Technical Rear end for ‘51 chevy coupe
Discussion in 'The Hokey Ass Message Board' started by J_J2, Mar 9, 2020.
  1. J_J2
    J_J2
    With the Olds swap, the closed driveline is getting the heave ho. Trans is a side shift Lasalle, what would a good rear end be for mainly street, I’d like to be as close to period correct as possible, I was thinking 57 Olds or Pontiac?
    j-jock likes this.
  2. lowrd
    lowrd
    I used a 77 Camaro with a 3. something gear. Mine already had the spring pads cut off, but I’ve heard the pads will line up with minimal work. You will have to recenter the axle if using stock springs. Measure first.
    J_J2 and gimpyshotrods like this.
  3. High5
    High5
    I run a '57 Pontiac rear axle in my '54 Chevy and it fits fine. If you use the stock springs, then the spring perches will need to be re-drilled to center the axle with the fender cutout.
    1934coupe and J_J2 like this.
  4. fastcar1953
    fastcar1953
    s10 is what i used. Is anyone going to know if it's old or not? Or care?
    bob b. and J_J2 like this.
  5. vtwhead
    vtwhead
    I wonder if a S10 would handle the torque of the J2 Olds?:eek: Might, might not if you have a heavy foot.
    lothiandon1940 and J_J2 like this.
  6. fastcar1953
    fastcar1953
    It's held up to 300 hp 350.
    lothiandon1940, J_J2 and bob b. like this.
  7. mr.chevrolet
    mr.chevrolet
    a 57 Pontiac or Olds rear isn't going to be easy to find today.
    J_J2 likes this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    I understand that 55-57 chev rears are a good fit for these, but still require the center hole for spring locating fix that they all do. Not known as the strongest but basically the same rear that came in 409 chevs in the early sixties....
  9. 325w
    325w
    5-7 Chevy fit like a glove. Redrill the spring bolt and it's done. Spider gears are the weak link in them. 8 inch Ford will fit nice also.
  10. High5
    High5
    The Ford 9 inch rear axle would be another good choice. They were first offered in 1957 and found in Ranchero's. The '55-57 Chev rear axle that Moriarity mentioned was very popular for V8 swaps of all types. Good luck with your build. Sounds like a very cool project.
    49ratfink and J_J2 like this.
  11. 51pontiac
    51pontiac
    from Alberta
    55-57 Chev fits great with a simple relocation of the centering pin hole. My 51 Canadian Pontiac (which is the same as a Chev underneath) has been running this setup since 1976. I did have custom ubolts made up.
    1934coupe, J_J2 and guthriesmith like this.
  12. Nailhead Jason
    Nailhead Jason
    I used an 8.5 inch chevy 10 bolt from 87' Monte Carlo SS, in my 1951 Chevy. It was a tad narrower than the stock rear, and let me run a 255/60 15 tire on a 15x8 wheel with 3.75 inch back spacing in.
    treb11, lothiandon1940 and J_J2 like this.
  13. Nostrebor
    Nostrebor
    S-10 4x4 rear is almost exactly the same width. Not same era, but an easy score. The Explorer rears are also similar in width and a bunch stronger, but need dual bolt pattern wheels or a re-drill.
  14. J_J2
    J_J2
    Thanks for the responses, I’m going to take a trip to the salvage yard this weekend and see whats there, I wasnt sure what would fit underneath the car, now I know what to start looking for. I’ll post my what I (hopefully) bring home.
    Nailhead Jason and 51pontiac like this.
  15. Nostrebor
    Nostrebor
    Avoid the fancy 4x4 S-10s (ZR-1?) as they are 4" wider. You are targeting 60" from wheel mounting face to wheel mounting face, or something close to that. The S-10 4x4 rear I used is 59 1/2". You can play with this depending on wheel and tire choices/offsets obviously, but 60" gets you in the ballpark of the OG rear. The Explorer rears are also just under 60" in my experience. Take a tape and some straight edges and double check us internet gurus!
    Happy hunting!!
  16. 52HardTop
    52HardTop
    Early Nova or Camaro is another good fit. I have them under both of my cars. They came with 308s and I changed them to 373s. The 52 has a T-5 while the 51 has a 200 4R
    J_J2 likes this.
  17. 500caddy
    500caddy
    I have one out of 96 jimmy under my 53 with a g80 locker works good
    J_J2 likes this.
  18. 49ratfink
    49ratfink
    well here's an odd one that will bolt in. early 60's Mopar 8 3/4. I parted out a 53 chevy that had a BB Mopar and this 8 3/4. I ended up putting it in my 61 Dodge.... gives you the wrong bolt pattern though.
    J_J2 likes this.
  19. Slow down
    Slow down
    [​IMG]i keep this on my phone for junk yard trips
    lothiandon1940, MO54Frank and J_J2 like this.
  20. J_J2
    J_J2
    That’s pretty damn handy thanks, now its on my phone as well
  21. 4x4 s10
    First and second gen camaro
    55-57 Chevy
    Grenadas ?? Weird yes
    Explorer tears but then you get disc brakes
    And a few others
    Like has been stayed there are some Mopar axles that will fit also
    J_J2 likes this.
  22. 38Chevy454
    38Chevy454
    Being around the 60 inches gives a lot of options. But a leaf spring car like 55-57 Chevy, 67-69 and 70-81 Camaro make it easier. As many suggested be aware the stock springs on your car have non centered pin. You can redrill the pads, or use lowering blocks with offset pin holes.
    Sent from dumb operator on a smart phone
  23. deathrowdave
    deathrowdave
    from NKy
    66 Nova L79 12 Bolt is best and hardest to find . I put a 66 Nova 10 bolt in a 49 Coupe , 8 in ralley fit like God made it to fit . They are getting a bit tough today also . Ford 8.8 is the next best thing today . Ranger is narrow and laters with discs .
    Nostrebor and J_J2 like this.
  24. J_J2
    J_J2
    Thats good to know thank you!
    deathrowdave likes this.
  25. 56sedandelivery
    56sedandelivery
    73 on 10 bolt GM; they have the same diameter pinion shaft as the 12 bolts, and you can actually still find them. Plenty strong, easy to find parts, right length if you go for the Camaro, Nova, Apollo, Omega; any of the X frame platform cars. With a big old Olds J-2, don't even think about the 4 X 4 S-10's, etc; they only have a 7.5" or so ring gear, and little pinion support. Tri-Five (what we used), or your 9.3" Olds/Pont ($$$). I am Butch/56sedeandelivery.
    J_J2 likes this.
  26. vtwhead
    vtwhead
    ^^^^^^^what he said. That J2 is a torque monster. Not that the S10 won't work in most cases as many have them running around as seen but if you are going to do this why not do it right the first time and get the strongest rear you can.
    J_J2 and triumph 1 like this.
  27. bschwoeble
    bschwoeble
    Wow! That combination takes me back along time ago. The obvious rear end to use for that time period, would be 55-57 Chevy. As long as you don't run huge, sticky tires out back, it shouldn't be a problem. Good luck finding one for a reasonable price.
    J_J2 likes this.
  28. J_J2
    J_J2
    It looks like I’ll be picking up a Ford 9” this weekend. The best part is I’m getting it for $100.00. Wish me luck.
  29. vtwhead
    vtwhead
    good price. Big bearing or small? posi or one wheel peel?
    J_J2 likes this.
  30. DDDenny
    Never was a specific 12 bolt for the L79 Novas.
    J_J2 and 1934coupe like this.
