Technical Manual transmissions
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Aug 18, 2019.
  1. seb fontana
    seb fontana
    from ct
    One with 3 spd crash box, one with T5z od, and one with Richmond 6 spd od..
  2. arkiehotrods
    arkiehotrods
    M-20 in my Nomad.
    guthriesmith likes this.
  3. deathrowdave
    deathrowdave
    from NKy
    I have had a few top loader 4 speeds big and small spline input . NP435s , not into NV4500s . Never had one issue with the car 4 speeds , wore out 2 , 435s , NV 4500 is in process . I have a SROD 3 sp OD for my 32 . I need a shifter for it , if any one has any parts laying about .
  4. Hank37
    Hank37
    I have a Muncie M-20 wide ratio with a Olds. 3.42 rear behind my Caddy .
  5. joel
    joel
    Doug Nash 4+1 in my coupe and BW T170 3 speed OD for my 41 p/u. 1st gear is a little short with the 4+1 and a 3.23 rear. They were designed for Camaros with 3.08 rears and Mustangs with 3.00 rears.
  6. jmkporsche
    jmkporsche
    1937 LaSalle with a Borg Warner R10 overdrive in my 1929 AV8 roadster. I have not had a chance to road test this yet, but hope to have it ready for summer.
  7. The A/T vehicles I have came that way (either factory or another person built it), the '36 is a A/T but put on the back burner and might change.
    I have a few T5 cars in the works (both Hillmans and the '28), the '56 panel is a 3psd o/d stocker and the '47 is stock but will be a 3.03...still on the column.
  8. junkyardgenius
    junkyardgenius
    from Kernow
    Just put a Tremec tko behind mine. Using a Ram clutch & hydraulic throwout bearing. All seems to be working ok on my hi tech stand. 20200220_120326.jpg
    Desoto291Hemi likes this.
  9. Muttley
    Muttley
    T-10 4-speed with a Hurst Comp/Plus.
  10. deucemac
    deucemac
    I guess I have the oddball setup. I have an O/D three speed from a 76 AMC Pacer in my deuce roadster, behind a 354 hemi. The transmission is a Ford full syncro 3 speed top loader and the overdrive is a Lay**** De Normanville unit ( Gearvendors nowadays). AMC used that combination for 75, 76, and 77, Gremlins, Hornets, and Pacers. I used a Wilcap adapter for hemi to Ford trans and have a rocker switch on the dash to engage the overdrive. I put a Jeep T 150 top cover on it and it comes through the floor less than an inch from where the original deuce shifter did. The Trans and overdrive work perfectly together and my final drive is Ford 9" 3:70 with Trac Lok. All the parts are readily available except for the adapter from the Ford box to the Lay**** o/d. Rare combination to find but great performance. A guy in the LA Roadsters had one in his deuce using the side shift and a 40 column. He drove it twice around the perimeter of the USA without any problems. I even made a bracket and bolted a 36 parking brake handle on the side of the trans. But, as I said it's a rare combination.
    j-jock likes this.
  11. Crayons
    Crayons
    T-85 w/overdrive in Olds powered Model A, Hurst Synco-Mesh shifter. T-5 in SBC powered shoebox, AOD in Merc. 20151019_135942.jpg
    Fordors likes this.
  12. klawockvet
    klawockvet
    Do you have a manual transmission in your current ride? Yes. I have a T5 in my 40 Sedan behind a 427 SBF and an RTS behind my B motor in the roadster. I have a stock sideshift in my 47 and plan to use a stock sideshift in my 40 coupe, which is my next project. I come from the late HAMB era (1964) when the BM Hydros and Mopar Automatics were kicking *** but I hung in there with the manuals and I'm still there.
    If you were planning to use a manual transmission in a future build which one would you use?
    Real Hot Rods have three pedals. Next project is a 40 coupe with a side shift original. If I live long enough the following project will be a 30/31 Roadster with the 39 trans sitting in my storage area.
  13. lippy
    lippy
    from Ks
    I'd put an 833 mopar 4 spd behind a Hemi. Keep it Mopar. ;) Lippy
    das858 and Desoto291Hemi like this.
  14. OLSKOOL57
    OLSKOOL57
    B/W T-10 4Spd. behind SBC for my 57 Chevy................. If I can ever get it done.
    chevy57dude likes this.
  15. -Brent-
    -Brent-
    Rock crusher!!!
  16. A 2 B
    A 2 B
    from SW Ontario
    Guilty... A non-HAMB approved Modern Driveline T5 package with the forward shift, behind the flattie for my avatar project. It is geared 2.95, 1.94, 1.34, 1, with a .63 overdrive and a 3.80 rear. I just want to keep up with the traffic but am wondering if I will have to shift into 2nd before I get across the intersection, from a stop. I will find out soon enough.
