Projects Old school cool 248 Gmc
Discussion in 'The Hokey Ass Message Board' started by Neb Hillbilly, Dec 26, 2019.
  1. f2504x4
    f2504x4
    scotty t and Halfdozen like this.
  2. f2504x4
    f2504x4
    I just have unpolished one in stock right now.
    My polisher retired on me.
  3. Neb Hillbilly
    Neb Hillbilly
  4. f2504x4
    f2504x4
    Unpolished valve cover
    $300
    The valve cover and side cover unpolished
    $525
    Shipping $20
    Parts made and machined in the USA
    Tman likes this.
  5. Neb Hillbilly
    Neb Hillbilly
    Not much progress this weekend. Shop is busy so they haven't had a chance to grind my crank. Drilled and tapped my block for full filter oiling. Found a 84 s-10 2.8 with a t-5 for $200. Pulled the ****** and iron piled the v6 after pulling the dist. Not sure if the t-5 is strong enough for a 200hp GMC or not but I will likely try it with the Jeep 10 spline input. Has to be better than the SM420 the truck has.
    Pulled the 248 short block out of my quansit down on my farm. Wasn't stuck after 7 years with no head in a dirt floor shed, kind of amazing. Removed the Bellhousing, flywheel clutch and pressure plate and got it on the stand so I can tear it down for the pan, oil pump, pick up etc. IMG_20200222_105533.jpeg IMG_20200222_105540.jpeg IMG_20200222_153803.jpeg IMG_20200223_125046.jpeg IMG_20200223_125052.jpeg IMG_20200223_145742.jpeg IMG_20200223_145748.jpeg IMG_20200223_153106.jpeg
    Sent from my S48c using The H.A.M.B. mobile app
  6. LAROKE
    LAROKE
    I've got a modified 302 Jimmy pushing about 230 hp and 300 lb-ft thru a 11" Hayes street/strip clutch to a Camaro T5 with S10 tailshaft and rebuilt with world cl*** parts. It resides in my '37 Chevy pickup. I've bangshifted it more than once and the transmission has never complained. The truck is down for rebuilding since it blew a head gasket at 80,000 miles. All the T5 needs is a new paint job.
  7. Neb Hillbilly
    Neb Hillbilly
    I have been looking for a camaro T5 for parts. This one feels nice shifting but it is the weakest t5
    LAROKE likes this.
  8. Neb Hillbilly
    Neb Hillbilly
    Slipped down after work to the shop and pulled the oil pan and pump. Slipped the pan in the cooker and pump in the hot tank IMG_20200224_163534.jpeg IMG_20200224_163539.jpeg IMG_20200224_170754.jpeg IMG_20200224_172023.jpeg
    loudbang, Six Ball and 302GMC like this.
  9. Six Ball
    Six Ball
    from Nevada
    I have an S-10 T5 behind a healthy 270. It's been there for several years and gets used hard daily. No problems. It has the good stuff inside. Just one thing I wouldn't do again. I got a T5 without the Chevy bolt pattern and had to make an adapter. A couple of bolts interfered so I had to whittle on the case but the 3/8" adapter took care of the extra shaft length.
  10. Neb Hillbilly
    Neb Hillbilly
  11. Neb Hillbilly
    Neb Hillbilly
    I have been going in at 4:30am to my buddy's shop to play before work. Cleaned the oil pump and Mallory dual point up. Decided to keep the Vac brake advance for now. Blasted my Nicson quick before it goes in the shot blaster. IMG_20200227_050544.jpeg IMG_20200227_050550.jpeg IMG_20200227_050557.jpeg IMG_20200227_051129.jpeg IMG_20200227_050612.jpeg IMG_20200227_050606.jpeg IMG_20200227_052604.jpeg IMG_20200227_060606.jpeg
  12. Neb Hillbilly
    Neb Hillbilly
    I forgot to say the weight and spring on the bottom are what advances the timing when the brake is pulled off by vacuum. The old instructions I found on here show that if you remove the brake to use a stiffer 24750A spring on that bottom weight that were used in the YC dist. The chances of finding that spring now are slim and none. My buddy has a dist machine so we can map out the timing for the mech and vac. The spring I have circled appears to add stiffness to the weight advance rate. The outside pin can be moved adding tension or relaxing the spring. Does anyone have more complete instructions that explain how to quicken slow the advance rate and limit total mechanical advance on these old Mallorys?
    64zim likes this.
  13. Neb Hillbilly
    Neb Hillbilly
    64zim, Six Ball and LAROKE like this.
  14. Neb Hillbilly
    Neb Hillbilly
    64zim and waxhead like this.
  15. 302GMC
    302GMC
    from Idaho
    You do nice work ! I always welded a wing nut to the screw in the holddown bracket so I didn't have to struggle with a screwdriver.
