Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. lippy
    lippy
    from Ks
    I'm digging this! :cool: Great work! Lippy
    Dino 64 and loudbang like this.
  2. mad mikey
    mad mikey
    Really nice work Gary. The whole system looks great, you should be very proud.:)
    loudbang and Dino 64 like this.
  3. Dino 64
    Dino 64
    from Virginia
    Go Gary go ! :):)
    loudbang and Just Gary like this.
  4. TFoch
    TFoch
    Nice work, love the headers!
    loudbang, Just Gary and Dino 64 like this.
  5. oj
    oj
    Great Job! That was a huge effort, I salute!
    Just Gary, loudbang and Dino 64 like this.
  6. loudbang
    Great job I like that style going back into the exhaust system. That USED to be mandatory on NHRA Drag Cars back in the early 60's
  7. CAHotRodBoy
    CAHotRodBoy
    Car is looking good! I love that style and will be building my '34 in a similar fashion. I sold my A sedan a few years ago and your car sure makes me regret it. Looking forward to seeing yours on the road.
    mgtstumpy, catdad49, enloe and 7 others like this.
  8. Mat Thrasher
    Mat Thrasher
    The car and fab work are killer! Keep it up. I'm following along.
  9. Dino 64
    Dino 64
    from Virginia
    They’re huge for sure, Gary, you trying to tell us something ?;):rolleyes:
    mad mikey, loudbang and Just Gary like this.
  10. Just Gary
    Just Gary
  11. swade41
    swade41
    from Buffalo,NY
    Really nice job on those headers man
    Just Gary, loudbang and mad mikey like this.
  12. Roothawg
    Roothawg
    You are in the home stretch now.
  13. Just Gary
    Just Gary
    Stock front seats are lowered in back using thinner Model A "feet cups":
    Then moved outboard and raised just a bit in front.
    This reclined position mimics my daily driver's ergonomics, clears the huge trans tunnel, and leaves room for a driveshaft loop and short tunnel.:cool:
    I'm 6'2" and even with the top chop, have just enough headroom.:)
    Rear seats pivot around a 1" square tube frame, which is bolted to tabs welded to the subrails.
    Their rear inboard corners rest on the rearend hump.
    I ran out of MIG gas shortly after tacking everything. :oops:
    "Simplify, then add lightness." ~ Colin Chapman; Founder, Lotus racing team & car company
  14. 6sally6
    6sally6
    Just finished the entire thread!! Super build I like it a lot, But.......(you knew that was coming!) I would like to see the tailpipes out the rear much larger in diameter. Really make a statement! Maybe even flared trumpet-style. Although 2 1/2" is large for most street rods yours is more Altered looking soooo it needs to be more radical almost to the ridiculous.
    Jus say'in not nit-pick'in.
    6sally6
    Just Gary likes this.
  15. mad mikey
    mad mikey
    Very cool Gary. Now you can sit in there and make loud engine noises.:D
    Stogy, loudbang and Just Gary like this.
  16. Just Gary
    Just Gary
    The Wayne Ewing-fabricated Greer/Black/Prudhomme dragster scoop "makes me feel kinda funny, like when we used to climb the rope in gym cl***.":D
    I copied it but with an air filter inside; starting with a 9"x5" tall cardboard buck.
    Next was a male scoop buck around that, using school locker sheetmetal and cardboard...
    ...reinforced by plywood.
    The top rib is a s**** of 1/4" all-thread.
    Cut, bend, tack, critique, repeat... Until the shape is right.
    I covered the buck with three layers of fibergl*** cloth & resin...
    ...then Evercoat Rage Gold filler:
    A wood block with a 1/2" slot made a perfect sanding block to keep both the top rib and the perimeter rim straight.
    Several cycles of filler/guide-coat/block sanding fine-tuned the shape.
    Next, some dark gloss rattlecan paint confirmed it was straight.
  17. Just Gary
    Just Gary
    I covered the buck with release agent, then made the top and bottom female molds.
    Finally, the top and bottom halves of the scoop itself. Each was two layers of gl*** cloth with embedded metal stiffening rods.
    I shredded their edges really badly when removing them from from the molds:eek: (Insufficient release agent? :confused:) and had to fix them before continuing. :mad:
    The inlet screen came from the same office ventilation duct screen as my grille insert.
    It's held in place with gl***ed-in studs and lock nuts.
    Three 18 ga. triangles are plug-welded to the K&N filter base. 1/4"x20 machine screws & gl***ed-in nuts connect them to the fibergl*** scoop.
    Then, a couple layers of cloth & resin join the top & bottom halves.
    Finally, a light primer coat and mounted:
    20200310_171010_2.jpg 20200310_171619_HDR_2.jpg gbp 32.jpg 20200310_171514_HDR_2.jpg
    This was my first fibergl*** project and it needs some clean-up work, but I'm pretty happy with the results. :)
    BTW, these pics were taken four years ago but I didn't have a carb to mount it on until this past Christmas, compliments of my beloved but long-suffering bride.:rolleyes:
  18. Stogy
    Stogy
    Ya gotta be proud of that Milestone Gary...it looks awesome...
  19. Tim
    Tim
    from KCMO
  20. mad mikey
    mad mikey
    WOW! I know that was a ton of work, but is a very cool one off piece. Great job Gary, very impressive . :)
  21. loudbang
    WOW love it. Came out GREAT and nobody will have one like it. :)
    Stogy, brady1929, 1947knuck and 4 others like this.
  22. Just Gary
    Just Gary
    Thanks, guys. :)
  23. lothiandon1940
    lothiandon1940
    Wow! Nice job for sure. Looks great.
    Stogy, Dino 64, Just Gary and 2 others like this.
  24. chevy57dude
    chevy57dude
    Crowning glory for a great looking engine!
  25. 392
    392
    Nothing like a hemi. Great build. Should be a blast to mash the gas.
  26. swade41
    swade41
    from Buffalo,NY
    That scoop is great looking, the Greer/Black/Prudome car is my favorite fueler and it's scoop is part of the reason why, your scoop has enough similarities that those that get it, will get it, but enough individuality to make it garner a closer intriguing inspection.
    I've often thought about adding the center divider in my surfer scoop to make it resemble that scoop, remember Kerry's front engine dragster build, I think he made one for it too if I remember correctly.
  27. brEad
    brEad
    Wow! Great job on that scoop!
    Stogy, Just Gary and loudbang like this.
  28. Dino 64
    Dino 64
    from Virginia
    Glad you decided to use it. You did a super job finishing it up[emoji4]
  29. Just Gary
    Just Gary
    The big ol' fuel tank filler & adapter combo got replaced with a better-fitting one from RCI.
    Carter P4070 pump & custom hoses from @D-Russ & @oj, respectively. Really appreciate your help, guys! :)
    Inline Tube sells 6' straight (not coiled) stainless steel tubing.
    The 3/8" fuel line has an 85-micron filter back between the tank & pump and a 40-micron filter just before the carb.
    May add a regulator later if needed.
    Yeah- I'm kinda nerdy about neatly routed hard lines.
    Must be the residual US Navy in me :rolleyes: or maybe Scott Sullivan's @cheezwiz '55 influence.:cool:
    Tight bends are way easier with 3/16" brake lines.
    Rubber-coated clamps try to preserve the '60's race car theme.
    No one will see these details when the floors are in place. Oh well- I'm having fun.:D
  30. Dino 64
    Dino 64
    from Virginia
    Looks great, especially in stainless ! Nice job ;)
    Stogy, enloe, loudbang and 3 others like this.
