Technical ***March 2020 Banger Meet Thread***
Discussion in 'Traditional Hot Rods' started by Jiminy, Feb 29, 2020.
  1. Jiminy
    Jiminy
    Coming Events: (PM Jiminy with additions/corrections)
    February 2nd
    Hope the groundhog doesn't see his shadow
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. winduptoy
    winduptoy
    Jet96 likes this.
  3. noboD
    noboD
    It's still February here.
    Garagekulture13 likes this.
  4. denis4x4
    denis4x4
    from Colorado
    Maybe......maybe not
  5. Took the coupe for a ride this morning
    Nice day for it
    March already 20 is flying on by
  6. IMG_20200202_183426_976.jpg IMG_20200202_183426_981.jpg 20200205_070502.jpg Finished my part of the Speedster a few weeks ago.
    Working on a narrowed 23T with an early decklid now. 20200220_174048.jpg And I have an awesome fun doodlebug for sale if anyone is interested.
    edfueler, mdimages, 282doorUK and 9 others like this.
  7. rwrj
    rwrj
    from SW Ga
    Checking in. Got the dual SU H6's installed and running pretty well.
    edfueler, Old Dawg, Dannerr and 6 others like this.
  8. Binger
    Binger
    from wyoming
    Checking in for the month. not much new going on in Cheyoming. The Wife and I were able to put 100 miles on our coupe Friday and Saturday. In Wyoming during winter you have to take advantage of the rare 50 degree day with dry streets when they come. Looking for a Dual intake that sweeps up to clear a lake style header. Does anybody have something? I am probably going to get one of the nice ones gear drive makes but thought I would see if anybody here has one for sale. I would also be interested in a single intake that would work with a lake header also.
    Jet96 and winduptoy like this.
  9. Binger
    Binger
    from wyoming
    Here is an example of the header I have that I need an intake for. Please let me know if you want to sell a single or dual that will work. Thanks.
  10. walls
    walls
    I know this isn’t exactly banger specific, but figured you guys would know.
    The barb fitting is what I removed from my Winfield carb.
    I wanted to use the stock gas line, but it doesn’t seem to seat properly in the carb.
    I don’t want to over tighten it and ruin the threads.
    What am I doing wrong here?
    The model A supply houses just call the fitting a 9/16 hex- what is the proper name for this fitting and are these two fittings effectively the same?
    Thanks 23A38808-4230-4C80-A4B6-748E5CD007B5.jpeg 34F1E8C1-EAF2-44ED-A8FE-55C7E95FE6EE.jpeg
    winduptoy likes this.
  11. Dustyp489
    Dustyp489
    Checking in, swap meets start soon need to move some A parts
  12. Johnny Nitro
    Johnny Nitro
    from Chicago
    Woohoo! Can’t wait to see the updates on everyone’s rides!
  13. 62pan
    62pan
    From what I seen Winfield used two different size fittings, 1/8 or 1/4 npt fuel inlet. You should be able to find these at Napa. If yours leaks the seat could be scored or you have to much tubing exposed and the furrel is not letting the fitting tighten all the way. I would not want a solid line from fire wall to carb. Too much body movement.
    winduptoy and Old Dawg like this.
  14. V4F
    V4F
    from middle ca.
    am I getting old , or is time going faster ?
  15. walls
    walls
    Thanks
    I was going to run the hard line with a rubber connection right before the carb.
    I’ll post it here once up and running.
  16. fourd
    fourd
    from Colorado
    March in Colorado, I love it! It was sunny and 60+ Saturday and then blowing snow sideways yesterday.
    I would like to take my car to the Antique Nationals in May. Having never run a 1/4 mile race with my car I am searching for gear ratio recommendations (quick change rear). Charts tell me 3.58 for 1/4 mile with my ***umptions plugged in. Any recommendations for a typical hopped up banger?
    I have:3.78 R&P with a quick change rear, current gear set @ 4.68. 31" Dia Tires, V8 Trans w/ 28t gear set, OHV 4 port head. (I have a 25t trans gear set on my shelf that I know nothing about)
    barrnone50, winduptoy, 97 and 2 others like this.
