Projects Anyone recognize the logo or number on this fitting
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Feb 25, 2020.
  1. I tried google with the part number SH201908.
    I’m trying to identify this fitting,
    Then research the threads on each end.
    Then fabricate a different apparatus.
    These pics are coming to me from across state. Obviously it’s made in China, 316 stainless.
    B81720F6-23E3-4B4B-A265-34457AAD993D.jpeg 85B87FB8-1F6B-447C-8C45-5E5A86EA9D6F.jpeg
    kidcampbell71 likes this.
  2. squirrel
    the date code is NOT a part number....so good luck with googling that number.
  3. Hydraulic or fluid fitting ?
    can you take a pic of the end ?
    Might be jis or din
    Chinese part numbers generally don’t cross over to North American or European numbers
  4. saltracer219
    saltracer219
    The 316 is telling you it is stainless steel 316 alloy. A good hydraulic store should be able to help.
  5. If you are trying to research the threads to determine what they are, just use a thread gauge on them.
  6. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Thread Pitch Gage 001.jpg AN Thread Size Chart 1 001.jpg I remembered seeing something like that in my fittings drawers. Seems like it came off an air tool. Couldn't find the one I thought was like yours, but found the one below. An AN/JIC cap screwed perfectly on the small end with its 37 degree taper. The female end accepted the AN/JIC fitting in the picture, but the fitting seemed a little loose and it did not go in far enough to make contact with the seat inside the main fitting. It had "AN LAK" stamped on the side of the fitting.
    Here are some reference charts you can use to compare things. What are you trying to ***emble?
  7. squirrel
    it looked to me like an air tool fitting, also.
    We love a good mystery.
  8. ekimneirbo
    ekimneirbo
    from Brooks Ky
    One more thing......You might try researching those numbers on the Alibaba web site (Asian Ebay). When I converted my lathe to single phase with a 7.5HP Chinese made motor years ago (before VFDs became popular), I blew a start capacitor. Could not find a replacement anywhere. Found it on Alibaba. Only time I ever used it.
    Nova Thug likes this.
  9. squirrel
    no matter how much you search for that date code, it won't turn into a part number.
    Paul and 31Vicky with a hemi like this.
  10. Ryans65
    Ryans65
    from Yulee FL
  11. fuzzface
    fuzzface
    bi logo stands for Brennan Industries.
  12. K13
    K13
    Looks like there should be a number under the logo for tracing the part.
    https://brennaninc.com/traceable/
    And they are right in your backyard. Headquartered in Clevland.
  13. Flathead Dave
    Flathead Dave
    from So. Cal.
    Looks chinese to me.
  14. J. A. Miller
    J. A. Miller
    from Central NY
    Ya think? LOL
  15. Beanscoot
    Beanscoot
    Remember he is being sent the pictures, so doesn't have access to the part to measure.
    Also, the bi logo looks pretty chintzy, perhaps it's just pretending to be Brennan.
  16. I think the numbers are where it was made and the date code.
    Shanghai,,,2019 August .
    Hydraulic industries logo .
    Just kidding,,,,goes with the country of origin .
    Tommy
  17. A mystery,,, I love a good mystery!!!
    Here’s the problem,
    The male end of the fitting screws into that ^^^
    Yep Some ***hat ****forbrains idea
    kidcampbell71 and VANDENPLAS like this.
  18. Roothawg
    Roothawg
  19. Hey, is Clevland in Oho? :D
    6-bangertim likes this.
  20. Flathead Dave
    Flathead Dave
    from So. Cal.
  21. Warpspeed
    Warpspeed
    Ah So ...
    Probably good Chinese metric thread made to confuse round eye Americans.
    Desoto291Hemi and kidcampbell71 like this.
  22. 5window
    5window
    Too bad it's not one of those "every thread is perfect every time" Australian threads.
  23. woodiewagon46
    woodiewagon46
    from New York
    You will almost never see anything made in China with a part number or serial number on it. Case in point, all the **** that you purchase from Harbor Freight. Sure the tools come with a parts list, but just try to find a part, or even where to get it from. Ask me how I know! The Chinese just dump this cheap **** on us and as long as they get our money, don't really care.
  24. squirrel
    Most of the modern electronic stuff I have like phones and TVs etc is made in China, and each has a serial number on it...and they mostly work pretty well.
    They'll make stuff to whatever quality level is specified. If you choose to buy the cheapest stuff, the quality level specified will be the lowest possible.
  25. 2OLD2FAST
    2OLD2FAST
    from illinois
    Pretty much like most manufacturing companies regardless of country of origin ..
    Desoto291Hemi likes this.
  26. Tickety Boo
    Tickety Boo
    from Wisconsin
    Is there room to weld a female pipe thread bung on the tube?
    Like Summit Racing part #VPE-11172
  27. Nova Thug
    Nova Thug
    from SG Vizzle
    I have some fittings that look similar. I believe their 3/8” Swagelok.
    deathrowdave likes this.
  28. I deal with aztec hydraulics they have a location in the USA
    That’s a custom made fitting
    you need to find a hydraulics company that makes tubing
    google aztec hydraulics
    Pm me if you want more info
    5window likes this.
  29. ekimneirbo
    ekimneirbo
    from Brooks Ky
    It looks like the part you originally showed with the thread isn't damaged, it's the other part that's stripped out. Can't you just dress it up and get it welded, brazed, or soldered back in place?