    LAROKE and Six Ball like this.
  16. Neb Hillbilly
    Neb Hillbilly
    Thanks! I will for sure do that.
  17. LAROKE
    LAROKE
    6-bangertim and lothiandon1940 like this.
  18. Neb Hillbilly
    Neb Hillbilly
    yes but the nut is also captured and the threads peened to prevent it from coming all the way off.
  19. Neb Hillbilly
    Neb Hillbilly
    Took the day off for a DDS appointment so I slipped down for a few min before heading to the appointment. Nicson intake shot blasted. The Mallory cap clips were Rusty and I don't know a way to black oxide them. I blasted them then used gun blueing. Not sure how it will hold up but they look good for now. Last pic is them coated in wd40 till tomorrow. IMG_20200227_060606.jpeg IMG_20200228_092412.jpeg IMG_20200228_093332.jpeg IMG_20200228_093822.jpeg IMG_20200228_094016.jpeg IMG_20200228_094558.jpeg
    typo41, LAROKE, 302GMC and 1 other person like this.
  20. sololobo
    sololobo
    What a cool build, I love these GMC motors. Good to see a Nebraska build going on. FPM folks are the real cool kids, making beautiful products for years. Best O Luck with this project.
  21. ebs121781
    ebs121781
    from Spring, TX
    Subscribed, taking notes, learning... I'm building a 235 Chevy for my 50 pickup. There's a GMC 270 in my buddy's storage building that has my name on it, but I don't have a place for it to live right now. Regardless, I'm very interested in seeing your project come along.
  22. 302GMC
    302GMC
    from Idaho
    That cold blue will take a better set if the clips are heated with a torch or set on a stove burner before drowning in the solution ...
    Neb Hillbilly likes this.
  23. Neb Hillbilly
    Neb Hillbilly
    These turned very dark after 3 times through the bath. I was just dipping them quick on each side then let them set a min before washing off in water, then repeated twice more Still I will remember heating for next time. Think it will help keep them from rusting again for 60years? Going to stove black my Fenton's tomorrow, have any tips for that? Help is always appreciated.
  24. 302GMC
    302GMC
    from Idaho
    Last few pairs I did, several coats of Rustoleum BBQ paint followed by 1/2 hr in ma's oven at 200 degrees.
  25. Neb Hillbilly
    Neb Hillbilly
    Didn't get much done today. Clips turned out nice on the flat top. Crank turns out to be a 302 crank. It is going to be ground Monday. Tried stove blacking my Fentons but found a crack. Tried veeing it a bit to braze it but it is WAY too thin. I will have the welder at work use some nickel rod and fix it. Wish I had Nicsons but my budget is tight and I have these. Found a NOS 292 balancer and have to turn the back groove off of it. Not sure how to get a small groove on my water pump or where to get a kit yet. Cleaned up my best timing cover and looked for bearings on the net. Looks like EBAY it is. Super Cool 35 Chevy was unloaded in their shop today. They are getting it running and stopping. They work on lots of cool projects here. Moved my parts to a 3 layer cart. Lots of extras I will eventually have to store in the barn. IMG_20200229_085741.jpeg IMG_20200229_091226.jpeg IMG_20200229_110407.jpeg IMG_20200229_110402.jpeg IMG_20200229_092648.jpeg IMG_20200229_092828.jpeg IMG_20200229_114707.jpeg IMG_20200229_114720.jpeg IMG_20200229_103624.jpeg IMG_20200229_124728.jpeg IMG_20200229_124734.jpeg IMG_20200229_124738.jpeg IMG_20200229_124806.jpeg
    Unique Rustorations likes this.
  26. Neb Hillbilly
    Neb Hillbilly
    Also put my repaired super T-10 back in this but it is to new for ham posts 1583020035797.jpeg
    64zim likes this.
  27. Neb Hillbilly
    Neb Hillbilly
    Got a text that my crank is done. .010 on the mains and .020 on the rods. Not to bad for a crank that looked like it was on the ***anic. 2020030295064627.jpeg
  28. Gofannon
    Gofannon
    Chevs of the 40's should have the pulley you need. Or maybe NAPA https://www.napaonline.com/en/p/WP_58126
    There are a couple of different Chevy pumps. The one on my 55 1st series has narrow pulley and fits a GMC.
  29. Neb Hillbilly
    Neb Hillbilly
    The outlet is diffrent than the pump I have in the shop. Do you notice a problem with hoses on your application?
  30. Gofannon
    Gofannon
    Mine is going into a T roadster, haven't built the radiator yet. You could just swap the pulley, 53-54 Chevy I think has the narrow one. Surely someone on the HAMB has a junk one they could off load to you?
