Projects Father/Son 63 Chevy C10 SWB Build Thread
Discussion in 'The Hokey Ass Message Board' started by guthriesmith, Jan 2, 2020.
  1. guthriesmith
    guthriesmith
    Thanks, but actually it is a 73-87 crossmember with all the steering linkage other than the pitman arm which is still the 63. According to where it was on the other frame and how everything levels out when all other joints are attached, it appears to want to land about here. I’ll make sure tomorrow that everything is right before I mount it.
  2. Holmes Cycles
    Holmes Cycles
    Ahhh alright cool, didn't realize you had a different year crossmember....may want to check just to see if the other idler arm would still work, just to utilize the stock frame holes....may work, may not, worth the shot for cleanliness
    1Nimrod, Thor1 and loudbang like this.
  3. guthriesmith
    guthriesmith
    Good point. Wouldn’t take much to mock it up and the one I took off is just behind the shop. I’ll check that out! Thanks!
    1Nimrod, Thor1, 1947knuck and 2 others like this.
  4. Junior Stock
    Junior Stock
    And that is a bad thing? Haha
    Always nice to see a younger crowd interested in the old stuff.
    1Nimrod, guthriesmith and loudbang like this.
  5. guthriesmith
    guthriesmith
    Well...I decided to follow up with Wheel Vintiques on the wheels today since we expected them to arrive. Turns out they hadn’t shipped yet based on incorrect inventory. So...praying they leave California today and make it to us by the end of next week. Otherwise, we will miss the open house and my kids opportunity to show off his progress. Not a huge deal, but I know we are both excited to see it rolling with those. I guess we will ****on up the front otherwise and move to the rear. I am heading to pick up the tires now and we will just mount them ourselves next week.
    1Nimrod, bobss396, Thor1 and 3 others like this.
  6. guthriesmith
    guthriesmith
    Mainly a parts gathering day today. Picked up the tires and a repo Cadillac air cleaner that now needs painted and a flying eyeball and pinstripes according to my son. Thankfully, I have a good friend Kyle Ambrose (lowheat) that does great traditional striping and likes flying eyeballs. Also got the rotors unmasked, greased the bearings, and put them all together. Found out the Mr. Gasket chrome dust caps slide right into the hole in the rotors so deciding whether to try something else or modify them to work. Anyway, little by little...
    E80AD018-2C66-4BBA-923E-71273B342B67.jpeg 2443830F-AE29-43C8-837F-3C79CAF55EC4.jpeg E9ECBA44-685F-4072-A913-24BD4F8AA663.jpeg
    My son was at a power lifting compe***ion all day today so is exhausted. We may call it an early night.
  7. guthriesmith
    guthriesmith
    Also, when I went to pick up the tires, made a new friend that had a fuel pump go out on his clean 57 moredoor at the tire shop. He also happened to be someone that goes on our reliability runs that we put on. Always good to meet a fellow gearhead.
    1Nimrod, Big mike 1968, Thor1 and 4 others like this.
  8. The stock 63 thru 66 idler will over center. Use the 73 up idler. no problem to drill two 3/8 holes.
  9. guthriesmith
    guthriesmith
    Good to know. I haven’t had the time to look at it yet, so will just plan on the newer one.
    The weekend isn’t over yet, but not sure how much more we might get done considering I have some house stuff to do. We did get the rearend cleaned up, put in new bearings and seals, and painted it. Also, painted the 2-1/2” lowering blocks we built and longer u-bolts for the rear as well. We had to order the gasket for the rearend cover, so didn’t quite get it completely sealed up yet. Now, we just need to install all the brake components and swap out the rearend either tonight or more likely tomorrow night.
    AAAC972C-56EF-49F9-8441-62B79C863951.jpeg 9DB00639-D675-44E3-8694-A19AC64B044B.jpeg EE492EAB-D9DF-40E9-99A6-BFDDA30FC89E.jpeg 9404A8C9-7A0E-46E0-BEAF-355FEB2597BB.jpeg 790C132E-075F-4A3A-AAC6-869364EE805C.jpeg
    1Nimrod, Thor1, JUNK ROD and 7 others like this.
  10. guthriesmith
    guthriesmith
    A little more done tonight...
    1Nimrod, Thor1, chryslerfan55 and 4 others like this.
  11. guthriesmith
    guthriesmith
    Well...got the rearend in with the lowering blocks, shocks back on, and ****oned up the steering in the front. Ended up just drilling a couple holes to mount the later model idler arm. Maybe tomorrow night, we can get all the brake parts on other than plumbing it all up. I’m getting too old to be doing this every night. Good thing we have a deadline and my kid is energetic.
    7845E1B8-806A-4317-9C37-7BC811382D00.jpeg 346F2F7C-413E-48BF-BAE8-642E7E2AF8A1.jpeg 209C244D-38F1-4410-9B9B-E19F2DBE035B.jpeg
  12. guthriesmith
    guthriesmith
    Oh, and for anyone wondering about what may not be the best joint through the lowering blocks, there are spacer bushings welded inside the square tubing to make sure I can get a good clamp load on the joint. Hard to see that in the ***embled pic. :D Attached pic is prior to actually welding the bushings in.
