  1. That's what I said about my photos!
    Sent from my Pixel 3a XL using The H.A.M.B. mobile app
  2. 40ragtopdown
    40ragtopdown
  3. 40ragtopdown
    40ragtopdown
  4. WB69
    WB69
    from Kansas
    Wow, first thing that I noticed. That's some crazy welding right there.
  5. HJmaniac
    HJmaniac
    chryslerfan55, Deuces and loudbang like this.
  6. topher5150
    topher5150
    JUNK ROD, loudbang and chryslerfan55 like this.
  7. Deuces
    Deuces
    :D:D:D:D:D
  8. Josh1226
    Josh1226
  9. lippy
    lippy
    from Ks
  10. Deuces, lothiandon1940 and loudbang like this.
  11. 40ragtopdown
    40ragtopdown
    No I just shared them .
  12. 40ragtopdown
    40ragtopdown
  13. 40ragtopdown
    40ragtopdown
  14. 40ragtopdown
    40ragtopdown
  15. Rich S. and chryslerfan55 like this.
  16. b-body-bob
    b-body-bob
    Deuces, chevy57dude, wicarnut and 3 others like this.
  17. loudbang
  18. lippy
    lippy
    from Ks
  19. 41 GMC K-18
    41 GMC K-18
    Years ago down at the Puyallup fairgrounds at one of the Goodguy's cars shows, I shot this picture, notice who has the Edelbrock bag, lost children indeed!
    loner2, Deuces, wicarnut and 5 others like this.
  20. Ron Brown
    Ron Brown
    7FCB7248-35D9-495D-9F50-BFFF5734BB7D.jpeg 'you can trust your car to the man that wears the star"
  21. loudbang
    Early Wood Bros
    Note the 348 engine
  22. Almostdone
    Almostdone
  23. HJmaniac
    HJmaniac
    loner2, j hansen, loudbang and 2 others like this.
  24. Experimental max wedge intake.
    Deuces, loudbang, JUNK ROD and 2 others like this.
  25. 40ragtopdown
    40ragtopdown
    Thanks I had never seen one.
  26. 40ragtopdown
    40ragtopdown
  27. HJmaniac
    HJmaniac
    https://www.hotrod.com/articles/mop...05-max-wedge-sixteen-pack-cross-ram-manifold/
    Max Wedge Engine Sixteen Pack Cross Ram Manifold
    The Mythical Max Wedge "Sixteen Pack" Cross-Ram
    Steve Magnantewriter
    Mar 10, 2010
    If you're like us, nothing fascinates you more than factory prototype cars and parts, especially stuff that never reached the production stage. These dead ends offer the teasing allure of what might have been and are just too much to handle for major league car freaks. So when we first saw the grainy photos of what appears to be a four-carb Max Wedge induction system, we ***umed the thing was some type of doomsday device hatched by Chrysler engineers in case the early '60s factory Super Stock wars went nuclear. But first appearances can be deceiving.
    Today we all know the production Max Wedge of 1962 - 1964 was only offered with dual Carter AFB four-barrel carburetors arranged in a cross-ram layout. With 15-inch tapered p***ages and generous plenum volumes, the cross-ram manifold was tuned to take advantage of naturally occurring resonating pulses within the intake tract to deliver a slight supercharging effect above 5,500 rpm-all the while remaining compact enough to fit under stock first generation B-Body sheetmetal.
    The '62 413 and '63 Stage II 426 Max Wedges (Dodge Ramcharger and Plymouth Super Stock) featured dual Carter 3447 carbs rated at 525 cfm, along with special solid-lifter cams, high-speed valvesprings, adjustable rocker arms, big port heads, and streamlined iron exhaust manifolds. They were highly effective in combating the Pontiac 421s, Chevy 409s and Ford 406s and 427s in the other lane. But just for good measure, the Stage III 426-introduced in late 1963-upped the ante with a pair of huge Carter 3705s rated at a whopping 750 cfm each.
