Projects And So It Begins
Discussion in 'Traditional Hot Rods' started by Piewagn, Jul 14, 2019.
  1. RICH B
    RICH B
    For future reference, the lock pin holes in the axle are not tapered.
    Nailhead A-V8 and loudbang like this.
  2. Mart
    Mart
    Yes, I was about to say that. I can also confirm they are not tapered. You can clean them out with a drill. It's a standard size. Don't quote me, but I seem to remember it might be 9/16". Please check before putting a drill through.
  3. RICH B
    RICH B
    9/16" hole.
  4. Piewagn
    Piewagn
    Thanks fellas! I was hoping to get some clarification on that....I didn't want to go wailing them into place, or drilling. These things didn't even TRY to go in the other way, so just to be on the safe side, I flipped the axle. But, like I said, it gives me the opportunity to repaint the spindles and perches for some contrast. You guys are the best!!
    Tim and loudbang like this.
  5. Piewagn
    Piewagn
    This is unacceptable! It should be stated on the listing it will take this long to ship!!
  6. loudbang
    Well that sucks bigtime. :(
    1947knuck likes this.
  7. RICH B
    RICH B
    Time to start calling all the early Ford parts dealers; usually can find one with stock. I'd try Third Gen Automotive first.
  8. Piewagn
    Piewagn
    Yes it does!.....Thanks LB.....
  9. Piewagn
    Piewagn
    Tomorrow morning Rich! Thanks for the contact!!
  10. Piewagn
    Piewagn
    Laid the cowl in position today to check clearances, nothing too bad that can’t be remedied. I will be eliminating the angled bracket from my pedal assembly and making my own shaft and mounting box that will allow me to mount a more modern master cylinder and eliminate conflict with the shift linkage.....I took a couple pics to stare at, but I already have a basic idea in my head allowing me to proceed. The column drop did line right up! We shall see....input appreciated.....thanks fellas!! IMG_1775.JPG IMG_1781.JPG IMG_1778.JPG IMG_1777.JPG IMG_1780.JPG IMG_1782.JPG
  11. Piewagn
    Piewagn
    Made the shaft for brake and clutch pedals. I’m gonna make a bracket and weld it cantilevered between the pivot shaft and a mount for the master cylinder, if that makes sense. Then secure it to the chassis and cross member and trans mounts. You’ll get the picture when it’s done....I can see it in my head! Too bad you can’t take a snapshot of those images in your head....[emoji16] Thanks for checkin’ in fellas! IMG_1784.JPG IMG_1786.JPG IMG_1787.JPG IMG_1788.JPG IMG_1789.JPG
    kiwijeff, brEad, Jeff34 and 1 other person like this.
  12. loudbang
    I for one am glad nobody, especially women, can't take snapshots of those images in your head :cool:
    1947knuck, brady1929 and Piewagn like this.
  13. Piewagn
    Piewagn
    God only knows what's in there! :D:D
    loudbang and brady1929 like this.
  14. chev34ute
    chev34ute
    You can pick these up through your local hardware store as aluminium T strips. They will need dressing on the edges to remove the sharp edges and notching to the right diameter. This is what they looked like on the coupe of a local rodder last year.
  15. AmishMike
    AmishMike
    Aluminum strips between steel panels does not seem like a good plan to me. Believe combination causes galvanic corrosion. Would expect it to mess up paint job. Not sure how long that would take.
    Tim likes this.
  16. Piewagn
    Piewagn
    I'll be looking onto this! Thanks for the input.....much appreciated!!
  17. Piewagn
    Piewagn
    I does seem like dissimilar metals could be an issue, especially with a bad body-chassis ground. Snyders does sell the aluminum "T bars", but they're quite pricey...Thanks for the input!!
  18. Piewagn
    Piewagn
    Made my master cylinder bracket today! It’s just tacked for now. I need to figure how I’m gonna mount it and keep it serviceable. Should be no biggie taking some measurements and making another bracket. After I figure that out, I’ll finish welding, break the edges and tidy everything up.....happy weekend fellas!!!! IMG_1792.JPG IMG_1793.JPG Adjustments.JPG IMG_1795.JPG IMG_1796.JPG IMG_1797.JPG IMG_1798.JPG IMG_1799.JPG IMG_1800.JPG IMG_1801.JPG
  19. Piewagn
    Piewagn
    I did get my ball studs!! Now I can move forward with the front suspension and steering......Thanks Rich!!
  20. Piewagn
    Piewagn
    I'm quite sure some of you have had that moment when you went "oh s***!" Well, I have to cut the tack welds off of the master cyl bracket because I'm a jackass and remembered......I need to cut the grooves for the snap rings in the brake/clutch pedal shaft! Geezus I hate making more work for myself!
    Mart and loudbang like this.
  21. Piewagn
    Piewagn
    Took some time today to dismantle brake assembly and cut the snap ring grooves....came out nice....movin’ on! Thanks for poppin’ in fellas! IMG_1803.JPG
  22. Mart
    Mart
  23. koolbeans
    koolbeans
    Gosh, you certainly can't be lonely with the rest of us riding "the bus"...no
    Sent from my XT1710-02 using The H.A.M.B. mobile app
    Atwater Mike and loudbang like this.
  24. Piewagn
    Piewagn
    I hate being a "frequent" rider on the bus!! :D:D
  25. Piewagn
    Piewagn
    Thanks Mart!
    You know.....I'll be revisiting that steering box AGAIN! I have to go up and forward a wee bit more to gain clearance for the brake pedal and shift levers......good thing it's only tacked in place.....right? ;)
  26. Piewagn
    Piewagn
    Huge hurdle tonight! This area had me highly discouraged and quite frankly close to bagging it.....at least until I saved funds to buy a different trans and steering column, or buy the Kingshifter and clear my head. I’ve remedied my issues with clearance for shift linkage, brake pedal and even got my steering box in a location where the pitman arm is close to factory location. I modified the brake pedal, moved steering box up and forward and now have my location for master cylinder. Clutch linkage is a breeze at this point. I need to tidy up the brake pedal arm, it looked way better before I hit it with grinder to knock down some welds. I’m there fellas! It’s gravy from here.....WOO HOO!!! Thanks for stoppin’ by! IMG_1821.JPG IMG_1819.JPG IMG_1823.JPG IMG_1825.JPG IMG_1838.JPG
    Tim, brEad, So Cal Brian B and 3 others like this.
  27. loudbang
    3 on the tree gonna work LOL :)
  28. Piewagn
    Piewagn
    Tacked in place.....needs some tweeking, but this is basic location.I still have to install the wedge in the steering box mount, which will bring the column over some of course. Things can get a little rough when you’re doin’ this by yourself.....I ALWAYS need a second set of hands.....thanks for poppin’ in fellas! Adjustments.JPG
    brEad, loudbang and waxhead like this.
  29. Piewagn
    Piewagn
    Yes Sir!!! Thanks LB!!
  30. Mart
    Mart
    Just shows that you need to just have everything tacked. You might have to go through several iterations before you hit that combo that works.
    Keep up the good work.
    Mart.