  13. guthriesmith
    guthriesmith
    We got a little more done tonight. Got the front completely together and greased other than plumbing the brakes and installing some shocks. And, we got the drums and wheel cylinders painted. Thinking we should be able to put all the rear brakes together tomorrow night, slap the drums on, mount some tires, and put it on the ground.
    B71201C8-38DB-44D9-9153-3D7FE8B38DBC.jpeg C214C308-62E9-43AF-8781-B9ECC51AA918.jpeg EC46B746-52EA-4593-B413-85000D628863.jpeg
  14. Rolleiflex
    Rolleiflex
    It looks like it's coming along real nice. Hope you're able to make your deadline.
    1Nimrod, Big mike 1968 and loudbang like this.
  15. guthriesmith
    guthriesmith
    Thanks! Not looking like we will have the engine in it, but it should be rolling so he can show off his work this Saturday. I forget how long this stuff takes...
  16. guthriesmith
    guthriesmith
    It’s like Christmas! Headed over to Sid’s to mount the tires on the wheels after taking my son to weight lifting. Getting exciting now that the Christmas jewelry showed up! :D Good day to take a vacation day from work.
    Edit: Decided I better test fit the front wheels when I came to my senses enough to remember the “mount them, own them” rule. I was mainly only concerned with the change to the drop spindles since sometimes they move the wheel up enough to cause problems with lower a-frame clearance or possibly tie rod clearance especially using 15” wheels. Appears we are good to go!
  17. guthriesmith
    guthriesmith
    Woohoo! He is excited now! I have to admit...I am too...just a little. :D
    01311F63-0266-45D2-8B21-D85D82FB265A.jpeg 25EAAD70-9E44-446E-A468-772D427BD9C2.jpeg
  18. JUNK ROD
    JUNK ROD
    sick!!!the stance looks just right and the frame is nicely detailed !!!
    1Nimrod, Big mike 1968, Thor1 and 2 others like this.
  19. brEad
    brEad
    Looking good! Fun to watch this father/son project come together.
  20. Jim Bouchard
    Jim Bouchard
    Looking good!!!!!
    Love the skinny whites!!!
    1Nimrod, Big mike 1968, Thor1 and 3 others like this.
  21. Nice project and doing a nice job- going to be a beauty!
  22. loudbang
    Second "like" on the just right size whitewalls. I'm 70 now but back in the day those are the size everybody was running including me. :)
  23. guthriesmith
    guthriesmith
    Thanks for all the compliments guys! Getting to this point is definitely motivating for both of us! Now, to get started on the bodywork before too long. I used to do paint and body, so like that part too. However, my son is not a big fan of things that take patience, so this will be a good learning experience.
  24. TFoch
    TFoch
    Great project and very cool truck!
  25. guthriesmith
    guthriesmith
    Proud owner...headed to car wash to get it ready for Saturday.
  26. loudbang
    Looks good in the daylight too :rolleyes:
  27. guthriesmith
    guthriesmith
    Thanks! It was definitely right at dark by the time we got to loading the pu. The rest of the story is that we had just finished unloading a bunch of fencing off the trailer so we could use it, put out a hay bale for the horses and then chased one down after she ran behind us and out the gate while we were putting the bale out :mad:, fed and watered the chickens and then finally got to what we were wanting to get done for the evening. :D It had been one of those evenings... But, we did get it to the car wash and then stopped for some milk on the way home. Oh, and that didn't include taking my other two kids to driver's ed for the evening that will also be 16 this year...
  28. xhotrodder
    xhotrodder
    Being from Kentucky & not Texas or Oklahoma, it tickled me to see your son setting behind his engine in shorts & his cowboy boots. Kids around here only know expensive sneakers. It was a welcome change of pace to my eyes. Love watching this build, have my eye on an old 60's Chevy truck down in the country I hope to get this spring if someone doesn't see it & beat me to it.
  29. guthriesmith
    guthriesmith
    Lol! Actually, this kid likes expensive sneakers too...I just make him change out of them regularly when we are working in the shop. I actually didn't even realize that is what he was wearing in that pic, but did notice it in the one I posted yesterday of him sitting on the frame on the trailer.
    And, thanks for the comments. Hopefully you can get the truck you have spotted. These pu's make great drivers and are somewhat reasonable to build. I know I enjoy mine.
  30. xhotrodder
    xhotrodder
    One other thing, I am envious of you on is, it appears that your son & you agree on how to do the work, and you do it together. My son & I fought all the time on how to do the work on his 1st car. He wanted to work on the sound system, while I wanted him to get all the mechanical things doubled checked first. A huge wooden box filled with a bunch of speakers that took up all of the back seat was more important to him than the car running & stopping smoothly. Subscribed.
