing all the luck I can muster.
  4. J_J2
    J_J2
    I did it’s called L & L cl***ic autos in Wendell ID. If I were a rich man there would be several more cars in my driveway, the place is huge and the inventory is something else. I live in Gooding about 10 mi. North. I’ve been trying to figure out how to update my profile but haven’t been very successful.
    Thor1 and chryslerfan55 like this.
  5. vtwhead
    vtwhead
    J_J2 go up to the top of the page, click on the single person silhouette, drop down to personal details, make changes and then click SAVE at the bottom:)
    J_J2 likes this.
  6. J_J2
    J_J2
    Thank you sir!
  7. Rusty Heaps
    Rusty Heaps
    Does L & L have a web page? DVAP ( Dessert Valley Auto Parts)or CTC Auto Ranch should have your gauges. Both can be found online.
    Just took a look on google, man, that is a hugh junkyard, seems there some very old stuff there!
  9. J_J2
    J_J2
  10. J_J2
    J_J2
    It is huge, I think its about 120 acres, if I had more money they would have a lot less inventory
    chryslerfan55, nunattax and 40two like this.
  11. J_J2
    J_J2
    That seems to be the extent of the major floor rust, Im trying to do everything I can with one arm I just cleaned out the whole inside, I’m glad thats out of the way.
    brEad, Thor1, alfin32 and 9 others like this.
  12. guthriesmith
    guthriesmith
    Looks like a nice solid car! Congrats and I will be following along. About 15 years ago, I drove a similar 52 and had lots of fun in it. Made lots of trips hauling my two boys in car seats in the back pretty much from the time they were born.
    brEad, olscrounger, Thor1 and 5 others like this.
  13. alanp561
    alanp561
    J_J2 likes this.
  14. J_J2
    J_J2
    Thanks, so far so good there’s some rust here and there but I haven’t found anything really bad yet. I will try to post as often as I can, I’ll be doing a lot more after my splints are off, of course I’ll be back to work but there’s weekends and evenings to knock things out!
  15. Rusty Heaps
    Rusty Heaps
    Thanks for the info J_J2, I'll look them up. Good to see that you have a solid project to start with. A rust bucket can be very discouraging.
    J_J2 likes this.
  16. Paul
    Paul
    Editor
    looks like a great start
    keep us posted on this one
    curious to see how you deal with the steering and front suspension
    I started down a similar path but got distracted and sold the car
    still have the engine though
    maybe some day it'll have a body too
    brEad, Thor1, j-jock and 15 others like this.
  17. J_J2
    J_J2
    Thank you, and you’re quite welcome!
  18. J_J2
    J_J2
    That engine is a beaut! (Car too) I’m putting the J-2 on mine as well. I’ll be posting as it progresses setbacks and all, thanks much.
  19. Crayons
    Crayons
    Wow, bet that Harbor Freight furniture dolly is screaming. ...
    indyjps, chryslerfan55 and J_J2 like this.
  20. Paul
    Paul
    Editor
    Ha!
    Yes it is
    Thor1 and J_J2 like this.
  21. Rusty Heaps
    Rusty Heaps
    I built my own to haul engines around my property. Larger wheels and several points of attachment to secure tie downs, chains to drag it, and more. A lot heavier duty. Paid for itself the first time I used it.
  22. Paul
    Paul
    Editor
    I know, I know..
    I have no excuses..
    J_J2 likes this.
  23. J_J2
    J_J2
    Got my splints and sutures removed today, I had to do something, so I cleaned up and put a coat of paint on the intake manifold today. At least it was something.
    brEad, Thor1, curbspeed and 4 others like this.
  24. nunattax
    nunattax
    im all for restoring the gauges.i got a set done through jim carter trucks for my 38.didnt break the bank
  25. J_J2
    J_J2
    I’ll check that out thanks for the info!
  26. nunattax
    nunattax
    obviously starting with the best core helps.
    loudbang and J_J2 like this.
  27. Nice project. You might try Bob Owens at Owens Salvage Co., in Wellington, Tx., he's easy to work with plus he's a H.a.m.b. Alliance vendor.
  28. J_J2
    J_J2
    Thanks very much, I want to go with as many HAMB members as I can.
    chryslerfan55, loudbang and 1stGrumpy like this.
  29. I like that its a stick trans. All real Hot Rods have three pedals!
  30. J_J2
    J_J2
    Yessir, I couldn’t agree more!
