Projects 1960 Pontiac Catalina Stick Car!
Discussion in 'Traditional Hot Rods' started by 31hotrodguy, Mar 3, 2020.
  1. belair
    belair
    Great score. Congrats.
    loudbang and kidcampbell71 like this.
  2. The Catalina has a 55 thru 59 engine. because its reverse cooled. So its a given it not the original 1960 engine.
  3. 31hotrodguy
    31hotrodguy
  4. My buddy, Sonny and I once bought a 60 star chief 2 door sedan[!]. I wanted the 389 for my 56 pontiac and he wanted the mint bumpers off it for this car. Rest went to scrap. sonnysponcho.jpg
  5. I cant help with engine numbers. However if the engine will rotate you can stick something in a spark plug hole and measure the stroke.
  6. Unique Rustorations
    Unique Rustorations
    Happy to help with the numbers...as others on here will do I’m sure. Randy
    loudbang, bchctybob and 31hotrodguy like this.
  7. Poncho60
    Poncho60
    from N Illinois
    If that car has the correct 1958-60 bellhousing, you can use any late model muncie, t10 or whatever trans behind it.
    loudbang and 31hotrodguy like this.
  8. 32Dan
    32Dan
    from Chino, CA
    [​IMG][​IMG]
  9. Cool 33
    Cool 33
    My dad bought a 60 4 dr. new. It was a 3speed on the column, 389, radio delete plate car. I had never seen another 3 speed column shift until I saw this thread.Must have had a rear gear actually suited for an automatic because it was anemic in low but would run almost 100 in second. I still have the body(very rusted out because vandals broke all the glass out years ago). If anyone needs the bumpers/brackets, steering column and wheel,grille or dash they are very available but no shipping, must be picked up.
  10. southcross2631
    southcross2631
    Be sure and check the motor mounts. They are bad to break and rock the engine and pull the throttle all way open . happen to my sister-in-laws car fortunately my brother was driving and he was able to shut the key off.
    another friend had a 59 Pontiac and his did it and he was in a parking lot and he got it stopped after he hit the 3rd car.
  11. 31hotrodguy
    31hotrodguy
    Old Wolf, we still might need to talk about some of the smaller stuff and maybe work something out. [emoji3]
  12. 31hotrodguy
    31hotrodguy
    And the engine is stuck! Not a big surprise. We have it soaking and it got it to move a little bit. We shall see!
    1947knuck, chryslerfan55 and loudbang like this.
  13. 31hotrodguy
    31hotrodguy
    I gave bored kids that wanted to help rubbing compound and a buffer (not shown) and said have at it! Surprisingly the paint is shiny in some places. IMG_8105.JPG IMG_8107.JPG
  14. mgtstumpy
    mgtstumpy
    I recall another member had a similar YOM Chevy long roof and wiped it over with CLR before clear coating it. All original and looked great when done. Here's an example how CLR can rejuvenate old original paint.
  15. 31hotrodguy
    31hotrodguy
    Oh wow! I will buy some tomorrow morning!!!!!!
  16. Chief 64
    Chief 64
    Great your kids are involved! Keep doing that!
    Also.....That bronze color is really growing on me.
    mgtstumpy, loudbang and 31hotrodguy like this.
  17. 31hotrodguy
    31hotrodguy
    Yeah me too but apparently my patina is not a cool as others because my car looks the same after cleaning the rust. Lol
  18. 31hotrodguy
    31hotrodguy
    The driver side head casting number gives me some hope that the engine is a 389. IMG_8136.JPG
  19. 370waterneckL.jpg Your heads are 1959 Pontiac 389. Valve sizes are 1.78" intake and 1.50 exhaust. Look at the front of the block just below the passenger side head for a letter code. Will prolly be a single letter. Tell us that letter and we can give you more info on your [hopefully] 1959 Pontiac engine. The 59 engine is just as good as a 1960 engine and some guys will say the '59 engine is better because of the reverse cooling. I run reverse cooling into my 1974 GTO heads on my 370 Pontiac engine in my 34 ford......never a problem with cooling.
    j-jock, 1947knuck, 47ragtop and 4 others like this.
  20. 31hotrodguy
    31hotrodguy
    Hey Rocky,
    Did you mean 1.88 or 1.78? Wallace Racing listed them as 1.88.
    I’m working today he weekend but I’ll go scrap crude off the front of the engine tomorrow.
  21. loudbang
    Great find not many stock stick cars out there. IF you plan on any paint work in the future I would hold off on applying CLR or anything else that MAY cause you headaches when trying to paint over it.
  22.
  23. 31hotrodguy
    31hotrodguy
    Here is a picture of the letter and numbers on the passenger side block just below the head. Does this tell me what year block? [​IMG]
    1947knuck and loudbang like this.
  24. sunbeam
    sunbeam
    It's got the peanut Muncie so Chevy transmissions should work and a 59-60 Buick Olds or Chevy sedan windshield should interchange. A 60 2dr sedan is my pick in Pontiacs.
  25. 41rodderz
    41rodderz
    from Oregon
    Or a real stock car as in a NASCAR replica :) Cool car and glad another is saved .
    chryslerfan55 and 31hotrodguy like this.
  26. 41rodderz
    41rodderz
    from Oregon
    Looks like by the young ‘be smile you are raising them right. Future hot riddlers.
    31hotrodguy likes this.
  27. 31hotrodguy
    31hotrodguy
    Thank you! Yeah, we have a good time! We don’t accomplish much but we have fun! Lol
  28. Bullit68
    Bullit68
    from Verona, PA
    I had a 60 Catalina 2dr sedan, 389 auto, converted to (correct) tri-power and 4spd with original parts. Used a brand new Richmond T-10 trans in it. Mine didn’t have reverse lights either, like this car
  29. Bullit68
    Bullit68
    from Verona, PA
    Another pic. The engine had the entire vin number stamped on the front passenger side of block. Added the long ram manifolds and oil filter relocation
  30. D = 59, 389, 2bbl, 245 HP, manual trans...considered a 425E series engine
    1947knuck, Cosmo49, jaracer and 5 others like this.