  17. Hank56
    Hank56
    from NC
    Plugging along...still have lots to do but it’s getting there... 77C87E69-6735-45C3-8B01-9E5798B0CE81.jpeg
  18. luckylou
    luckylou
    from canada
    Installed a tattersfeild Intake and stromberg carb today,,,, I have a model b distributor to put in my model. Pickup, do I need to get a model b distributor driveshafe? Seems like the model a one is one piece.? . Can someone enlighten me on this?
    Dannerr likes this.
  19. Steve,
    Yes, you are getting older and time is flying by.
    But, the older I get the faster I was...........that's my story and I am sticking to it!
    J
  20. Checking in - this made me chuckle, @johnneilson! Thanx. :D
    Steve @V4F, we're all getting older - so you're not alone in the matter.;)
    Looks good!
  21. 97
    97
    I don't know what the Winfield size is , however I know the
    Model A Zenith and Stromberg 97, Holley 94 all use an AN 1/2" fitting , 20tpi thread, outside diameter is 12.7mm
    1/8 NPT is 27tpi , od 10.29mm ,.
    and 1/4 NPT is 18tpi. outside diameter is 13.72mm
    I know measuring in mm is foreign to most Americans ( especially talking about old cars , but that is how my charts read . The difference in diameter of 1mm between AN 1/2" and NPTF 1/4 is about .040" (40 thou) just enough to give you a headache.
    NPT - American Taper Pipe Thread
    = National Pipe Taper
    NPTF - American Taper Pipe Thread for Dryseal joint without sealant compound
    = National Pipe Taper Fuel
    NPT and NPTF appear to be identical. Both have the same pitch diameter at the top of the hole of the internal thread or end of the pipe on external threads and both have the same thread lengths or depths. However, there is a subtle difference in the root and crest diameters of the threads.
    The sealing tapers are possibly slightly different on the two fittings , common angles are 30 and 37 degrees, which is quite hard to see unless you have a gauge of some kind.
  22. rwrj
    rwrj
    from SW Ga
    I just used the Model A shaft. Seems to be working fine. If that's not right, hopefully someone will chime in.
    Dannerr likes this.
  23. 62pan
    62pan
    I just put an aircraft oil pressure gauge in my car and not knowing, those AN fittings drove me nuts till I got it sorted out. After reading your reply I went and checked the Winfield parts catalog as I was going by memory. He made two fuel screening inlets. One 1/8 and one 1/4.
    97 and Dannerr like this.
  24. railcarmover
    railcarmover
    Picked up a hand full of 1/2 NF phosphate coated grade 8 'tall' nuts yesterday..now I have main bearing bolt nuts with great grip for the rest of my natural life for 6 dollars and eighty two cents..woo-hoo
    Jet96, winduptoy and Dannerr like this.
  25. V4F
    V4F
    from middle ca.
    john , your saying BOTH are happening at the same time ! I used to be fast also , but cant remember when ………..
  26. Yeah! But you gotta remember: "The First Liar Doesn't have a Chance"! And, "Maybe that wasn't the way it was; but that's the way it should'a been"!
    edfueler, Dannerr and Jet96 like this.
  27. montereyawards (2017_12_27 02_23_16 UTC).jpeg "Of all the Gin Mills, in all the towns all over the World; she had to walk into mine!"
    That guy! Ever since he was a kid, would do anything for a trophy!
    Jet96 and railcarmover like this.
  28. jim1932
    jim1932
    Had a good day and got a ***le for my truck. Used the old CA pinkslip that seller signed in 1980 and has been p***ed through a number of people (Truck and pink slip) since then. Wrote my name in the buyer section and went in with all my applications forms filled in correctly and the nice lady OK'ed it after struggling to find info on the pink slip...."EL thats an El camino. 1930 ford? no Maam thats a model A.....
    Old Dawg, Dannerr, Jet96 and 2 others like this.
  29. railcarmover
    railcarmover
    Ive found that a smooth and caring line of ******** works wonders at the State Home for the Incompetent..gotta love the fools who blurt out "there's a vin number on the frame"
  30. CGkidd
    CGkidd
    Anyone on here have a B crank they would sell? Non counter weight will work. Mine ended up being cracked.
    Eric
    Sent from my E6910 using The H.A.M.B. mobile app
