Hot Rods Spalding Bros Repro, for "Too Tall" Ganahl.
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Jul 13, 2015.
  1. 1940Willys
    1940Willys
    I do not know about or have I ever seen a torque tube driveshaft. I find it odd that they are not a hollow tube to take the torsional forces like our modern driveshafts.
    Stogy and loudbang like this.
  2. Marty Strode
    Marty Strode
    Ford used an enclosed tube driveshaft from 32-36, and some in 37, before going to the 6 spline solid shaft. Chevy's employed a tube through 1954, and Buick though 1960. The 35-37 tapered tubes were a favorite of Hotrodders for exhaust systems.
    Stogy, cactus1, 1947knuck and 6 others like this.
  3. Marty Strode
    Marty Strode
  4. 1-SHOT
    1-SHOT
    from Denton
    Ford later puts a center bearing in the torque to stop vibration.
    We ran into this when we built a 2 seater outlaw sprint car it had bad harmonic vibrations because of the extended length, we finally went to a Carbon Fiber Drive shaft tube like in 35-36 Fords and this stopped it. We also put a Carbon Fiber tube in a regular WOW 410 car but we spun the splined end loose in it and went to a steel shaft in it. Smiley’s still has 4 school cars that we use, those things are fun to drive.
    P.S. I really appreciate you sharping you talents with us. I would really love to have one of your dirt track T . Frank
    kidcampbell71 and loudbang like this.
  5. Marty Strode
    Marty Strode
    Maybe Smiley needs some school Track Roadsters, for the older set !
    1947knuck and loudbang like this.
  6. 1-SHOT
    1-SHOT
    from Denton
    I have made laps in my 29 at several of the dirt tracks while we are having school its flathead powered and my present build before I 62D94A2B-EC64-4835-874F-F730CB9B6F52.jpeg 0BD611FD-68B1-4387-97CA-CB2AF9C73666.jpeg C740B026-5F33-4477-BC9C-C32ED802A5C1.jpeg 5644F3AF-764D-4D3E-B797-5B7D7AEA5EE4.jpeg 164728A4-8299-4D8A-9222-D13B42BEAF5C.jpeg F920C9B5-D3DF-42C3-9016-980A4727F181.jpeg F3480C8A-9EF5-4A4E-B5F7-D2DC5BCE23B9.jpeg changed the windshiels
    Being 78 and Smiley being 80 we dont see many old folks.
  7. Stan Back
    Stan Back
    When Scotty's Muffler put the Cad Hydro in my roadster over 50 years ago, they shortened the solid driveshaft to an acceptable length, ground the spline off it, stuck it in the link and stick welded it together. Over the years I broke lots of drive parts, but never that one.
    rod1, Stogy, town sedan and 8 others like this.
  8. Marty Strode
    Marty Strode
    Sure Jim, but you have a reputation for being gentle on parts.
  9. 48bill
    48bill
  10. Dave G in Gansevoort
    from Upstate NY
    New guy on the HAMB. saw this and must say I still have the R&C issue with the track roadsters and this car has always been one of my favorites. Mr. Strode is definitely a master craftsman. Has this car been finished yet? If so where can we see some more images of it in color, and/or a video of it running?
    Stogy, loudbang and tractorguy like this.
  11. Marty Strode
    Marty Strode
    Thanks Dave, it was long pull to get it to this point. Pat is working on getting a clutch built, and is waiting on a transmission. He has been busy with the final touches to his newly built 33 sedan, then he can concentrate on the Spalding. Thanks for your interest.
    Stogy, loudbang and brEad like this.
  12. Gofannon
    Gofannon
    Make sure Pat gives us the details of his clutch. There's some of us on here with Cyclone adaptors that would like to know!
    loudbang, Bowtie Coupe and Stovebolt like this.
  13. Dave G in Gansevoort
    from Upstate NY
    By the way were the front hubs on the original car 1940-ish Lincoln Zepher? Those hubs would help on my project to reduce the scrub radius.
  14. Dave G in Gansevoort
    from Upstate NY
    Going back and looking at the construction of the front axle it looks like a sleeve is inside the axle where the ends weld on. What wall thickness is that inner sleeve? I made my tube axle for one of my projects using 2 inch 0.250 wall dom milling the ends for the kingpin bosses. Of course I welded them in before making brackets. I made clamp on brackets, one of which pivots like Kurtis did on Indy roadsters, but they are heavy. I want to make bracketry similar CAE had, and your axle construction method will allow me to ket them on the axle. Thanks
  15. Marty Strode
    Marty Strode
    Dave, The front axle was built by BC Choppit on here. The ends are built with a flag welded to the boss, wrapped with a sleeve, fully welded, and machined. The king pin bosses are honed, for a perfect fit. He then inserts the ends (with a minimum of 2" inserted into the 1/4" wall tube, and welded. I had him leave one end off, so I could slide the link plates on, and weld the one end. I can't find the photos of the end, prior to the install. If you contact Bill, he will show you how he does it, and build one if you desire.
    Stogy, Bowtie Coupe and loudbang like this.
  16. Dave G in Gansevoort
    from Upstate NY
    Thanks. I can picture what it looks like from your description. I guess I'll be making a new axle that way, or using the heavier swing sleeve already made.
  17. kiwitudor
    kiwitudor
    Love the build thread, picked it up from Pat's Rod and Custom in the garage post, so maxed out thru all 53 pages in one go! Just curious with the tooing and froing what did the wheelbase end up at?
  18. clem
    clem
    ^^^^^^ first post kiwitudor, - welcome to the HAMB !
  19. Marty Strode
    Marty Strode
    As I remember it came out at 100". Pat called today, and is starting back on the car, now that his 33 is finished. He rounded up, most of the parts necessary parts to make it run.
  20. kiwitudor
    kiwitudor
    The scary big wide world lol Cheers
    chryslerfan55 and clem like this.
  21. Dave G in Gansevoort
    from Upstate NY
    So Marty, Pat, how about an update. Even if it's just "still collecting parts, more next month". We're all getting anxious to see more... PLEASE!:(
    loudbang, X38 and kidcampbell71 like this.
  22. Pete1
    Pete1
    from Wa.
    Just curious Marty, do you use 7 inch clutches in your cars?
  23. Marty Strode
    Marty Strode
    Dave, Pat is making headway, perhaps he will give us an update. I do know, he has the clutch issue handled, trans is back in, and and ready to plumb the brakes. He has been a busy guy !
  24. Marty Strode
    Marty Strode
    Pete, we normally use 10" clutches, as they are street driven as well. Pat's is a different deal, he was having problems, getting the clutch and flywheel installed, using the Cyclone adapter bellhousing.
  25. Gofannon
    Gofannon
    Marty, a 9 1/2" clutch will fit a Cyclone. I was lucky enough to find an Aussie XB GTHO Falcon 9 1/2" twin plate that I think will squeeze in. Making a 5/16" mid plate to space the bellhousing back a bit for clutch cover clearance. That's with Packard trans and Hildebrandt adaptor mated to the Cyclone. I won't know for sure until I get the machining done and bolt it all up. Probably an over kill! If Pat wants to go to a diaphragm type rather than Long style, I think Jaguar 6's used a 9 1/2" single plate.
    hendelec, Stovebolt and chryslerfan55 like this.
  26. Marty Strode
    Marty Strode
    Thanks Mike, good info.
  27. Marty Strode
    Marty Strode
  28. Tim
    Tim
    from KCMO
    Thanks for the heads up!
  29. Gofannon
    Gofannon
    Stovebolt and tractorguy like this.
  30. Marty Strode
    Marty Strode
