Technical How do I start 47 dodge pedal start?
Discussion in 'Traditional Hot Rods' started by tramp63, Mar 7, 2020.
  1. tramp63
    tramp63
    from fontana
    I got a 47 dodge pickup and I put it in storage. Unfortunately, I forgot how to start it. What I think I remember is that I had to push the brake or clutch the the start pedal while in neutral. I could have sworn I had to push do something w the shifter. However I don’t have the previous owners number to find out. I charged the battery and still couldn’t get it to turn over. Other electronics work so I know it’s not the battery. I’m going to take my multimeter to see if I’m getting enough power. I need suggestions and tips please!
  2. Budget36
    Budget36
    Unless the PO installed something, like a push ****on, clutch switch, etc, you should just be able to turn the key on, pull out the choke and push down on the start pedal.
    firstinsteele and flatford39 like this.
  3. Rickybop
    Rickybop
  4. Rickybop
    Rickybop
    I have to say, it made me chuckle a little when you said you forgot how to start your truck. LOL
    Sent from my VS835 using The H.A.M.B. mobile app
    VANDENPLAS and j hansen like this.
  5. Rickybop
    Rickybop
    I think maybe you didn't forget... and it's just not working correctly?
    And you thought you forgot.
    [emoji16]
    sleepchamber likes this.
  6. battery hooked up... key on
  7. well key on to energize the ignition...
  8. tramp63
    tramp63
    from fontana
    Yeah brotha. I just recall that the experience was different w positioning my feet and that could be because of the start pedal above the gas pedal. But I think it may be a power issue because I’m not getting a crank.
  9. tramp63
    tramp63
    from fontana
    Keys on bc the electric pumps on but I’m going right now to try again. Hopefully I get I figured out.
  10. Budget36
    Budget36
    If I recall, on the last foot start I had, it would crank over without the key being on. The battery connected directly to the starter, via the foot pedal, really just a manual solenoid if you will.
    If that's the case in yours as well, you should have battery voltage at the started at all times.
    How long has it been sitting? If a few years, might be best just starting off by cleaning all battery connections, both on the terminals and their mounting spots, both pos and neg. At least rule that out and you know you have good connections in the future.
    tramp63 likes this.
  11. Slopok
    Slopok
    Hey, at least you're not locked out of it!;)
    We're all getting old.
  12. Hnstray
    Hnstray
    from Quincy, IL
    @tramp63
    I was tempted to reply...”just pedal it really fast and when you get it to 10 mph or better, drop it in gear and pop the clutch”......but then I thought that sounded a little smart *** like and decided not to......:)
    Glad you got some good advice......
    Ray
  13. Los_Control
    Los_Control
    from TX
    All good advice above, key on or off, stomp on the pedal and will crank over, key will supply power to the coil.
    It is a 6 volt positive ground system, and often poor grounds cause issues.
    A fully charged battery and good ground connections then report back.
    tramp63 likes this.
  14. tramp63
    tramp63
    from fontana
    I tested the battery and it only held a 4v charge. So I think your advice is on point about starting w a fresh battery. As for the rest, you guys have me cracking up lol
    Rickybop likes this.
  15. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Truck is rebelling. Pissed you put her in storage:cool:. Cars seldom play nice coming out of storage. All sorts of weird phenomenon-from traveling zero miles.
    tramp63 and Budget36 like this.
  16. Wavetrain75
    Wavetrain75
    “Every time I learn something new, a little of the old gets pushed out of my brain. Remember that time I took that wine making course and forgot how to drive?” ~ Homer Simpson
  17. Maicobreako
    Maicobreako
    Sometimes tapping on the starter with a hammer, tap, not pound, helps. I had a truck that sat a lot and had to do that every so often.
  18. If its got a starter pedal, put it in neutral turn on the switch and mash the starter pedal. You'll probably have to choke it.
  19. tramp63
    tramp63
    from fontana
    Good news it was the battery and the clutch depressed with stater pedal. Sounded strong! So happy! Thanks all
    Budget36 likes this.
  20. tramp63
    tramp63
    from fontana
    Here’s a pic
    Sandgroper and Budget36 like this.
  21. rudestude
    rudestude
  22. ClayMart
    ClayMart
    Awww . . . c'mon. :p You're not going soft on us, are you? o_O
  23. Hnstray
    Hnstray
    from Quincy, IL
    apparently.......funny thing, that’s what my girlfriend recently asked me...:(
    Gangrene likes this.
  24. Budget36
    Budget36
    Pssst, hey Ray. They have a pill for that...
  25. ClayMart
    ClayMart
    Well, it appears that my previous post has suddenly taken a turn I wasn't expecting. :eek:
    . . . OK. Maybe I was kind of expecting it. :rolleyes:
  26. Hnstray
    Hnstray
    from Quincy, IL
    I know....I was taking them with poor results.....turns out they were blue M&M’s :confused:
    ClayMart likes this.
  27. Budget36
    Budget36
    I could go on, but don't think it's a good day to get banned from the HAMB :)
    But I'm picturing a ....never mind, M and M's don't...grrr, never mind...
  28. Hnstray
    Hnstray
    from Quincy, IL
