Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. LAROKE
    LAROKE
    From the BillyBob Shop log
    March 10th 2020 Elongated the master cylinder mounting holes in the cage 3/32" each to fit the mounting holes on the replacement master cylinder. Both holes were elongated to keep the geometry intact.
    That was the plan but I couldn't find my die grinder burrs. I thought I could detect the soft laughter of my Dad's spirit on my shoulder. I can't put paid to this task just yet. Beer of the day was River Horse Brewing Co's Oatmeal Milk Stout.
  2. swade41
    swade41
    from Buffalo,NY
    Cleaned up the carbs and blower I took off the 41 so I can bag and box them for future use maybe on one of the other projects. One day the weather will break around here and I can get more motivated, at least the rain is washing the salt away. 20200309_140156.jpg
    chryslerfan55 and LAROKE like this.
  3. ct1932ford
    ct1932ford
    Don't know much about the blower and carbs but I like the avatar!:p
    chryslerfan55 and swade41 like this.
  4. JOYFLEA
    JOYFLEA
    Sanded , epoxy primed and high build . Color maybe tomorrow. Shame to cover up all that pretty Aluminum. Blue
    67ECAEF2-4854-43AD-BCFC-659FE9753F1A.jpeg BB9464F7-D533-4800-8B53-B571B29A8644.jpeg EE6459A7-FAB0-4755-827F-F582789F239D.jpeg 292230B5-DBB7-49CA-AFA0-3F221E1C8443.jpeg C1FEDDFC-12DB-4DB9-9A5E-DC70BE3C85F9.jpeg
  5. harley jim
    harley jim
    Planted seeds in the green house/back porch. Garden season is coming.
    Sent from my SM-A102U using Tapatalk
    badgascoupe likes this.
  6. 31Apickup
    31Apickup
    Ground off the rivets and replaced the bent & rusty mounting bolts on a set of Guide 903 headlights, used repro Model A headlight bolts along with rounded stainless screws also sold for Model A’s. Had to file the slots slightly wider. The original bolts look to be regular carriage bolts, the replacements are curved to work with the inside of the mount.[​IMG][​IMG]
  7. Jalopy Joker
    Jalopy Joker
    watched the movie "Hollywood Knights" again 20200310_204425.jpg 20200310_204355.jpg 20200310_204413.jpg 20200310_204431.jpg 20200310_211150.jpg 20200310_214754.jpg 20200310_214820.jpg
  8. LAROKE
    LAROKE
    March 11th 2020 I didn't have suitable materials for "scaffolding" to reach the top of the truck for the paint and bodywork operations. I cheated and used some particleboard shelving I had layin' around. I was punished for that foolishness before long. Standing on the shelf I had placed over the frame rails in front of the firewall but, with my feet too far from the frame rails, the particleboard broke and I went down. The engine oil drain pan was beneath me but I landed just right and it didn't become a carnival midway dunk tank episode. I didn't get hurt and I think the Great Mechanic of the universe gave me a mulligan.
    chryslerfan55, Lil32, swade41 and 2 others like this.
  9. lothiandon1940
    lothiandon1940
    ..........................Holy chit, man, be careful! I would miss your posts if you were laid up.:)
    Lil32 and LAROKE like this.
  10. LAROKE
    LAROKE
    Thanx, I'm using a running board now, unwieldy and heavy but it's not going to collapse under me.
    chryslerfan55 and lothiandon1940 like this.
  11. harley jim
    harley jim
    Land in that oil pan and we rename you a member of the black foot tribe. Slickumtoe
  12. David Gersic
    David Gersic
    from DeKalb, IL
    One of these:
    https://www.lowes.com/pd/Werner-1-6...-250-lbs-lb-Aluminum-Work-Platform/1000381787
    might save you having to buy new shoes. Even the smaller and cheaper one from HF would help.
    chryslerfan55, JOYFLEA, Lil32 and 2 others like this.
  13. Mr. Sinister
    Mr. Sinister
    from Elkton, MD
    New carpet, new buckets and mount, moved my shifter back so I can reach it while strapped in.
  14. Tommy2Times
    Tommy2Times
    from NE Ohio
    Watched the paint dry on the rear end for my ‘56 Pontiac g***er and unboxed the new axles.
  15. swade41
    swade41
    from Buffalo,NY
    chryslerfan55 and Lil32 like this.
  16. ccain
    ccain
    Fueled up the fleet.
