Technical ***March 2020 Banger Meet Thread***
Discussion in 'Traditional Hot Rods' started by Jiminy, Feb 29, 2020.
  1. 51 mercules
    51 mercules
    When running a T5 behind a B motor. I see people are using a AA bell housing. Can a BB used? What is the difference? Another question are the flywheels the same for a model a motor and a model b? Thank You!
  2. Mikko_
    Mikko_
    from Sweden
    Don't know about the bellhousings but the flywheels are different between the A and B as I understand it.
    I'm going to use B-engine and B-trans in my '28 phaeton.
    Dannerr and 51 mercules like this.
  3. 51 mercules
    51 mercules
    For my A I have a B Motor and B trans. No flywheel yet. My friend is the one running a B motor with an Ardun head and wants to run a T. He doesn't do computers. That's why I am asking. Thanks.
  4. railcarmover
    railcarmover
    Some bead blasting and paint jobs are funner than others
    Dannerr, Old Dawg, winduptoy and 3 others like this.
  5. Thank Krylon for making “farm tractor implement red” paint
    If someone tells me they don’t care what color the motor is, I make another tractor.
    I tell them it’s worth 2-3 hp
    J
  6. railcarmover
    railcarmover
    Ill have you know that's Winfield regal red rustoleum made specifically for Winfield 7 to 1 heads from home depot :) Krylon is for lowballers
    Old Dawg and 51 mercules like this.
  7. Mikko_
    Mikko_
    from Sweden
    Ok, I've been told by my friend and mentor who is helping me with my car that the B flywheel is a bit lighter than the the A. And by the looks of it that seems reasonable.
    Dannerr, Old Dawg and 51 mercules like this.
  8. The B is lighter - the BF more so. An A flywheel won't fit in the B bellhousing without lightening down to the B dimensions. I have about 20 orphaned A flywheels here but the shipping to Sweden would be a killer.
    Dannerr, Ron Young and 51 mercules like this.
  9. railcarmover
    railcarmover
    B flywheel is 10lbs lighter than an A,63 lbs vs 53 lbs..the heavier crankshaft weight is offset by the flywheel reduction.the B Flywheel has two 'steps' on the outside edge,the A has three..
    Dannerr and Old Dawg like this.
  10. That's funny, a rattle can painter talking about another.
    J
    Jet96 and barrnone50 like this.
  11. railcarmover
    railcarmover
    Mr N,my guess is that there's more rattle can rustoleum on old fords than any other coating..
    Colonial Coupe, 97 and barrnone50 like this.
  12. winduptoy
    winduptoy
    So it was good to see and dine with you in Denver Saturday! ...this could have been a topic for discussion & I am glad you are planning on doing this. I don't know the paper answer but I think I would find me a level highway section and benchmark a 1/4 mile and run it with the car.
    It is going to be a combination of engine performance, main box gear split and rear end gear....that would allow for a real performance test. How does it do with the current set up? Do you run out of motor or gear?
    My thoughts....
    Binger likes this.
  13. 51 mercules
    51 mercules
    Thank you!
  14. Mikko_
    Mikko_
    from Sweden
    Thanks for confirming.
    And I already have a B flywheel for my car so no shipping needed.
    Dannerr likes this.
  15. Binger
    Binger
    from wyoming
    I am not sure about the BB bellhousing but for T-5 conversions people like the AA because it is shorter than a stock A. It allows the input shaft from the T-5 to engage the clutch. I used a stock A bell for my t-5 conversion and had a little adapter shaft made out of a T-5 clutch hub and and an old input shaft.
    I hope this helps. There are more pics in my build thread. There is a link in my signature.
    edfueler, Dannerr, rwrj and 2 others like this.
  16. 51 mercules
    51 mercules
    Thanks for your input and pic's.
    Binger likes this.
  17. 51 mercules
    51 mercules
    Now I see! Thanks![​IMG]
    Dannerr likes this.
  18. fourd
    fourd
    from Colorado
    On 1/8 mile don’t top out in third. I will experiment but not overthink it like I was.
    A veteran racer friend who I shall not name put my car down the 1/8 mile 4times and won the last 3 by a good margin. He sad “I left it 2nd and it kept pulling”. The flywheel bolts were less than hand tight after that.
    Old Dawg, Jet96 and winduptoy like this.
  19. railcarmover
    railcarmover
    My little bit of experience understanding stored energy and Mr Fords desire to dampen torsional impulses with flywheel weight led to 63 lbs. For a street car pulling 10 lbs off by using a B flywheel and a dynamically balanced A crank allows a little better spool up and faster shifts,but is still nice to drive.
    51 mercules likes this.
  20. luckylou
    luckylou
    from canada
    What is the overall length of that adapter
  21. I would believe more rust than paint.........
    Come to find out, I never look at the labels, it is Rustoleum Tractor Farm Implement Red paint.
    Whoda' thunk
  22. railcarmover
    railcarmover
    el oxido nunca duerme...rust never sleeps
    winduptoy and hotrodfil like this.
  23. guitarguy
    guitarguy
    I have never seen a "B" flywheel before, but pretty interesting as I just whittled my "A" flywheel down to 51 lbs.....51.15lbs to be exact, and it looks similar to the stock "B" flywheel. I could have gotten a little more off probably to 48lbs give or take, but my target was 50lbs, I'm not going to worry about the last pound.
    Dannerr, rwrj and 51 mercules like this.
  24. 97
    97
    I just wish we could buy a good quality rattlecan paint like Rustoleum in New Zealand!!!:eek::eek:;)
  25. railcarmover
    railcarmover
    Once you free yourself from the chains of perfection paint and body is fun.
    Binger, rwrj, Jet96 and 1 other person like this.
  26. Not knowing what the flywheel is going in, most will upgrade to a 3 finger 9" clutch.
    If you want to do this, the step can be removed, approx #2.5 and then you can remove a little more from the clutch surface. You will have to drill and tap for the new clutch, not difficult. This is probably the most common conversion. If you need more clutch torque capability some use a diaphragm clutch from the S10 pickup.
    On a side note, what machine are you turning the flywheel on?
    Best, John
  27. V4F
    V4F
    from middle ca.
    *** guess im lucky as my clutch disc is splined for the T-5
  28. Kiwi 4d
    Kiwi 4d
    Was that a touch of subtle sarcasm @97 ? I just bought a can yesterday at the local paint store.
  29. winduptoy
    winduptoy
    I think the 9" clutch conversion is one of the things that absolutely makes the Model A/B more driveable.
    Dannerr and G Baese like this.
  30. winduptoy
    winduptoy
    mdimages, Dannerr and 51 mercules like this.
