Hot Rods The 'General Mischief Coupe' Model A build
Discussion in 'The Hokey Ass Message Board' started by Jethro, Jan 3, 2020.
  1. Fitnessguy
    Fitnessguy
    Everything is looking great so far!! Hurry up and get er done, my coupe needs a cruisin partner!! Was just by your place on Monday as i had to go to Sun Peaks for some business. Would be good to finally get that meeting outta the way. We should plan a visit so i can see your build in person!
  2. Jethro
    Jethro
    Dug through the snow and found the rear backing plates. Degreased them and derusted them in citric acid for a couple of days. Did the same hole treatment except I left the area where the E brake goes alone. So , all 4 backing plates drilled and screens installed. 20200202_125758.jpg 20200202_125747.jpg 20200202_125816.jpg
  3. 392
    392
    Great work. Nice details. Function, form and straight up spot on.
    Stogy and loudbang like this.
  4. brEad
    brEad
    Backing plates look great. Very nice work.
  5. grdra1
    grdra1
    Awesome, love everything about it - maybe just a slight chop, just my opinion. Glen
  6. Jethro
    Jethro
    A little more to show . I spent about 6 hours today trying the 117Harv treatment on the stock model A axle that I 20200210_174555.jpg 20200210_174608.jpg 20200210_174627.jpg 20200210_174807.jpg have. Much respect for that man! I'm sure I've got several more hours ahead of me to get it anywhere near what his stuff looks like. I won't be polishing like he does, I am going to paint all my ch***is gloss black . It needs to be smooth though so here's where I am. I think I will drill the axle too but have a few more days of grinding and sanding to go.
  7. RMR&C
    RMR&C
    from NW Montana
    Looks great so far!
  8. A Boner
    A Boner
    Mount the body on top of the frame & chop the top! That's what I would do, anyway.
    AmishMike likes this.
  9. dumprat
    dumprat
    from b.c.
    Looks great Jeff!
    Ya figure ya will fit in it with a chop and a channel?
  10. Jethro
    Jethro
    I got lots of comfortable cars.... I can suffer a bit for this one
    Stogy, bct and loudbang like this.
  11. HOTRODRONNY
    HOTRODRONNY
    Top need that rolling bone style chop maybe channel it 2/3 rds of the frame show a little of the style
  12. Jethro
    Jethro
    Another 6 hr day , I only took it to 120 grit. It's going to be painted anyway but man what a pile o work. Drilled some holes too. I think my model A axle will look pretty good. 20200212_153919.jpg 20200212_153936.jpg 20200212_154039.jpg
  13. dumprat
    dumprat
    from b.c.
    Ya could send it down and get it dropped 4"!
  14. Fitnessguy
    Fitnessguy
    Lookin good!
    kidcampbell71 and loudbang like this.
  15. Jethro
    Jethro
    I know I can buy these but it gave me the opportunity to use my forge and anvil....love pounding hot metal! 20200217_143703.jpg 20200217_143723.jpg 20200217_143748.jpg
  16. dumprat
    dumprat
    from b.c.
    What kind of material did you make them out of Jeff?
  17. Jethro
    Jethro
    I made them from some 3/4 cold rolled that I had leftover from some past project
  18. Jethro
    Jethro
    So I had a buddy stop by the other day , he's building a model A too(29 roadster). We were talking about this and that and he mentioned that he was using a torque tube and had to shorten it. He asked me what I was going to do. I said that I was going to convert to open drive and was going to order a kit for the conversion. He looked at me and said "why not do it yourself? It's something in your wheelhouse that you can do ". I thought 'he's right' I'm just being lazy and straying from my original course of doing as much as I can with what I've got on hand.
    I went back to the house and started to research 'open drive conversion' I found a thread by Tman that guided me along (thanks Trent!) I thought I was going to have to go to town and buy a yoke and seal but I didn't want to so
    I went out to my snow covered pile and dug out an old torque tube and a piece that I saved from my firetruck build that was part of the PTO that drove the fire pump. The yoke off the PTO thing was removed and I cut off the flange end of the torque tube. I dug through my junk drawer and found a SBC timing cover seal and measured the yoke. It was bigger than the seal but I can machine it down to the same diameter as a SBC damper. The idea of using the SBC seal just presented itself but I thought if I'm in Bumhole Saskatchewan any parts place will have a seal.
    So cut , cut ,cut , machine ,weld , machine , measure , machine , fit , ***emble , dis***emble , adjust , re***emble and I got an open drive conversion that cost me absolutely NOTHING! All stuff was on hand and it's going to work....I hope!
  19. The ones I did on my touring 15 years ago have held up find and have thousands of miles on them.
    lothiandon1940, loudbang and Stogy like this.
  20. Excellent! I haven't been around here much lately but that is changing.
  21. 29Roadie
    29Roadie
    Wow, nice job man! It looks awesome.
    I know you probably know this but don't forget to put a vent in somewhere.
  22. loudbang
    Good thinking. And it looks like it was made for there. :)
  23. lothiandon1940
    lothiandon1940
    Innovation Maximus! Love it.:)
  24. Jethro
    Jethro
    I cannibalized a fitting from some old Ford that has the tee for the rear brakes and a vent that goes through the center to hold it down.
    chryslerfan55, Stogy and loudbang like this.
  25. Jethro
    Jethro
    When you flip the banjo housing to make a quick change it puts the drain plug at the top. I thought that this would be a good place to put a vent. I drilled and tapped the plug and now I have a vent and a tee for the brakes. 20200228_133722.jpg 20200228_133700.jpg 20200228_133952.jpg
  26. 29Roadie
    29Roadie
    Smart! It's looking really good.
  27. Tim
    Tim
    from KCMO
    On your open drive conversion Is the yoke held onto the shaft with that set screw? Looks good
  28. Jethro
    Jethro
    I put 2 on opposite sides and made little divots so they hopefully can't slip. I'm going to use some blue Loc***e as insurance.
    chryslerfan55, loudbang and Tim like this.
  29. Jethro
    Jethro
    OK , I know that I can buy these too , there's even a guy on here that makes a real nice looking forged pair. I am trying to stick to my original plan and make as much as I can.
    These are made from 1-1/4 square tube with the ends covered and the notch filled. I turned the shock mounts and the bushings on my lathe 20200306_125857.jpg 20200306_125917.jpg 20200306_130156.jpg 20200306_130213.jpg . They go all the way through.
  30. chop job
    chop job
    from Wisconsin
    Let's see more of this one. Great build so far.