  17. JUNK ROD
    JUNK ROD
    wow thats crazy!!!!
  18. Gman0046
    Gman0046
    M-21 close ratio or an M-22 Rock Crusher.
  19. Finn Jensen
    Finn Jensen
    I wouldn't run a close-ratio Muncie, unless you have the rear-axle ratio to support it. I ran an original numbers-correct M-22 for awhile in front of a 4.11 rear. That combination was just too hard on the clutch, even with that rear ratio. It might have been okay with mild street driving.
    I pulled the transmission and replaced it with a new wide-ratio M-22 Muncie. Big improvement. I sold my original M-22 before I would have damaged it from the stress, to a guy who was looking for numbers-correct originality.
  20. bowie
    bowie
    Like my tag line says... wouldn’t run anything but one in a Hot Rod. The Vette has its original M20 with 3:08’s, the 3W runs a 1961T10 with 4:11’s, and the ‘57 uses an M21 with 3:55’s. All with BIG letter Hurst Comp Plus shifters : 4CE5EFA2-D15A-4372-AD60-3FBDBAF55771.jpeg 83054F16-F30F-4A39-BC5A-74B731A612AB.jpeg 4670440B-C00C-4EF8-839A-C40696AD788C.jpeg
    Moriarity and chevy57dude like this.
  21. chevy57dude
    chevy57dude
    Love the monkey paw^
    bowie likes this.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    T10 4 speed in the Car Craft Dream Rod
    00134F7A-3BC0-42A5-BC96-A593DB0D01A4.jpeg 047827B8-2AB8-4CB4-95BE-275DAFDFA626.jpeg
    bowie likes this.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    Sword shifted chrome plated 39 Ford 3 speed behind the 49 331 caddy in my Outlaw clone
    EA59021E-5265-42E7-BA1E-FB0400F583F7.jpeg E532FD52-4281-44FE-8CA6-ED75B8141BE4.jpeg
    bowie likes this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    Hurst shifted wide ratio Muncie in my man a fre equipped corvette
    E5BDA3FC-EEDC-4841-BAED-725EA1717AE5.jpeg 617ECA88-F15A-446D-9C71-5FA406BE30DC.jpeg DF5F023A-CFF6-488A-A69F-96FFC04DC36F.jpeg
    chevy57dude and bowie like this.
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    Ansen shifted 55 3 speed overdrive behind a 364 nailhead in Miss Elegance
    510E28E5-ADE0-42E2-9B46-8BA52F6F70A5.jpeg 31E1873F-883D-4B21-98AF-75339FACB3DC.jpeg 92643CAB-5FDF-411E-86A9-BB71BFDAFCAB.jpeg
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    Hurst shifted HD Muncie 3 speed behind the 283 in the Astorian
    81CD4767-2478-4540-AD30-250503511AEA.jpeg 222591C2-9B5A-4A0C-BB19-F91708BCF940.jpeg
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    40 Ford 3 speed behind the 49 331 caddy in my 40 coupe
    CBF4E604-CB26-419C-A1FD-0BF06C8B72E8.jpeg E1CF93D7-A9F1-4270-8715-6ED077B5E7B2.jpeg
  28. G'day, I haven't decided for sure what transmission that I am going to use in the 59 Vette but have a few in mind. I am planning on running an alloy 427 small block if the money for the block comes through so it should have a bit of power. On one hand I have a new Richmond Gear 6 speed that a friend provided. I also have a fresh Turbo 475 that is set up for more power than I will ever put through it.
    The Turbo 475 is quite a story itself. I bought it at the Pomona swap meet before I got sick. We met the seller at his transmission shop the next day and he had it all torn down and packaged in small boxes. We did not take the case, valve body, or converter. We were flying first cl*** so had four suit cases. Could you imagine the faces on the TSA guys when they x-rayed those cases.
    I am leaning towards the Richmond as I have had good luck with the 4+1 versions. I also have a couple of the 4+3 Corvette trannies handing around but they are not fresh. Also have the Turbo 350 we built for the drag car and didn't use. Yes, I am a hoarder and have more transmissions than I can ever deal with.
  29. triumph 1
    triumph 1
    M20 Muncie 4speed in my ‘32 tudor
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    Hurst shifted Muncie 4 speed in the Deals wheels 57
    D43105A8-F677-4942-A44C-7365F8CF1ADF.jpeg 33E76D7B-2344-477F-AFA6-ECB8B343A691.jpeg
    chevy57dude and rusty valley like this.