    Think about that. The Stage III 426's dual 750s were capable of supplying a combined 1,500 cfm at WOT. Straddling a 426 cube Wedge, that should be plenty to feed the fires even at crankshaft speeds in excess of 7,000 rpm, which brings us to the crazy induction setup under discussion here. With a total of four Carter AFB four-barrel carburetors, it's got sixteen throttle plates. Lets whimsically call it the Max Wedge Sixteen Pack from here on-even if it predates the actual '691/2 Six Pack by several years.
    When accomplished NHRA Stock and Super Stock racer Bob Mazzolini mentioned he owned a complete four carburetor cross-ram a decade ago and has photos to prove it, we jumped on the chance for a look. As you'll see in the following photos, the thing looks exactly like a Chrysler item. It has the same shapes, contours, core plugs, and general characteristics as any standard Max Wedge cross-ram-except for those extra carbs.
    Mazzolini tells us he bought it from a seller in California around 1989 as part of a Max Wedge parts stash. It arrived exactly as we see it in these photos, complete with four unmolested Carter 3447 Max Wedge carburetors that still had their choke plates intact. Bob says he resisted the urge to scavenge the rare carburetors-a super hot commodity a**** cl*** drag racers and restorers alike.
    Though he had no immediate use for it, he marveled at its potential and even brought it along to numerous NHRA national events and points meets as a conversation piece. Observers agreed that it appeared to be a Chrysler item but many eyebrows were raised at the sighting of the integrally cast Navarro logo almost hidden between the carburetors on each bank. After a few years of blowing minds, Mazzolini sold it to a collector in Michigan and that was the last we've seen of it.
    Mazzoilin says, "I placed the induction setup on a '64 Dodge B-Body, and the throttle shaft of the p***enger side rear carburetor (shown here) hit the firewall. If I was serious about installing it and running it, a small amount of hammer work would have provided needed clearance." Based on Bob's photos and observations, we can conclude that this was definitely an aftermarket item produced by Navarro-not some top secret factory wonder weapon.
    Borrowing a stock Max Wedge cross-ram from Max Wedge fanatic Bob Mosher, we placed the pattern atop the manifold and the mystery of the four carb cross-ram was solved.
    It turns out that Barney Navarro cast an unknown number of these wild four carburetor Max Wedge intake manifolds in the early '60s. Most likely they were made for land speed and marine use. But that's about all we know at this point. Check out the photos and captions and see how the story unfolds.
    It's Not One of Ours: Chrysler Guys Speak Out
    To see if anybody at Chrysler knew of a clandestine collaboration between the factory and Navarro on the quad-carburetor cross-ram, we showed several high ranking ex-Chrysler engineers photos and asked them for their input. These guys weren't only Max Wedge racers, they designed the Max Wedge. Here's what they had to say:
    Bill Shope, former Ram Chargers member (1958) and Chrysler ram tuning engineer: "That's an interesting design! It reminds me of the fabricated manifold Barnes Daniels used on his E/G***er. His was more akin to the Weber designs, but he used 8 Carter side draft carburetors. To sum up, it's an interesting design, but no, I don't think the unit shown in the pictures came from within Chrysler."
    Barnes Daniels, former Ram Chargers member (1958-1963) and Chrysler engineer: "I've never seen anything like it. Not sure how a four carburetor cross-ram like the Navarro unit would work, but we sure didn't make it."
    Bill Weertman, former Chrysler ***istant Chief Engineer- Engines: "That quartet of four-barrel carburetors is certainly an impressive top end for any engine. No shortage of inlet air capacity-at least not through the carbs. Some dyno work would be needed to see if those extra throats can actually translate to a difference at the flywheel. The photos were the first time I have ever seen or even heard about the setup so I can't help with any additional information. Perhaps Tom Hoover has some knowledge about it".
    Though solid evidence is evasive, clues indicate the Navarro four carb cross-ram was made for guys like Norm Thatcher. At the age of 70, Thatcher set a series of land speed records in Dodge and Plymouth products during the early Sixties. Thatcher (on right) owned a repair shop in Van Nuys, California, and was a regular contestant at Bonneville and Muroc. If anybody can shed more light on the mysterious Navarro four carb cross ram, we're all ears.
  28. 40ragtopdown
    40ragtopdown
  29. Ron Brown
    Ron Brown
