Projects '61 Falcon Street/Strip Gasser Build
Discussion in 'The Hokey Ass Message Board' started by brianf31, Nov 14, 2019.
  1. oldiron 440
    oldiron 440
    What is going to power this ride?
    Thor1 and loudbang like this.
  2. brianf31
    brianf31
    460 with D2OE-AB 429 Police Interceptor heads. It will be a pump gas affair around 10:1 CR. I'm hoping for 500 hp after working on the exhaust ports.
  3. oldiron 440
    oldiron 440
    That will be fun for awhile....
  4. brianf31
    brianf31
    I made a transmission crossmember from some old roll bar tubing lying in the corner.
  5. brianf31
    brianf31
    Yep, then you get used to it and it ain't enough!
    fauj, catdad49, Thor1 and 3 others like this.
  6. southcross2631
    southcross2631
    If you gotta rebuild you might as well make a 5:rolleyes:00 something and get after it.
  7. brianf31
    brianf31
    Ladder bar crossmember was made from 2 X 2 X 1/8 wall, with 1/8" doubler plates on all cuts. I'll run outriggers from the subframe connectors to the rockers and those will get doublers, as well. Ladder Bar Xmem.jpg
    catdad49, Thor1, brEad and 1 other person like this.
  8. brianf31
    brianf31
    I saw a post recommending Stock Car Steel for ladder bat tubing. They have quite the selection and ship fast. I used 1" OD X .156 wall for the main tubes and 3/4 OD X .156 for the braces.
    -Brent-, catdad49, Thor1 and 3 others like this.
  9. brianf31
    brianf31
    Why spend $80 on a set of ladder bar brackets when you can spend a little less than that on 3/16" flat bar and a half a day making your own?
    winr, fauj, -Brent- and 5 others like this.
  10. brianf31
    brianf31
    Stock Car Steel's 1" OD X .156 wall tubing is a bit tight to thread directly for 3/4-16 rod ends. Theoretically, it's .688 ID but the 11/16 (.688") drill bit still bit into it pretty hard.
    I didn't have the proper 45/64 (.703") bit I needed for 50% thread engagement so I had to leave it at .688". It was a tense moment when I ran that Chinese tap into the undersized hole...
    fauj, catdad49, brEad and 6 others like this.
  11. brianf31
    brianf31
    I tried my hand with the gas lens for the first time. It does a great job of flooding the area with gas so you can run your tungsten out in tight spots.
    I admire a guy that can lay a beautiful bead on angled round tubing. It ain't easy as the pros make it look. I better keep my engineering gig.
    fauj, Just Gary, catdad49 and 3 others like this.
  12. seb fontana
    seb fontana
    from ct
    Lower tube first bend back from pivot I visualize as a potential weak spot or flex piont..
  13. Thor1
    Thor1
    Brian,
    It is hard to tell from the picture, but just in case, tapping goes a lot easier if you use cutting oil or similar lubricant. I ***ume you know that, but like I said, just in case.
    Thor
    loudbang and brianf31 like this.
  14. seb fontana
    seb fontana
    from ct
    I noticed you are aiming for 50% thread; why? You should be all set with 1" od and .156 wall tube. Using a starter tap would help.
  15. brianf31
    brianf31
    Yeah, it's always ideal to have straight truss members for tension/compression loading considerations. I wanted the upper and lower tubes parallel for rod end adjustment purposes, hence the bend. The braces triangulate it well and straddle the bend so I think deflection will be minimal. Maybe I'll do a Method of Joints ****ysis on it.
    Don't have a starter tap in that size. I went with 75%. It was slow starting but worked out OK.
    catdad49, Thor1 and loudbang like this.
  16. brianf31
    brianf31
    Since this will see a lot of street duty, I went with bushings on the front pivots and angled the ladder bars in 12 degrees. That should give a sufficient amount of articulation on uneven surfaces. I'll add a panhard rod to control lateral movement.
    I'll add outriggers between the rockers and subframe connectors to stiffen up the ladder bar crossmember.
    -Brent-, catdad49, 29EHV8 and 5 others like this.
  17. brianf31
    brianf31
    I hate stripping paint but it is a good way to p*** the time when you are "working" (wink, wink) from home.
    The reward is finding lead joints.
    fauj, Just Gary, catdad49 and 5 others like this.
  18. Its coming along nicely eh! I dig the work. Can not wait to jump into my Henry J AFX build, soon...
    -Shiny
    loudbang, brianf31 and Thor1 like this.
  19. oldiron 440
    oldiron 440
    The reward is finding solid metal......
  20. loudbang
    You do know the there were never any Henry J's in any FX cl***. :rolleyes:
    seb fontana likes this.
  21. brianf31
    brianf31
    I decided to go with '65-'73 Mustang HD leaf springs and shackles. Since I moved the axle back 1" and the Mustang leafs are longer than stock, I had to make an upper shackle pivot tube. Roll bar tubing worked well after a little I.D. sanding.
    Leftover 3/4" OD ladder bar bracing tubing serve as the sliders and they were drilled out to accept 1/2-13 Grade 8 bolts. 3/16" plate was used for the floater brackets. I'll run a panhard rod to keep bending loads off the brackets. The ladder bar will have two brackets each side to put the fasteners in double shear.
  22. Thor1
    Thor1
    Brian,
    Any updates on the Falcon?
    Steve
  23. brianf31
    brianf31
    It's been slow going lately. I narrowed the rear and hard welded the ladder bar brackets and floaters. Next tasks are ladder bar bracket back plates, shock and panhard mounts. I'm waiting on a buddy to machine a rear housing straightness jig before I brace it and weld the ends on.
    Shalamo, cktasto, catdad49 and 5 others like this.
  24. brianf31
    brianf31
    I felt like a little sheet metal work so I roughed out a firewall and floor panels. 20 gage steel was used for the foot wells and .032 aluminum everywhere else.
    The set-back 460 and plans for three pedals make for some tight spaces. I had to cut a window in the panel for rear head bolt clearance. I'll probably split this whole panel so I can pull a head off without dis***embling the whole firewall.
    fauj, -Brent-, brEad and 4 others like this.
  25. 6sally6
    6sally6
    VERY nice work!! Can hardly wait for the next update.
    Question (you knew that was coming, right?!)...
    COULD you have shortened the rear axle enough that cutting out the rear quarters would not have been necessary?
    I realize the inner wheelhouse would have to be totally re-done and enlarged as well as narrowing the back half. Just looking and think'in.
    Keep up the good work.
    6sally6
  26. brianf31
    brianf31
    Thanks!
    You won't get much tire in there without back-halving the car. Even if you cut out the wheel wells, you only have 12 inches from rear subrail to the fender flange. Leaving room for suspension movement, body roll and tire removal, you'd probably be lucky to get an 8" tire back there.
  27. brianf31
    brianf31
    Trunk rot.
    I can't find patch panels for this thing so everything has to be fabbed with my rudimentary equipment.
    fauj, brEad, Randall and 6 others like this.
  28. GordonC
    GordonC
  29. catdad49
    catdad49
    Your “equipment” looks like it is up to the task so far! Great work.
    Thor1, brianf31 and loudbang like this.
  30. Boulderdash
    Boulderdash
    Looking good!!! Literally fitting a battery box on mine last night in exactly the place you have replaced that rusted section, to the RH side of the fuel tank.
    Are you retaining the stock fuel tank?
    Thor1, Gammz and loudbang like this.
