Projects Can Anyone Identify this Old Frame?
Discussion in 'Traditional Hot Rods' started by Wavetrain75, Feb 29, 2020.
  1. Wavetrain75
    Wavetrain75
    This is in the field behind our house, reasonably complete and begging to be made into a speedster.
    DCB7E998-5660-4607-AD7E-47916F33C6FE.jpeg 2085BEA6-4E87-4C55-B553-3A5A0C07D650.jpeg 1CFC83F0-EFAE-47F0-A765-2BAFC3B1FB15.jpeg 9F65A36F-B53F-4A6A-B4D1-F685820F3C9E.jpeg 7D1A9589-68A8-4B9D-99ED-81EC51BA0A77.jpeg
  2. sloppy jalopies
    sloppy jalopies
    the boys here tell me this is '28-'29 chebby… is the shock the same ?
    chryslerfan55 and kidcampbell71 like this.
  3. 31Dodger
    31Dodger
    Looks like it to me.
  4. rusty valley
    rusty valley
    not a chevy, no torque tube. unusual to see drop center rims with wood spokes.
  5. Doublepumper
    Doublepumper
    from OR-WA, USA
    Those six lug wheels with that style cap retainer....look GM to me.
  6. harpo1313
    harpo1313
    from wareham,ma
    That spoke wheel would look nice hanging on the wall in my living room.
  7. tb33anda3rd
    tb33anda3rd
    wouldn't the round front axle be dodge?
    chryslerfan55 and VANDENPLAS like this.
  8. The round pinion flange looks a little "Dodgy" to me.
    VANDENPLAS likes this.
  9. scotts52
    scotts52
    Early GMC had "GMC" on the back of the axle housing. Also the front crossmember doesn't look right for GMC. I have a 29 and this doesn't resemble mine.
  10. 41 GMC K-18
    41 GMC K-18
  11. stillrunners
    stillrunners
    from dallas
    International.....or Dodge ?
  12. :rolleyes:
    yup
  13. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Pull that baby out so we can see the front axle.....
  14. studebakerjoe
    studebakerjoe
    See if you can find a number on those shock absorbers as that will narrow it down too. Apple Hydraulics has a chart with part number range and what used them. And like others have said a clear pic of that front axle would help too.
  15. Wavetrain75
    Wavetrain75
    If I had room for it I would have already made an offer on it, (they have an ***ortment of rotten lumber, old tires and rusty barb wire, I was going to offer to haul it all away and clean up the area a bit. Failing that, $100) I might make an offer on it anyway but I don't want to get them all worked up thinking they have a priceless piece of automotive history.
    But there's some good information here that gives me an idea where to look on the frame for better identification.
  16. Wavetrain75
    Wavetrain75
    I'll check.
  17. 270ci
    270ci
    Wheels look Buick to me. And the frame in back has some Buick like features. I'll suggest around 1929-1931 Buick.
  18. studebakerjoe
    studebakerjoe
    270, the rear axle is open drive not like a Buick torque tube.
  19. Desmodromic
    Desmodromic
    Shock arm is different than SJ's maybe-chebby, axle end rotated 90 degrees at connecting link. Shock body design is probably common to many marques.
    I can't clearly see what tb33+ is looking at to think it's a tube axle. If so, it could be Franklin, Hupmobile, etc., etc., as well as all Mopars. Is it an Elliott type axle? That would probably put it in the 20s.
    If in reasonable shape, rails would be excellent for a vintage Indy/"Big Car" project.
    Procure it, break it down, save mainly the rails (won't take up much room), maybe the cross members if they can be shortened; toss out the front and rear axle, or sell them to your buddies for trailers, or research to see if they are Duesenburg or Rolls Royce, etc., then put them in Hemmings; clean, paint, stain and varnish the wheels, sell one to harpo, use one for a hose reel, sell or set up on either side of your driveway entrance the other two.
    Tell the owner you "could use it for a trailer I'm thinking of building, although I'd probably have to replace the running gear with more modern axle/wheels", not "I'm building a Maserati Indy car replica".
    Hot Rods Ta Hell likes this.
  20. 270ci
    270ci
    Studebakerjoe, I see a rear that has an open drive "look" to it, but it also appears identical to a 30 Buick Marquette rear.
    However, the Marquette wood wheels used 10 spokes, while the frame in question has the 12 short wood spoke wheels typical of Buicks around 1930, so I'll admit I'm not sure what we're looking at.
  21. tb33anda3rd
    tb33anda3rd
    front axle looks round in the photo, not an I-beam.
  22. studebakerjoe
    studebakerjoe
    7D1A9589-68A8-4B9D-99ED-81EC51BA0A77.jpg Desmo heres a better look at why he thinks tube axle. 270, we also don't know what's happened to it over the years. It could be a mix of parts as well.
    31Dodger and tb33anda3rd like this.
  23. tb33anda3rd
    tb33anda3rd
    I was thinking the same thing.
    31Dodger likes this.
  24. greybeard360
    greybeard360
    1930 Buick Marquette had open driveshaft and the frame looks correct. 1929 big Buick had different trans crossmember.
  25. studebakerjoe
    studebakerjoe
    1930 Buick Marquette Booklet-19.jpg greybeard, I agree with the Marquette rear, but the front shock setup is different and there are 10 spokes Marquette vs 12 on this frame. Maybe Lasalle? Or Viking or?
  26. 270ci
    270ci
    Had the same thoughts of a Lasalle, because they also had wheels that look like the ones on the mystery frame.
  27. Desmodromic
    Desmodromic
    I have a 1931 Buick; has wood spoked wheels, ten spokes as I recall, so not likely compatible with the 6 "lug" hub shown in the pics. Also, I don't think they were drop centers. Not very accessible, or I'd go take some pictures. I plan on building a vintage Indy racer using the rails, eventually (Future Project No. 17).
  28. studebakerjoe
    studebakerjoe
    Desmo, any plans for the rear axle?
  29. studebakerjoe
    studebakerjoe
    ebay188530.jpg 71885_Front_3-4_Web.jpg 1931 Oldsmobile? 12 spoke wooden wheels. Open drive rear axle. The ch***is pic isnt great but the axle ends look round like in the op pic and the front shocks are the same style with the same type arm and link. What does evveryone think?
    hotrodjack33 and 270ci like this.
  30. sloppy jalopies
    sloppy jalopies
    '30 Oldsmobile… neat...
    Some of the guys use those early GM frames under model As and '32-'34 trucks as they tend to follow the body's shape more than a stock A... and they have a very handy frame kick up...
    Weld on a pair of model A frame horns, an A crossmember and you have a cool hot rod frame...
    and mine was real cheap...
    I have another '29-'30 chebby-ish frame cut off just before the kicks, $25.00...
    tb33anda3rd likes this.