    Yeah... I'm into the pre-pre-war, pre-traditional, O/T stuff. :D
    swade41 and Lil32 like this.
  17. HotRod33
    HotRod33
    IMG_20200311_173549.jpg worked on finishing the exhaust on my A ...
  18. harley jim
    harley jim
    Blasted chrome all day. Somebody wants an all painted Harley
    swade41 and ccain like this.
  19. LAROKE
    LAROKE
    March 12th 2020 Starting the die grinder burr hunt. I will clean and inventory as I go along in the search. Started with my Dad's machinist tool box. Moved everything and vacuumed the same re-roofing debris that was on the truck.
    There was a coping saw, small vise and two dead multi-meters outside the box. The top compartment held computer diagnostic boards and LAN tools from the nineties, technology long gone. In the drawers were a jewelers screwdriver set, razor blade s****er, tweezers, key fobs and trinkets, novelty playin' cards, decals and dash plaques, set of micrometers, set of small hole gauges, set of small taps and dies and crimpers.
    In the thrift store chest below were a blind hole bearing puller set, master torx kit, stud extractor set, impact tool kit, screw extractor kit, brake tube flaring tool, vernier calipers, hole gauges, spring scale, disk brake caliper tool set, dial indicator, piston ring installer, letter and number punch set, the dreaded ridge reamer, piston ring compressor, dial bore gauge, valve spring compressor, harmonic balancer installer and puller set and Dad's ring groove cleaner.
    But no die grinder burrs or bits.
  20. Rusty Heaps
    Rusty Heaps
    I removed all of the interior window mouldings, door, windshield, etc., form my '50 Chevy 4dr, and wet sanded them in the bath tub to prep them for paint. Man that bath tub comes in handy for car and motorcycle parts! I wonder what else it could be used for? It's nice to have a parts wash station in the house!:rolleyes:
  21. harley jim
    harley jim
    I drove 6 hours round trip to look at a misrepresented f100 that was for sale.
    Wish people could just tell the truth
    Roothawg and chryslerfan55 like this.
  22. Budget36
    Budget36
    I got the rings off a set of pistons and have them soaking in Berrymans, exciting, right?
    LAROKE likes this.
  23. Can I ***ume that you are not married? Personally, I’d be a dead man if I tried that. However, it’s a great idea.
  24. What did I do today? Well, let's see....got up this morning and drove my Galaxie to work. ( first time since October!!) After work I went to get my newly purchased parts car. I was excited! Four hours, two winches, and two batteries later it was loaded up and headed home. The thing was literally grown into the ground (the rearend hogshead was against the dirt). Lately I feel more like an archeologist than a car guy. I also had to cut down a handful of trees....man am I tired. 20200312_175330.jpg
  25. el Scotto
    el Scotto
    from Tracy, CA
    Helped my 9 year old rebuild a Briggs and Stratton 5 horse carburetor. We got it to pop on starting fluid but I didn’t have any gas in the spare can... he was still excited though!
  26. BoogittyShoe
    BoogittyShoe
    That's precious. (See "origin of precious") IMG_20200312_161009.jpg IMG_20200312_165431.jpg
    My first rebuild was a Briggs and Stratton in a 9th grade Power Mechanics shop cl***. Sold it to a lawn mower/bicycle shop. (Later got my very first job there)
    PS: You're a good pop.
  27. blowby
    blowby
    from Nicasio Ca
    Nice to have something productive to do while taking a bath.
  28. LAROKE
    LAROKE
    March 13th 2020 Second p*** over the cab exterior, this time with Scotchbrite "cookies" in the air-powered angle grinder to get the nooks and crannies the Eastwood drum can't reach and eighty years of character bumps and dents I'm going to treat with filler before painting. Also took the more aggressive Eastwood 40 grit drum over the cowl bottoms where rust was bubbling thru.
    After getting all the bumps and dents I could see. I gave the cab exterior a Dawn dish soap and water wash down to see what I missed. Beer of the day was Fordham & Dominion Brewing Company's Back Stage IPA.
  29. guthriesmith
    guthriesmith
    Got my sons truck rolling Wednesday, so loaded it up to wash it so he can show off his progress at a buddies open house tomorrow.
    530E88E6-F5B5-4D35-AD38-5F66889C1CAA.jpeg 3E9846BA-4AE3-4762-8BC7-AE5E6CCED533.jpeg 853A02A3-62DB-40C4-B267-77F0DFEDB368.jpeg
  30. ROADSTER1927
    ROADSTER1927
